Question about Polaroid Televison & Video
Any settings on the TV ( Polaroid 50 inch P50US2236A) that can be changed to allow my to to connect to my wifi ( wifi password is 10 digits long)
Have been advised to change my password by broadband supply as I can connect the TV to wifi if I disable the encryption. Does anyone know of similar issues?
SOURCE: Emerson, I think, Dora Explorer TV
default password is 1111
Posted on Oct 11, 2007
SOURCE: Panasonic TV 50 inch plasma
I had the same problem and found that I was viewing the TV input instead of the composite input. Once I changed it back, the aspect setting would hold.
Posted on Feb 10, 2008
  • 1689 Answers
SOURCE: Insignia flat panel tv
I don't exactly know your model. I can give you a generic type answer.
I can tell you that when you select to have the full screen, it may not work in the mode for the tuner. The reason is that the programs coming in from your tuner are actualy 4:3. When asking for a full screen you are asking for a 16:9 type format. This would stretch a 4:3 picture.
Have you tried contacting the manufacture, or if you know their local factory support place for your area?
Jerry G.
Posted on May 22, 2008
SOURCE: Polaroid TLA-04011C LCD TV remote codes
I have the TLA-04011c and have yet to find a code. Out of curiosity, have yall? thanks
Posted on Jun 22, 2008
SOURCE: How to disable parental lock
Go in and reset the code.
Posted on Oct 06, 2008
I have a 50inch smart polaroid tv that wont connect to my wi fi what can i do
Have you connected any other new device to Wifi ? This is verify if you remember the Wifi SSID password.
Aug 01, 2016 | Polaroid Televison & Video
How do I enter WiFi security key AXESS TA2513-10WT 10-Inch Dual Core,Tablet Rockchip 3066 CPU with Android 4.2 Jelly Bean
First of all, you must have the password which is set for your home WIFI. You can't do anything without it. Assuming you got the password, Go to tablet's Settings, turn on WIFI. When your WIFI router is displayed in the list, select it and you will be prompted for the password. Enter the password and click Connect. When you see Connected, it's done.
Jan 10, 2015 | Tablets & eReaders
How does the iconia one 7 tablet hold the wifi password without you having to type it in every time you turn it on?
When entering the password there is a tick box that allows you to save the settings and connect whenever this wifi available, check the settings from the password page!
Dec 27, 2014 | Acer Iconia One 7 B1-730HD-11S6 7-Inch HD...
Why can't I connect to wireless?
you need a type G or above router that has the wps trigger button
or a type G wimen that can allow you smart TV to connect to the right protocals
its all a matter to the TV whats avalible on the wifi router
if you have a GH modem then look to upgrade
Nov 30, 2014 | Vizio 50-Inch LED Smart HDTV 1080p Full HD...
I can't connect to WiFi. Any advice?
Is the wifi enabled, can you see any wifi networks? If not, make sure wifi is enabled, if there is button on laptop to disable/enable wifi connections, swich wifi on.
Check from control panel -> network (network and sharing center in Vista/Win7) -> change adapter settings. If wireless lan adapter disabled (grayed out).
Jun 04, 2014 | Computers & Internet
I cant get my polaroid 7" tablet powered by android 4.1 to get to my wifi . the wifi on the tablet is turned on .i have put in the password but keep getting authentication problem. please help
Maybe try going to the router settings and changing the security settings. See if turning off wifi password solves the problem then turn it back on.
Oct 19, 2013 | Polaroid 7 in. Internet Tablet
My arnova 10 g2 wont connect to wifi it authenticates, says rembered then drops out to disabled
try deleting connection and reconnecting with password. Other options is check your router for the number of allowed users on wifi.
Dec 09, 2012 | Archos Arnova 10 G2 Tablet Android 2. 4 Gb...
My archos 605 gen 5 cannot connect to internect
Try:- Menu Settings Language and Region WiFi Region.....set to "EUROPE" Followed by: Menu WiFi Status WIFi ...important that pasword format corresponds to that of your WiFI system eg WEP or WPA. The type of format will dictate the length of code. Generally WPA can accept a longer code than WEP format although a short code can be used for either. If your Archos is set to WEP and your WiFi network set to WPA (or vice versa) the format conflict will not allow the correct password to recognised It should be possible to use the
Dec 30, 2009 | Archos 605 WiFi Digital Media Player
What is the v-chip code for polaroid tv
DVD discs equipped with the child lock function are rated according to their contents and settings vary from disc to disc. Depending on the disc, you can lock out selected scenes or playback of the disc altogether. Access parental control by pressing the left/right (direction buttons together) on the remote control and then press the OK button.
System Setup/Password
Parental control features are password protected. The original setting is unlocked. This setting allows you to use number buttons to input any password. Note: The Default Password is 1369. This password is always effective even after you
have selected your own password and changed it. To avoid the possibility of others using the default password to set the parental level and change the password, you can record this default password in another area and delete it from this manual. Some discs can be limited depending on the age of users while some discs cannot.
Manual is here
(you need Adobe Reader) and their phone # is
at the end!
Jan 05, 2009 | Polaroid FDM-0700A 7 in. TV/DVD Combo
8gb ipod touch will not connect to internet when i have a full wi
You shouldn't need to change the Address or DNS.
On your wireless router, make sure of your Firewall settings (if there is any form of blocking) and it's security settings (eg, network name, password and security type etc). Once you are sure of it's settings, on the iPod go to Settings, then Wifi. In there turn off then on wifi. Allow it to scan then if it comes up with your network, select it then type in the password when requested and tap Join. If it doesn't show you need to enter it manually. To do this tap on Other then type in the Network name. It should now request a password (if one is set) and you are then connected indicated by the wifi logo in the status bar.
For more info refer to your ipod touch manual pages 90-91.
All the best.
Dec 27, 2008 | Apple iPod touch
Televison & Video Logo
166 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
