Question about Remington Health & Beauty
Remington 5790 trimmer quit working, can i fix it?
Battery not holding charge very long
I've written up a complete step-by-step tutorial on how to replace the battery on a Remington MB-300 Beard trimmer: John Fixes Stuff How to Replace the Batteries in Remington MB 300 Beard...
Apr 06, 2014 | Remington MB-300 Beard Trimmer
Back put together trimmer
I've written up a complete step-by-step tutorial on how to replace the battery on a Remington MB-300 Beard trimmer, which includes how to reassemble it: John Fixes Stuff How to Replace the Batteries in Remington MB 300 Beard...
Dec 09, 2013 | Remington MB-300 Beard Trimmer
Want remington shaver manual f 5790
You can download the user manual for model F5790 at shaveroutlet.com. Use link below and then click on 'User Manaul' near the add to cart button
http://shaveroutlet.com/shavers/foil-shavers/remington-f5790-titanium-pivot-and-flex-triple-foil-shaver-p-819.html
Mar 17, 2013 | Remington Health & Beauty
Remington mb300 battery replace how
The rechargable nickel-cadmium is hard-wired and not replaceable.
Instructions for removing the battery from the user manual:
1. Make sure your groomer is unplugged from any outlets so you don't risk an electric shock.
2. Remove side panels/grips
3. Remove the 4 housing screws
4. Pull or gently pry the clipper halves apart, exposing the batteries.
5. Remove batteries from the unit.
6. Twist batteries to break wires. Wires may also be cut.
I also own an MB-300. The battery still works good and I loved this trimmer but I need a new cutter blade for mine.
Jan 01, 2013 | Remington MB-300 Beard Trimmer
The foil of my 5790 razor is damaged. How to I remove the damaged foil?
remington SP390 replacment blades and screen foil for remington f5790 heads replacement parts.
Aug 22, 2011 | Remington Health & Beauty
Pop up trimmer stopped working Remington R830
Make sure you are using the trimmer with the shaving heads on the shaver. With heads removed, the trimmer on the back will not work properly. If thats not the problem, the trimmer is broken or jammed. clen the blades really well with a toothbrush and rubbing alcohol. If they're jammed, this will probably free them up. If that doesnt do it, the trimmer is probably broken and that part is no longer available from Remington. If you really like this model, you can find a replacement at shaveroutlet.com
Jan 10, 2010 | Remington Health & Beauty
Trimmer Broke
Call this number; 1-800-736-4648 Or go to this link; http://www.remington-products.com/consumer/contact.htm Hope this helps :)
Apr 04, 2007 | Remington NEDH-2500 Nasal/Ear Trimmer
Health & Beauty Logo
57 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
