Question about Hard Computers & Internet
MY pogoplug does not see my hard drive. WhY?
I have verified that the drives are ok by direct connection to my CPU USB ports. I can see the drives. The Pogoplug device is on line with a green indicator light. How do I fix this?
    Problem Solver:
  • 10 Answers
My apologies, but why don't you contact pogoplug?
  • 19396 Answers
SOURCE: Western Digital External Hard Drive SN WCAMR4295471
If you are using a pre-Windows xp system you may need to install specific drivers for your HD. If you run xp or Vista Try disconnecting completely the power cable from your computer for five minutes and then plug it back to the power and restart it. I know it sounds weird, but sometimes usb mass storage devices suffer troubles caused by electrostatic charges.
Posted on Feb 14, 2008
  • 202 Answers
SOURCE: External Hard Drive -- too much power for my USB port on my computer
Hi mhjohn
First, this is actually a good thing in a way. The reason is, it is actually telling you right up front that your USB bus is underpowered for this device. That's a huge improvement over issues caused by underpowered USB buses in the previous model computers. In those, we were left to having to figure out what the problem was when a USB device inexplicably stopped or didn't work.
What is happening is, your new external hard disk drive (HDD) is trying to run off of power taken from your laptop's USB "bus" (circuitry). This is OK for devices needing low power. But in the case of external hard disks, it's "iffy" whether there'll be enough power on the USB bus to support them. Particularly on laptop computers.
You need only attach an A/C adapter to your external hard disk drive (HDD) and you should be OK. If that is not an option, connect a **powered** USB hub to your laptop and plug the external HDD to the hub instead.
By "powered" I mean a USB hub that comes w/ an A/C adapter. In either case, using a powered USB hub or attaching an A/C adapter to your hard disk drive will remove the external hard disk's power load from your laptop's USB bus and provide sufficient power for the HDD to run.
You can find USB hubs at and lots of other online high tech stores. I like Newegg because their prices are competitive, their customer service is excellent and there're customer reviews of most of their products there as well.
If you have any more questions, comments, observations - anything at all, just let us know. We're here to help.
Thank you,
BJ @:)
Posted on Apr 15, 2008
Had the same problem...tried everything with no results. In desperation, I grabbed a different USB cord, plugged it into the drive and the laptop and VIOLA! my laptop could see it again! Maybe this will help someone. Cheers!
Posted on Apr 06, 2009
SOURCE: Fantom Drive TFDU16072A Error
2009 06 30 - I just had a similar problem. The Fantom external drive was working fine, but I had to shut down due to a thunderstorm. When I restarted the PC, the drive was not showing up. WHAT I FOUND: First, I didn't find this solution anywhere - everything seemed to point to a new install (or at least how to reformat and start over.) BUT, I right clicked on Computer, Manage, Disk Management - it still didn't show. On the right, under More Actions, I clicked 'rescan disks'. Now it shows up! And all of my data is right there. Whew!
Posted on Jul 01, 2009
  • 65 Answers
SOURCE: flashing power light.
Have you tried a differnt usb cable if that dos not do it get back with me and I will walk you though checking it out
Posted on Jan 09, 2010
How connect ext mass storage Seagate FreeAgent GoFlex Net to LAN through router by TCP/IP
Here is the link to the pdf for your Go flex.
This is an excerpt from the file concerning NOT using the pogoplug...
Accessing GoFlex Net Without Using the Pogoplug Service (Windows)
You can access the drives connected to GoFlex Net without using the Pogoplug Web
interface. Follow these steps to set up local network access.
1. On the Windows taskbar, click Start > Network or right-click My Network Places >
An Explorer window opens showing all computers on your network.
2. Locate and then double-click the computer name associated with GoFlex Net.
NOTE: Your GoFlex Net name starts with the letters "FADS" followed by the last six
alphanumeric characters of its MAC address. This 12 digit address, preceded by "MAC:",
is printed on the label on the bottom of GoFlex Net.
You can now access each drive connected to GoFlex Net. Access is regulated by the file
sharing permissions you set using the Pogoplug service.
Hope this helps...
Nov 01, 2012 | Seagate FreeAgentĀ® GoFlex? Black 1TB...
My hard drive is not visiable in system
Ok try to plug it to the USB port at the back of your CPU usually USB port at the back of the CPU supply sufficient power to the device that was plugged in that port so it functions properly cause a USB device plugged to a USB port w/ low or insufficient power supply in that device may cause the device not to work properly that's the reason why your portable HDD wasn't recognize by your system..
Jul 08, 2011 | Transcend INFORMATION : 320GB 2.5 inch...
Instal in XP
Hello, This external hard drive does not need a driver, even in XP. If you're using a desktop, don't connect it to the usb ports in front of your CPU case, instead, connect the usb at the back USB ports, if this doesn't work, try using a shorter USB cable and connect it again at the back.
Jun 19, 2011 | Western Digital Elements powered by WD 320...
I have a Lacie mosKeyto 8GB USB Flash Drive. When it it inserted into a PC it just does not show up at all, meaning computers do not detect it. What can I do? thanks
hi have you try connect it to other computer? if is working i guess your usb port have problem try to connect your flash drive to other usb port at the back your cpu. if not working your usb flash drive have problem. thanks
May 28, 2011 | LaCie MosKeyto - USB Flash Drive - 16GB...
Have iMac ejected hard drive so I could remove now computer won't recognise the hard drive
First thing I would do if the drive is connected via a usb hub connect it directly to the imac, then if that does not work try one of the other usb ports. If that does not work connect it to a usb port you know works and then go into the applications folder and then into the utilities forlder and open up disk utility. Once opened your hard drive should appear in the left hand box click on your external hard drive then go to the first aid panel and run verify disk and if any problems appear run repair disk. Hope this helps.
Nov 12, 2010 | Western Digital Elements powered by WD 320...
No cpu will recognize the drive or acknowledge it is connected to the cpu. This problem occurs across all the ports (firewire and usb). The drive lights up and receives power from the cpu and hums and...
make sure that you plugged in the Portable HD to a USB 2.0 port. delete the USB root hub from your device manager and install it again. change your data cable.
Mar 26, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
My hp hd 10000x is not showing up on my computer. my cpu makes the noise letting me know that something is in the usb port but the external never shows up. how can i fix this?
Try connecting the disk-drive to a different computer,
to see if the disk-drive works at all.
If not, then either the USB-to-disk-drive interface inside the casing has failed, or the disk-drive has failed. So, disassemble the casing, remove the disk-drive, and temporarily connect it as a "slave" disk-drive in your desktop computer, to see if the disk-drive itself is OK.
Or, exercise any warranty to get it replaced.
Jan 16, 2010 | Computers & Internet
My flash drive is bent and my computer will not recognize it
try to use the USB port at the back of your CPU direct to the motherboard. do not use the front USB port, try to use also the another port if they are not functioning in other one
Jun 30, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My two front usb ports cant read usb hard drives
Some external USB drives require external power sources. Typically this is done either with an external power supply that connects to the drive or a second USB cable that connects to the drive and a second usb port on the pc. I have even seen one drive that comes with a Y cable. one end goes to the drive and the 2 usb plugs go to the pc.
Dec 12, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
145 people viewed this question
Top Hard Computers & Internet Experts
David Clark
David Clark
john smith
Are you a Hard Computer and Internet Expert? Answer questions, earn points and help others
