Question about Panasonic Lands Phones
On a Panasonic DT343 how do I change the extension for the mailbox number?
TallBourbon
  • 30 Answers
SOURCE: how to chg a norstar mailbox from 'General Delivery' to 'User'
check under the mailbox set up ( where you created it) for that extension that the extension number of that phone is on that mailbox> in other words, you could create mailbox 221, but assign it to 222. The Gen Delivery box is 100 which is the catch all for transfers that cannot be completed.
Posted on Jan 07, 2009
SOURCE: Changing names assigned to extension numbers
I just worked it out.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
Posted on Mar 24, 2009
  • 19 Answers
SOURCE: changing the names fixed to internal extension numbers
If you can not log into the programing tool to change it that way then you will still need the Installer password. However from the main ext typically the first ext or 101
hit the Program soft key just below the LCD
push * then #
password
004
ext number you wish to change
type in new name
ENTER
END
Posted on Apr 14, 2009
cnavarro
  • 2460 Answers
SOURCE: need to change hold music
It depends on where the music source is coming from. A Panasonic TDx system has a port for external music located on the system cabinet. If it's enabled in programming, that's what you hear. If not, you get an internal "tune".
If the music is exterhal, all you have to do is find the box that is playing the music and change the recordings. That's a whole other topic :-)
Carl
Posted on Feb 19, 2011
cnavarro
  • 2460 Answers
SOURCE: how do i change the
From the phone connected to extension 101, press PROG and dial **1234 If the display responds Sys Prog #, then dial 004 and enter. It's the menu to assign names to extensions. You can sort of follow along and use the arrows, the keypad, and the ENTER and SAVE buttons to step through the names and change them.
Carl
Posted on Aug 26, 2011
How can i create extension line on a panasonic KX-DT343 console
Try Googling (Panasonic)(KX-DT343)(manual) without parens for instructions.
Jun 23, 2017 | Panasonic Lands Phones
How to change recording on day/ night mode
This depends what voicemail you have, SVM OR TVM. and you need to know what group rings in each mode SVM day *47 (voicemail extension number) (PIN number) *38801 record STORE NIGHT *47 (voicemail extension number) (PIN number) *38811 record STORE TVM voicemail extension number (500 or 200) #6* (ringing group number) option 3 then 1 then 1 follow the prompts
Aug 12, 2013 | Panasonic BTS KX-DT343-W-NR Digital Corded...
How do i set ring on Flexible Buttons.....
Perhaps you are trying to set up speed dialing.
Right?
Jul 22, 2013 | Panasonic KX-DT343 White 24 Button 3-Line...
I need to know how to access the general mailbox on the Panasonic KX-T7633 to change the message received when calling in after hours.
the general mailbox can be any mailbox from 100-998... or if you have 4 digit extension numbers, 1000-9998...or it can be one of a couple hundred other greetings if you are talking about custom service menus instead of a mailbox (all this is best determined by your local panasonic dealer/serviceman)
once you know which mailbox is your general mailbox:
1) call the voicemail
2) press "#6*" + the mailbox number
3) enter password then "#"
4) press options "3" then "1" then "1"
5) record your greeting then press "1" to stop the recording then "2" to save it
6) hang up
Jan 07, 2011 | Panasonic KX-T7633 Corded Phone
Hi there, my business uses Panasonic KX-T7431 Digital Super Hybrid System and we have several lines. when nobody is available to take the call it goes directly to a company message stating are names...
The introduction message is usually setup as a custom service menu. You need to determine if this is the case by logging into the message managers mailbox and listening to find the current greeting. To log into the message manager mailbox, call voicemail, dial #6 then *98(for 2 digit mailboxes) or *998(for 3 digit mailboxes) or *9998(for 4 digit mailboxes), enter password followed by #. Once in the message managers mailbox, press 5 to record messages. Your introduction message could be the company greeting or a custom service menu. Press 1 for the company greeting and follow the prompts to listen to the greeting. Press 3 for the custom service menu, then enter the custom service number 1-100( in your case start with 1 until you find the current introduction message) and follow the prompts to listen to the message. Once you have found the current introduction message record your new message and save.
Dec 28, 2010 | Panasonic KX-T7431 Corded Phone
I need to change the name that is said when someone dials an extension. For example, if I call the main number then dial an extension, I hear "Transfering you to 'blah blah'". I want to change...
The recording of the name you hear announced during the transfer is the recording that the particular mailbox owner has recorded. If that mailbox owner has not recorded a name then you will hear a system prompt of the extension number. Access that mailbox as the owner and you can record a new name for the mailbox. This is easiest if done from that mailbox owners phone, you will need the password for the mailbox if password protection is enabled. Once in the mailbox it will play any new messages then follow the prompts to get to user options.
Dec 10, 2010 | Panasonic KX-T7630 Corded Phone
Need to change password on voicemail extension on
If it's a Panasonic brand voice mail, you administer the system from the System Owner's mailbox (999). With that, you can use option 4 or 5 and reset the mailbox password to any and all mailboxes (except 999 :-)
Carl
Sep 03, 2010 | Panasonic KX-T7420 Corded Phone
How to set up password for voicemail/how to set up new mailbox
By default, a Panasonic TVA voice mail system can have a password set. It could be 3 plus the extension number, but it doesn't matter. You can clear it by logging into mailbox 999 and going to options 6 1 3 which will be the mailbox password menu. Select the lady's extension and follow the instructions to confirm password deletion.
Now she can call voice mail from her extension and set a new password.
This also works for a TVS system.
Carl
Sep 17, 2008 | Panasonic KX-T7731 Corded Phone
Lands Phones Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
