Question about Panasonic Televison & Video
I have a Panasonic Dimension 74 TV with a burnt resistor R838 can someone tell me its value
It i s located on the Power Supply board
the dr
  • 447 Answers
SOURCE: Maytag Neptune m/n MAH3000AWW burnt R11 resistor
STOP
There is a short in the door lock (very, very common problem )
Go to ebay and search neptune washers and im sure youll find a site i was selling a kit to repair this. If you cant find it let me know ill look .
Posted on Jan 18, 2008
Slinteriors
  • 8617 Answers
SOURCE: need resistor value for RK62 on DP2X board for 57SWX20B
RK62 is a 2.2ohm 1 watt metal oxide resistor hitachi part number 0700054M any 2.2ohm 1 watt resistor will work although it does have to be metal oxide(flame resistant) for safety purposes.
Posted on Mar 24, 2008
easyab
  • 132 Answers
SOURCE: TV set shuts down
3.9 ohm 2W
They are parallel in circuit and measure around 2 ohms when ok. Check the fuse associated with that circuit. FD101S 3.5 A
easyab
Posted on Aug 24, 2008
SOURCE: burnt out resistor
I'm in the same fix. I learnt that a new pcb is £68 so had the pcb repaired but after the machine has warmed up it now cuts in and out. Like you, I haven't been able to locate a wiring diagram so am trying a last minute lash-up before binning the machine:
A friend suggested that since we all seem to only operate the cleaner on full power I should connect the on/off switch direct to the motor bypassing the rheostat and the pcb as in old fashioned machines.
Posted on Jul 07, 2009
gessneruk
  • 22 Answers
SOURCE: 37"scott lcd tv power supply
We repaired ours for about $5. We have a page with pictures showing the compnents replaced.
Hope it helps!
http://www.findonefindall.com/toyota-sienna/LCT37SHA_Scott_Akai_LG_LCD_tv.htm
Posted on Sep 02, 2009
What is the R4 resistor value on the MEGMEET MLT668TL-VM POWER SUPPLY BOARD OF AN E-HOME LCD TV?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 21, 2016 | Televison & Video
Panasonic tc-21v50p, anybody knows the value of resistor located @ regulated power supply r833 its burn cannot read the value. It is also have resistor parallel connected to this resistor
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams to many popular brand TV SMPS are given. You can figure it out there.
Oct 07, 2015 | Panasonic Televison & Video
Samsung home-theater model no# HT-E330K, power supply resistor RA805 completely burnt can't see the value of the resistor. Pls help with the value of the resistor
This may sound like a lazy answer but without a schematic, its going to be tough. Perhaps you know someone...or maybe there is someone here who has the same unit who wouldn't mind opening it up to get the value. Good luck.
Oct 08, 2013 | Audio Players & Recorders
Hilti TE-5 burnt resistor value
Hilti should be able to supply that information.
Jul 24, 2012 | Drills
When turn on ht-tz212 it shows protect and turnes off again
I the same problem. When I opened the system up I find that I have a burnt out resistor on the power supply board. Can anyone tell me the value of Resistor number SWR60, which is located fairly central on the board.
Many Thanks
Dec 19, 2008 | Audio Players & Recorders
Panasonic COLOR CT-27G14A
check Vertical IC out (LA78..) and resistor voltage supply from flyback transformer to this ic. Check the STR main power supply(and resistor near, change value), some times seems good out main board,but in operation not good
May 18, 2008 | Televison & Video
Magnavox resistor problem
The CRT board is the one that connects to the back of the CRT.
Follow the 200VDC line to locate the burnt resistor, is normally a low value fuse resistor.
Apr 15, 2008 | Philips Magnavox 27MS343S 27" TV
Panasonic PT-47WX51CE convergence
the value of r7050 is 2.2 ohm 2W
i might be able to email the manual but its big - just let me know and i will send it or look up anothe part # for you
thanks
scott
Sep 29, 2007 | Panasonic PT-47WX51 47" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
