Sounds like the motor is laboring when opening. It opens fine just makes a lot of noise. I have greased the platic cogs and oiled the chain and rollers but the noise is coming from the motor unit.
It is 10 to 20 degrees outside so is that the reason or is something going out on the unit?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
Check motor bearing may be need lubrication or damaged need replacement if sleeves need replacement
Posted on Jan 03, 2017
RepairUSA
  • 50 Answers
SOURCE: Fan making loud noise like it needs oiled
Most of the fan motors can be oiled. You will have the slide the ac forward and remove it from the case to access it. You will find yellow pull pins on each end of the motor, a lite drop or two is all that is needed.
Posted on Aug 18, 2007
SOURCE: I have a Samsung RS21DPSM
There is a design problem with this model. The fridge section is icing over due to a design defect and the noise you can hear is due to the fan on the motor driving against the ice. Eventually the motor will be stopped from running and the fuse will blow in your plug. Contact Samsung and they should replace the defective parts with a fix.
Posted on Jun 03, 2008
22yooper
  • 828 Answers
SOURCE: outside makes loud noise
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
Posted on Jun 16, 2008
  • 22 Answers
SOURCE: excessive oil leaking from condenser motor
A bit late late for the date listed, but for future reference:
The condenser coils are easy to clean by simply rinsing them with a water hose with LOW pressure. Grass or sand can easily get sucked into the condenser coils (think of it a an oversized vacuum cleaner) and slowly decrease the machine's ability to shed the heat it is pulling from inside. If the coils are really clogged, follow this procedure: 1) Turn the thermostat to "OFF" and if others are around, tape a note over the thermostat stating "DO NOT TOUCH!!!", 2) outside on the wall there should be a disconnect box with a pull out power connector or a flip switch - pull out the power bar noting which side is up or flip the breaker to off. Be sure the main power to the condenser is off. 3) A few 1/4" or 5/16" hold the top on, including the fan. Remove the screws (note if any screws are longer than the others and mark where they went) and lift the lid (fan and all) up and if there is enough slack in the fan wires you may be able to lay it over, if not, use a stick to prop it up. 4) Use a LIGHT mixture of a alkiline cleaner like 409, Purple Stuff, etc. DO NOT USE ANY ACID BASED CLEANER! Soak the coil through (not just the outside) and let it sit for 5-10 minutes. 5) Use a garden hose and a spayer nozzle (but not with a hard stream as it may bend the fins on the coil) and THOROUGHLY rinse the chemical and debris out. Do not get any water or chemical into the electrical area! (While the lid is open, grab the fan by the hub (center) and give it a pull in each direction; there should be vitually no "play" on the shaft except a small amout up and down. If there play or grease visible, it probably won't be long before the motor gets hot and siezes). 6) Put the lid back on making sure the wires feed back into the electrical compartment and are fully out of the way of the fan blade and putting the screws back in snug making sure any longer screws go back to the same spot. 7) Turn the main power back on and start the a/c. For regular cleaning, just rinse the coils with a garden hose. Depending on the conditions maybe every 2 weeks with lots of sand blowing or mothly in a grassy area.
The fan motor: if it has oil/grease leaking it will fail at the worst time (Murphy's Law). Most warranty repairs have to be done by a licensed contractor. For any repair it's a MUST to do price shopping and reference checking. Sometimes it's better to pay 25% more for a company with a good reputation than a hacker that may even wire the motor wrong.
Bottom Line: Get a maintenance contract with a reputable company that will clean the air handler and condenser and check for weak components and not try to sell you a bill of goods. Never hire a company that does it for less than $50 per cleaning as they will try to sell you something you don't need or even sabatage your system (I've seen it all living in Florida) as it costs about that much just to put the truck on the road.
Posted on May 06, 2009
localwonder
  • 6784 Answers
SOURCE: Compressor of the Ruud A/C outside unit is making unusal loud continuous noise
OK, you will need to replace this compressor. the internal seals have ruptured, causing the loud noises. the heat is from the metal to metal friction. the compressor can be rebuilt but, it will be more costly than just replacing it with a new compressor.
Posted on May 27, 2009
2008 toyota avalon sunroof when tilt open or slide open make a popping noise feels like is stuck
could be the seal sticking or the cog on the motor is slipping. could mean the mechanism is stiff and needs freeing up ie re greasing and the cog replacing as they made out of plastic.
Mar 23, 2018 | Toyota Cars & Trucks
Why does my mx 650 chain keep making a grinding noise then fall of
It sounds like it could have a chain link that is binding and causing the noise and then coming off the sprocket, try removing it and inspecting the chain link by link until you find one that is bound or damaged. You can try greasing/oiling it and moving it to regain movement from the link. But the best bet is to discard the chain and purchase a new one. Also check your sprockets for correct alignment and damage.
Feb 22, 2017 | Cars & Trucks
WEN 6014: Motor is running, but chain doesn't move. Chain sprocket seems fine, cogs are only slightly worn, sprocket fits perfectly, no wear. Is there an internal clutch or connector? Motor worn out?
There is a clutch behind the metal housing where the chain sprocket at the engine end attaches to the chain . There are wear parts with springs on them that have to be changed. ChainSaw Shed Chain Saw Parts for Wen Wagner Brand Chain Saws Chains Bars... You can get parts here.
Sep 15, 2016 | Garden
Does Anyone have a Service Manual for a McCulloch M2B 12" Chainsaw. I have stripped it and require Parts/Specs and Oil and Grease Viscosity etc before I re-assemble it. Thanks in Advance Cassandra
The only real setting is the carburetor jets. Typically screw them all the way in and then turn it back out 1 revolution. That is referred to as "bench setting" you may have to fine tune it when you get it running. The moving parts can be greased with Lubraplate or just about any wheel bearing type grease. In most cases you don't want a lot of grease on a chain saw because it will collect wood shavings and plug things up. The air filter should be soaked with air filter oil. A lot of people think they go in dry but that is not so. You can get air filter oil at your auto parts store.
Dec 19, 2014 | McCulloch Garden
Grease used for StairMaster 4400CL to fix grinding sounds
There are several types of grease that can be used for this machine. You can use a lithium grease on the hub and a 30 WT motor oil on the chains.
Super Lube with Teflon 16 Oz Jar SPORTSMITH net
Jan 15, 2012 | Stairmaster 4400CL Freeclimber...
General diy servicing Is there a chain that requires lubricating on the Sovereign Deluxe scooter?
No. The motor turns cogs 'directly' in the transaxle which would have been filled with either grease or oil at the factory and should never need touching unless it breaks.
Jul 18, 2010 | Pride New Mobility Legend 4 Wheel Scooter
My washer has started making a high-pitched noise while spinning.
Hi
to chek what is wrong follow the bellow instruction....
Check the motor bearings
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer.
Check for Obstructions
Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket.
Check for Grease Spatter
A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing.
Check the Drum for Irregularities
Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Thanks for contacting fixya.com
Nov 13, 2009 | Kenmore Washing Machines
Clicking noise on door hinge
there is a plastic piece that slides in the center of the door hing if you look close it will be broke or cracked in half. That is what is causing the noise.
Aug 13, 2009 | 2000 Jeep Grand Cherokee
Clicking sound - door doesn't open or close
Turn off the breaker for the unit. Set up a good ladder, change the bulb. Release the opener from the door,turn the breaker on, and try the opener while it is disconnected from the door. If it works, give the chain a good spray of wd40, followed by a good spray of chain lube or spray grease. Operate the motor back and forth, spray grease wherever the chain attachment rides the bar. Once it is working good and free, try to connect it to the door and test it. If it has a problem, check your door rollers and hardware.
May 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not open or close
I had the same problem, mine was just the white Sprocket assembly, it stands straight up, there is another one which is the Worm gear, mine was fine. I read on some other post, when you take off the panel, and if you see a lot of white dust (shredded white plastic) then its the gear. Went to Sears warehouse, had the part in stock and replaced it myself. Had to just unbolt the Sprocket assembly from inside (3 bolts), pull out from the top, a little hassel, but got it done. Follow the instructions and you will be fine. Remember after greasing up the sprocket like it says too, take the time to use some silcone spray on the springs and rollers, a lot of people forget to do this, even me...
Dec 20, 2008 | Sears Craftsman LiftMaster Chamberlain...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
