Middleby marshal ps350 will not fire up, no polite light. Have gas going to has valve but no polite light?
SOURCE: marshall control valve . gas regulator valve
I went to Lowe's and bought a replacement regulator (I am not at home so I can not cite the model number - but drop me a note if you need it) and using the adapter off the original regulator, it works like new.
dmanuel (see above)
Posted on Feb 06, 2009
SOURCE: Middleby Marshall PS360 pizza oven won't maintain HEAT
I have a middleby marshall ps570 oven. The conveyor belt is moving too fast, I already try adjusting the timer control but it does not do any-good. I open the access panel I turn on the oven and started to work fine as soon as i close the panel it does it again the conveyor speeds up, Any body know what could be wrong.
Posted on Nov 30, 2009
  • 4 Answers
SOURCE: I have a Middleby Marshall Pizza Oven.igniter
Need a qualified person to check gas control valve to determine proper voltage to the valve is supplied. If voltage is present, either the gas line is blocked to the pilot, or the valve has failed and needs to be replaced. Typically, the latter is probably the problem. If NO voltage is present when the unit "calls" for ignition, check for loose conections at the ignition control, and the gas control.
Posted on Jul 21, 2010
MBramhall
SOURCE: Middleby Marshall 360 pizza conveyor
Is it the rear of the oven or the left side?
  • Rear of the oven, it is a obstructed or malfunctioning axial fan. Replacement cost $10-$20 - 30 minutes labor
  • Left side of oven, possible main blower fan malfunctioning. Depending on type of motor "S" or "Q". It might be the mount or a bearing wearing out. Replacement motor $200-$400, motor shop rebuild instead $150. Squirrel cage will need to be removed if damaged $100-$300. Labor 2 hours, if you know what you are doing, 4 to 6 if this is your first time. Check your heat slinger also. This might have come loose.
Call me for parts or further info. I have been here before.......
Marcus Bramhall
Shimmmer LLC
318.202.2022
206.769.4466
Posted on Feb 18, 2011
KevinWhite
  • 1902 Answers
SOURCE: I have a middleby marshall
Hello & Welcome to FixYa
The first thing you will have to do is to clean the Jet as the carbon might be stopping it to work correctly. Then check if the small holes on the burner are clean, if they are fine then you will have to check the ignition switches under the surface control knobs. Please get back to me if you have any other questions.
Kevin
Posted on Apr 27, 2011
Middleby marshall conveyor motor speed
my conveyor motor is going fast and will not slow down, what is the fix for this?
Feb 02, 2012 | Ovens
I have a 1962 or 63 Wedgewood 30' gas cook top. It has polite lights. Is there any kit to change it over from polite lights to a up to date igniter system?
no there is not the burners wont have anywhere the electrodes could mount to,plus it would need to wired for a spark module and find spark switches for the valves that were never designed to fit those gas burner valves
sorry
Jul 27, 2011 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
I have a Middleby Marshall Pizza Oven.igniter works but seems like no gas coming through ,tried poking a pin in the gas nozzles as we had that problem before where some **** blocked one of the holes but...
Jul 21, 2010 | Ovens
Pilot light keeps going out when turning on oven
Sounds like the GSD. The Gas Safety Device valve needs replacing
Oct 17, 2017 | Ovens
sounds like the control cabinet overheated and the controller starts to break down at 140' F I would replace the controller and keep the cooling fans clean
Aug 06, 2009 | Ovens
My conveyor is not moving on my pizza oven any suggestions?? its a middleby marshall q360
These little motors are controlled by a rheostat for speed control, or electronic speed control. Follow wire from motor to control and check. Also; is chain on?
Jul 06, 2009 | Ovens
No gas to fire up the polite light
there could be a few reasons for this but the first thing I would check would be the Thermal couple. If you do not know what that is I would call a qualified tech to come and replace it . they are easy to replace . It is also possible that the main board has shorted out but I would start with the thermal couple first.
May 16, 2017 | Superior Lennox Blower Thermal Sensor -...
Marshall control valve . gas regulator valve
Replace the regulator as this is typically an issue where the diaphragm has separated from between the body and bonnet. This is not repairable. There is no recall for this as was in the case of the 450 regulator as it is a manufacturing variance that happens with all products. It passed initial QC, but in time the diaphragm moved.
Oct 24, 2007 | Thermos Stainless Steel Gas Grill
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
