Question about Kitchen Ranges
How do you get the yellow plunger for the natural gas regulator
4 Suggested Answers
  • 531 Answers
SOURCE: setting the regulater from propane to natural gas
check your manual or check inside regulator valve you see lpg and ng turn it to ng
Posted on Apr 07, 2009
heatman101
  • 43501 Answers
SOURCE: Natural gas regulator
No.. the gas pressure that is run out to the grill should be low pressure allready...just hook it in leak test it and you are good to go....
My grill sits right by my meter about six feet away... I tee'd off at the meter installed a valve and then run right into the grill....works great!!
heatman101
Posted on May 29, 2010
SOURCE: GE Monogram cooktop ZGU385NSMSS (natural gas) without pressure regulator?
I have the same question, so any help would be appreciated. Mine came from a "scratch and dent" store without the regulator.
Posted on Dec 02, 2011
Why is it no matter which way I adjust the oven's spud orifice, the burner flame stays large, yellow and sooty even after adjusting the air shutter?
Possible problem with the gas regulator allowing too much gas through the system. On LP systems the regulator should be on the storage tank. The regulator on the range usually has a changeable cap and plunger. One direction is for LP and the other direction is NAT gas. In the LP position, the plunger actually holds the range regulator wide open letting the one on the storage tank do the job.
May 02, 2015 | Kitchen Ranges
Replaced gas valve on oven. can't seem to adjust flame. Baffle wide open. large yellow flames. How can I tell if this valve is for Nat. gas. I have prop.
Too much gas or to little air or both with orange flame.
Check to make sure all pipes and airways after regulator are clear.
If you are sure air mix is max than you need to check how much pressure is going in and coming out of gas valve there is typically a port on valve to do so. You need a manometer to do this. In a pinch you can make one check internet..
For propane you should be getting 9 to 11 inches water column depending on BTU of oven.
Typically natural gas controller/regulator is less 4 inches wc in which flame would be very small if it was set up for propane and you installed natural gas regulator.
Jan 14, 2015 | Eaton Nc-1425-5a Gas Valve
Clean corroded thermastat
What is a thermostat plunger?
If anything is corroded, Thermister or Temp Sensor, just replace them.
Nov 15, 2014 | Pentair Master Temp 400K BTU Natural Gas...
I have 2Psi inlet pressure so if I don't use regulator pilot is working but huge flam. But when I put regulator in (3
Hi there.
Your maxitrol regulator specification is correct for natural gas use, the pressusre setting may be in minimum (3"wc) that's why the fryer does not fire-up or it may also be clogged.
Check also if the spring is sitting properly on top of the plunger.
Regards.
Jun 24, 2012 | Frymaster Dean SR42G Deep Fryer
Oct 28, 2011 | Cooktops
Converting it back to Natural Gas what I sdone to convert oven area
Usually the oven has an adjustable orifice. For natural gas you want to turn the brass orifice counter clockwise ( out ) to increase the gas flow. Start with a few turns and keep testing till flame is high enough. NO Yellow in the flame..... that is too much gas. The orifice takes a 1/2" wrench. Also make sure the appliance regulator is set for natural.
Tom
Aug 11, 2010 | Tappan TGF351ES Range
Converting whirlpool LGR3624EQ2 back to natural gas
Hi, There should be a cap on top of the regulator that willneed to either be flipped over or there is a plunger iside the cap that will need to be reversed. The orfice on the gas valve will need to be changed as well.
If I can assist you further, please let me know.
Vic
Jul 12, 2009 | Whirlpool Dryers
Natural gas orifice burners
Before you get too involved, check to see if the natural gas orifices are still with the range. Usually, when the conversion is done, the person who converts the range puts the original natural gas orifices into the holder which contained the LP ones, then replaces it. Look for an inch and a half long metal strip holding the four brass orifices held on by one screw very near the range gas regulator. (the regulator is the part the gas line connects to on the range) Also, look for the conversion instructions in the original installation and set up instructions, or attached to a sheet of paper on the back of the range. You will need to change the plunger in the regulator (Unscrew the cap, flip the plunger around, and replace) and turn the orifice spud on the bake and broiler burners three full turns counter-clockwise also. (using a 1/2 inch open end wrench, counting twelve 1/4 turns) Orifices will require a 7mm or 9/32 inch nut driver or socket to change. The orifices are different for the simmer, regular, and high output burners. (have a "I", "II" and "III" marked on them to help identify them, respectively.) The left two burners are both "regular output" burners, and use the same orifices.
Apr 20, 2009 | GE Kitchen Ranges
Natural gas to propane
GE is one company which generally includes all necessary parts and instructions for conversion to LP with the range without having to order or purchase anything extra. Check the mini manual in the white envelope pasted to the back of the range for instructions. Generally, the LP orifices are in a metal holder near the gas regulator (right where the gas connects to the range). You will have to flip the plunger in the center of the regulator and turn down the collar (with a 1/2 inch open end wrench) on the oven burner and broil burner about 3 full turns. Air shutters are usually OK without any adjustments.
Sep 17, 2008 | Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
