Trio stelth won't charge has a battery warning
3 Suggested Answers
ka4iup
  • 3957 Answers
SOURCE: how do I reset my trio stelth G4 7.85
Have you tried using the reset button on the tablet? Manual can be found here: http://www.manualslib.com/manual/749979/Trio-Stealth-G4.html
Posted on Feb 05, 2015
ka4iup
  • 3957 Answers
SOURCE: How do I reset trio stelth G4 7.85 tablet it wont turn on
Youcanresetthetabletbypressingtheresetbuttonlocatedinsidetheresethole.
How do I reset my trio stelth G4 7.85
Feb 05, 2015 | Tablets & eReaders
Charge trio g2
Hi Jennifer,
Battery error or charger error.try with new charger or usb cable.
if you have warranty you have no problem and go for warranty.
regards.
nuwan
Jan 10, 2014 | Mach Speed Trio Tablets & eReaders
My Trio Stealth Pro 7 in. Internet Tablet will not connect to my wi-fi.
I HAVE AN TRIO STELTH PRO.I AM ON RR INTERNET.I CANNOT CONNECT TO INTERNET NOR WI-FI AT HOME BUT I CAN TAKE IT TO MY DAUGHTERS & IT WORKS FINE.ALSO MY LAO TOP WORKS OK ON MY WI-FI.IT IS BLOWING MY MIND.THANKS TROY PRUITT
Jan 30, 2013 | Mach Speed Trio 4GB 7" Trio Stealth Pro
My eclipse cld 4gb mp3player wont hold a charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 17, 2012 | Mach Speed Trio Eclipse 4GB CLD MP3 Purple...
My onxy mp3 player won't charge despite being plugged into my USB port for hours
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 13, 2011 | Mach Speed TRIO Onyx MP3 Player
When I start my 1995 sls the "Battery No Charge" warning comes on the dash. After driving for while the light will go out and the display will say Battery charging. But the display also says...
You need 13.8 to 14.5 volts for proper charge. I suggest that you pull the alternator and get it bench tested. There is a diode trio that controls the regulator, and when a diode fails, issues like what you describe, happen.
Feb 25, 2011 | 1995 Cadillac Seville
'alternator Workshop!' warning along with the battery light keep popping up. The battery is good and the alternator seems to be working correctly. What else can this be?
If the voltage regulator is charging too high or too low or one or more of the diodes in the diode trio are burnt out and not functioning, the battery or alternator light will pop up.
This indicates that the charging system has something amiss, unfortunately.
Jun 26, 2010 | 2002 Volkswagen Passat
19 people viewed this question
 Grubhead
Grubhead
