Question about ViewSonic N3752w 37 in. LCD TV
How to repair my viewsonic N3752W. It has limited response from the remote and no use of the manual controls.
I have a viewsonic lcd tv that was zapped with static electricity while turning it off manually. It will now only turn off or on with a remote. I can use it as a monitor with hdmi, and pc mode.
SOURCE: ViewSonic N3250W Locked
Yeah, my 19 year old daughter did the same thing. I found a solution on the 2750W thread
http://www.fixya.com/support/t115143-tv_just_flashes_different_colors
Solution - just press Menu, Enter and Power buttons at once.
Posted on Mar 12, 2008
MNfisherman
  • 11896 Answers
SOURCE: TV wont turn on with remote or the power button
ONE: The protection circuit has taken over the power managment of the set. When you unplug it for a couple of hours or so and plug it back in it will start up because the circuits have all been reset (unplugging the power cord is a reset operation.)
TWO: The protection circuit goes into action whenever it detects an excessive amount of current being drawn from one of the 10 sections of the tv circuitry.
THREE: When it won't turn on it is because the protection circuit has captured the ON function and holds the power relay OFF until it is reset.
FOUR: So, the problem area could be any one of the 10 or so sections of the tv. The most common of which is the high voltage section because it uses the greatest amount of power. If so, this could be very expensive.
FIVE: On the other hand, it could be one of the other sections and a small part such as a resistor or capacitor shorting down. In which case the cost of repair may be only a few dollars.
SIX: However, you will need a tv tech to come to the home and diagnose the set because we cannot tell where the failure is without a hands-on diagnosis by one who knows how to test the circuit sections.
SEVEN: Usually a shop will send out a tech who will do a quick check and tell you what is wrong with the set and how much the repair cost is going to be. A house call such as this will cost from $40 to $80 depending on the distance and the price they set. I suggest you call a few shops and get their best response before deciding which one to employ.
Let me know if you will need further assistance
Posted on Jan 17, 2009
  • 9 Answers
SOURCE: all buttons on tv stopped working only turns ON no ...
There is a button lock in the menu of the television. Using your remote access the menu screen and unlock the buttons.
Posted on Feb 19, 2009
SOURCE: Remote code
I had the same problem with a Viewsonic N3735W LCD TV and Comcast Customer DVR 3 Device remote. I contacted Viewsonic and they gave me 11454 which works.
Posted on Jul 29, 2009
SOURCE: viewsonic n3752w lcd tv has goneblack,the green light is on.
Viewsonic n3752w lcd tv has goneblack,the green light is on.
Posted on Dec 08, 2009
What is the code to use on a universal remote
Each brand of universal remote could have it's own code for the TV so without more info, no one can help you.
You can also check to see if you have a search feature on the remote which will allow you to try every code until one works.
Mar 31, 2013 | ViewSonic N3752w 37 in. LCD TV
My Viewsonic N3752w is not working. First it would not turn off - all of the buttons on the TV, including the power button, would just bring up the start menu. I unplugged the TV, and now it will not...
Leave it unplugged for 10 minutes (normally 1-2 minutes to clear the memory). Try turning it on again via the TV. Can you also turn it on via the remote?
If this helped, please mark this as helped.
Dec 14, 2017 | ViewSonic N3752w 37 in. LCD TV
Viewsonic N3752w LCD TV: plug in, red light goes on, press button and green goes on but then off before any picture; seems dead, no red light or green and nothing happens when press button again. If I...
We have the same problem with ours. I'm suspecting it's the power supply board. I'm going to order a new one, swap it. That should fix it, I suppose.
Oct 04, 2010 | ViewSonic N3752w 37 in. LCD TV
Hi just got a ViewSonic N3752w 37 in. LCD tv from a friend with a pretty banged up screen. It has several lines in the picture as well as some blackend screen. Any idea of whether it is repair able or how...
It sounds like the LCD panel is badly damaged, if that is the case, it will not be worth it, sceen is the most expensive part of the whole TV, you may be able to sell each parts of the TV on EBAY. Post the pictures of the screen will help.
Parts price: http://www.shopjimmy.com/catalogsearch/result/?q=ViewSonic+N3752w+
Dec 17, 2009 | ViewSonic N3752w 37 in. LCD TV
NEED THE CODE FOR THE COMCAST REMOTE
http://www.comcast.com/corporate/customers/customer_support/remotes.html
try this link... it has codes for most tv's. if it does not then it will instruct you how to do a code search
Jun 27, 2009 | ViewSonic N3752w 37 in. LCD TV
ViewSonic N3752w 37 in. LCD TV Logo
47 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
