Question about Polaroid Televison & Video
Where are fuses located on flat screen tv #flm2632 model 2700 Polaroid only found one next to power cord
  • Polaroid Master
  • 6,694 Answers
There would be only on fuse in power supply
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Jan 01, 2017
albertv29
  • 87 Answers
SOURCE: polaroid 2700 hdtv power supply
The only place I have been able to find the power supply or main board for this is shopjimmy.com or Ebay but even there I can find none.Tell your husband to check for puffy capacitors in the power supply.This is a very common problem with these power supplys.
Posted on Jan 15, 2009
racer7x
  • 42 Answers
SOURCE: Philips 47PFL7422 Flat Screen no power
Check the main fuse
If that is ok look for puffed up capacitors on the power supply
Check the 1000ufd @ 35v change them to 1000uf @ 50volts
Good luck
Posted on Feb 08, 2009
SOURCE: The power cord for my Hyundai E320 flat screen tv
Start by confirming the circuit is hot at the wall. Plug in a lamp or something.
Try your generic cord with another device to eliminate it as a variable.
What sort of cord is it?
Posted on Mar 02, 2009
  • 11 Answers
SOURCE: Missing Power Cord, Stand Base, Owner's Manual for Element 15" TV
The manfacturer has information for you about this model when purchased from Circuit City: http://www.elementelectronics.com/support2.html
The distributor Element uses provides parts at http://www.encompassparts.com/
(you may have to have a legitimate repair center login in and get parts from them)
Posted on Mar 30, 2009
  • 11 Answers
SOURCE: missing power cord 12v
go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
Posted on Jul 03, 2009
Where is fuse located at on flat screen tv model# flm2632
sorry but picture is not good enough to see any
Dec 29, 2016 | Televison & Video
Where is fuse located at model #flm2632
what is model flm2632 cars and trucks have many fuses .
Dec 29, 2016 | Cars & Trucks
Polaroid TLA-01511C stopped working after electrical storm. Will try to change fuse, if I can get to it. How do I access the fuse? NOT equipped mentally or with tools to do more.
Contact any service technician. The fuse can be located at itw main power regulator board inside. If the power supply regulator board is found faulty, it will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
Aug 07, 2014 | Polaroid TLA-01511C 15 in. LCD Television
Polaroid 3700 lcd
GOT SAME PROBLEM NOW IS THERE A FUSE WHERE POWER CORD PLUGS INTO THE SET ON THE BACK MINE HAS A GLASS FUSE NEXT TO THE PRONGS THAT COME FROM TV YOU HAVE TO USE A SCREW DRIVER TO POP IT OUT SHOWS A PIC OF IT IF YOU DON'T SEE IT DON'T TRY TO POP IT OUT
Feb 24, 2013 | Polaroid FLM-3732 Television
I have a 46" Flat Screen TV. Model Number
First thing you do is to check the outlet if there is a power output the check the power cord and plug.If there 's a power in the power cord,Check the fuse of your television.The fuse is located at the power supply.You can see the power supply when you open the back cover of your television at the upper right side.Replace the fuse if busted with the same value of fuse.That's the step you can do first..Thanks..
Aug 25, 2011 | Televison & Video
I have taken the back of the polaroid tla-04011c tv and can not find the fuse? The tv is not getting any power and I am starting at the fuse, but cannot locate it. Any help would be appreicated. Thanks!
Remove the power cable from the back. With the 3 silver prongs exposed you should be able to see that the same black plastic receptical that houses the power cord, also houses the fuse (on the left side). You will need a small flat tip screwdriver to open the fuse compartment. Good luck!
Jan 10, 2011 | Polaroid TLA-04011C 40 in. LCD TV
Polaroid tv 2700 dead
I have to tell you that I'm finding that this is about the life expectancy of the first generation LCD TV's. It could be fixed/repaired for between $100 to $200 at a good TV Service Shop.
You may just want to put that money into another TV!
Blessings,
A/V Media Tech Guy
Sep 22, 2009 | Polaroid FLM-2632 Television
SCREEN doesn't turn on when powered up
it's the power board (transformer). Buy on ebay for 99.00 and replace.
Jul 03, 2009 | Polaroid Televison & Video
Polaroid 2700 hdtv power supply
Jan 15, 2009 | Polaroid FLM-2632 Television
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
