Question about Refrigerators
My RCA Ice Maker says add water when it's right full to the max line what can i do?It's a brand new machine
Bought at Wallmart as a Christmas present never has made any ice for me. model #RIC102-SILVER
    Top Expert:
  • Refrigerators Master
  • 49,128 Answers
Call the service agent for a warranty check/repair or refund
Posted on Dec 29, 2016
Where does the water go in the model IM90 emerson ice maker
open the lid and remove the plastic ice basket. Look on the walls under the ice basket and you should see a "fill line".. Water should be poured into that area (below where the basket goes) no higher than the max fill line.
Oct 21, 2014 | Emerson IM90 Portable Ice Maker
Why doesn't our new icemaker in a whirlpool ed5 fridge work?
Make sure water line valve is turned on where it taps in to water line,and that ice shut off is down not up, check to see if water is in ice tray or if it is dry if no water or ice is present then water is not getting to it if water tap valve is open then water valve in ice maker is off or ice shut off arm is up instead of down. Try pouring warm water in ice tray see if that will get it started.
Jul 21, 2014 | U-Line Icemaker
Brand new uline ice maker not making ice
If you have water and power to unit and no kinks in water line and water filter is not clogged then you need to call company you bought it from the machine is under warranty and repairs will be no cost to you.
Jun 19, 2014 | U-Line Icemaker
How to install the water for the ice maker
To hook up an water supply to an ice maker falls under two catagories. The first being that a water supply valve is already present behind the machine and therefore all you have to do is get a water line, preferably a braided steel ice maker line that can be purchased at home depot or lowes. Then you just sonnect the water line to the water supply at the wall the to the water valve on the machine, located on the lower right or left side in the back. The second scenario is yoo don't have a supply line, and in that case your going to have to locate the nearest water line, most likely under the sink, and you'll have to run a line. They have an ice maker installation kit at home depot and lowes, and you may have to drill a hole through the cabinet to make the line unseen, or even through the floor and back up again. Either way its not a difficult task, just takes time and patience. Good luck.
May 10, 2012 | Frigidaire Refrigerators
Add water light stays on when the reservoir is full
I have the SPT IM-100 Portable Ice Maker. After about 2 months, it stopped, telling me that it needed water, when of course it was full of water. I did alot of digging on the Internet to find a solution. There was none. It finally occurred to me that the water sensor might be calcified with our hard water here in Reno. BINGO!!!! I ran several cycles with lemon juice and vinegar (you pick your favorite non-toxic acid), and the damned thing started up again as if brand new.
Jul 24, 2011 | Sunpentown SPT IM-100 Portable Ice Maker,...
Ice maker makes about 8 cubes every 3 hours. That is pretty darn slow. Is there someway to increase production speed. This is a brand new refrigerator
The best way to deal with this issue is to use a step by step trouble shooting procedure, and in your case paying special attention to the line supplying water to the machine including all fittings. May be a bad water connection problem.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Apr 15, 2010 | Frigidaire FRT18B5J Top Freezer...
Frigidaire refrigerator, ice maker
If the ice maker is doing the normal cycle and when calls for water doesn't get any,probably the fill tube to the ice maker is clogh with ice because the dual valve (solenoid) is leaking and this water freezes up clogging the fill tube , or the solenoid doesn't work ,in both cases it has to be replaced(it's located in the back of the refrigerator attached to the water supply line).
Aug 28, 2009 | Frigidaire FRS3R5EMB Side by Side...
Fill water light comes on while the water is full on my BlueIce model 80533 Icemaker
I had the same problem with my machine bought from Costco - did you know that Costco will refund or exchange your item no matter how old or how long out of warranty?
They pledge to make you happy or you can have your membership money back.
we took our 28 month old Blue ice model 80533 ice maker back to Costco and got a full refund and then bought a brand new one. The new one was £30 more but when we complained and then threatened our membership (they did not want to do an exchnage as it was more expensive now) they relented and gave us an exchange.
we understnad from friends that it could eb 10 years old and Costco will still refund your money, so try this.
Aug 08, 2009 | Deni 5000 Scoop Factory 1.5 Quart Ice...
How do I get water line to ice maker defrosted?
you will have to remove the Ice maker and the use either a hair drier or shop vac the blow air onto the line unit it thaws. Have a Merry Christmas and thanks for using FixYa.
Dec 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
