Need a cord and remote for tv where can i get one
Hisense tv connected to cable. Unable to turn on with or without the remote
1) please test the power cord, use another However this test is very easy use the VOM.
2) if the power cord is o.k , you must test the power button for open or faulty, need to open
If you do not have enough expertise, better go to tv repair shop.
God bless you
May 30, 2013 | Televison & Video
How to fix power on problem?
This can be a result of a stuck button on the TV or remote. Remove the the batteries from the remote to prevent a signal from it being sent. Operate all the buttons on the TV one at a time in an attempt to "un-stick" any stuck button(s).
Press the power button on the TV to see if it will turn on. If it does not, check for an open fuse or tripped circuit breaker. Check for the presence of power at the outlet by connecting a table lamp or other electric device. If power is off, see if a wall switch is off somewhere - as it is not uncommon for a switch to control 1/2 of an outlet.
Make sure the power cord is connected at the TV set. Many power cords are completely removable and the end the connects to the TV may have been loosened or fallen out. Visually check the length of the cord to make sure it has not been damaged or cut. Do not use you hand to feel for damage unless the cord has been unplugged from the outlet first.
Unfortunately, if you're unable to turn the TV on; it will probably need to be serviced professionally. There are typically no user serviceable parts inside the TV itself. If your TV has a fuse holder on the outside of the TV, you should unplug the TV and remove the fuse for replacement if found to be open or blown.
Lastly, operate all the buttons on the remote - again to un-stick any button. Return the batteries to the remote when done. If your remote has a lamp to indicate when a button is pressed, check to see if it is on with fresh batteries. Old batteries may not show the lamp being on, but still allow the remote to send a signal.
Jan 09, 2012 | Sharp LC52D85U 52 in. LCD TV
Avol tv. What is direct tv remote codes for programing remote to tv
Try using the brand "Hisense"....worked for my Avol.
Sep 02, 2011 | Televison & Video
My tv will not come on, checked the power cord and the cord is fine. TV just does not respond whether you use the remote or the button on the side. Please advise.
Did you make sure that the cable cord was also connected to the TV? ....and also did you
check the battery in the remote -you may require a new one.....
Jun 08, 2011 | Philips 32PFL3403D/27 32 in. LCD TV
It did not come with a manual, speakers, or any cords. Where can I order these? I also need a remote.
The tv speakers it is build in the tv unit itself could be on the bottom of the tv,check have plastics line grill on the bottom of the tv.The manual tries to down load it from it website itself,if the tv itself is still in an selling on the market.Not search for the 1-800 number on their website pay them a charge they'll send it out to u.The tv a/c power cord tries websites like Partstore.com,Amazon.com,Ebay.com to buy a power a/c cord.Tries website like Remotes.com to buy the tv original remote or a very close compatible one.
May 13, 2011 | Sceptre X37sv-Naga 37 in. LCD Television
Need directions on how to hook system up to tv
Check the back of the system, you will find Video out, then Audio out (left and right). Connect the yellow cord to video out, and the white & red to Audio out appropriately.
Then connect the other end of the yellow cord to "Video in" at the back of the TV, then the red and white to audio in at the back of the TV.
After connecting as directed above, turn on the TV, then turn on the system. On the TV remote control, press "AV" or "Source" depending on what is written on the remote and there should be a display. If there is no display, press the "AV" or "Source" on the remote once or twice more and there should be a display of the receiver's welcome screen on the TV. You might also need to press "Source" on the system's remote if there no display.
Let me know if you don't av display even after following the above steps. The above is the correct way of connecting so it should work.
Note; The White and Red cords stands for Audio left and right, while the yellow cord stands for Video. The yellow is suppose to allow your system display on the TV screen, while the Red and White is to bring out sound.
I hope the above helps.
Good luck.
Feb 01, 2011 | Audio Players & Recorders
The tv quit responding to the remote
On this unit if you do a fact reset it should fix this problem steps as follows. PS you might need 2 people
1- unplug power cord from back of TV
2- on the key pad on the tv hold the input and vol dowm buttons
3- while holding the buttons plug the tv in, keep holding the buttons until the screen comes up.
4- once the screen is up there should be a white K in a blue or green box.
5- next, on the key pad on the tv press the channel and vol down buttons once.
6- a menu should pop up
7- using the sharp remote,locate the directional pad
8- press the down button once should bring you to a 2nd page
9- top should state FACT INIT press the right arrow once to turn on, next a series of back slashes come up.
10- screen goes green and says INIT Successful
11- unplug power cord from back of tv wait 10 sec then plug back in. tv should turn on by itself. should be back to as new.
Mar 19, 2009 | Sharp LC52D65U 52 in. LCD TV
I need a power cord and remote for tv
hi,
no problem purchase remote control from blow link --
http://www.google.com/products?hl=en&client=opera&rls=en&hs=VYV&q=purchase+konka+tv+remote&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
and purchase power cord from ---
http://www.google.com/products?hl=en&client=opera&rls=en&resnum=0&q=purchase+konka+tv+power+cord&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
please give me FixYa if you find the solution
Thanks for using FixYa
Jan 05, 2009 | Konka Televison & Video
Virgin pulse 10inch tv dvd player
you can use any A/C cord that happens to fit the TV. Use a universal remote, if there are no good codes for the TV then you'll have to use buttons.
Dec 09, 2008 | Virgin Pulse VP-10 10.4 in. TV/DVD Combo
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
