Samsung NP R70 Laptop won't charge
My laptop is 17 months old and I cannot use it as I can't get it to charge, I think it could be the charing circuit as I thought I should I be able to use it if it is plugged in the mains without the battery fitted, do you know if this is correct?
The charger has been tested and it's not that, Samsung say it's either the battery or charging circuit, which isn't a surprising answer and not helpful.
Thanks
  • elainesr Jul 21, 2009
    Hi I live in the UK and purchased the laptop through Additions Direct, both Samsung and Additions have responded 'that I didn't purchase the extended guarantee so they can't help'. I didn't buy this as was over 50% of the cost of the laptop and did not expect something of this cost to breakdown so quickly.
    Regards
    Elaine
  • clive pearson
    clive pearson May 11, 2010
    Hi I am Vortash firstly disregarding the fault the guarantee period of this unit may be what you need to address .. firstly can you tell me what country you live in and from what retailer you purchased your Laptop . A lot of manufactures try to get away with it but you have rights under consumer agreements in many countries that they have to abide to and this sounds like one of them .. regards Vortash ..
  • 32,281 Answers
Most laptops will work with or without the battery and with the power adapter connected.
If the power adapter is OK, just connect it to the laptop's power socket and wriggle this plug. Does the charging LED flash as you wriggle this plug? If so the power socket may have a dry solder joint or it may be faulty. Either way the laptop needs to be dismantled to solder or replace the power socket.
Posted on Jul 21, 2009
How do you remove or reset the bios password?
i don't think its possible on laptops, unless you can get to the bios battery remove a re-install - this may remove it - but i think its stored on the main board - if not i think it need to be return to the samsung with proof of ownership, and they will charge for this too,
Apr 13, 2015 | Samsung Np-qx411 Laptop Silver Lcd Cover...
Flashing orange laptop light on samsung laptop
If your battery is six years old, it has done very well and you have looked after it. I would think that a new charger will fix your problem.
Dec 21, 2013 | Samsung R519-53S Notebook
I have a samsung r710 laptop which i have had for a few years. I started to have problems with the battery charge not lasting long which got worse until it wouldn't charge at all. The battery went to...
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Samsung NP-R710 AC Adapter 60Watt 19V 3.15A
Replacement Samsung NP-R710 AC Adapter 90Watt 19V 4.74A
Nov 13, 2012 | Computers & Internet
My Samsung NP-R540 has a loose charging port. Not sure how I should go about getting this fixed; any advice is appreciated. Also, my warranty expired not even a month ago. :(
The port was pulled, tugged, yanked, by the cord? You could open the laptop and try to repair the damage if you have the tools and expertise. Other wise I would contact Samsung or a qualified repair person.
Nov 03, 2012 | Computers & Internet
Plugged in, not working
The battery is 2 years old and beyond it service life. You need a new battery.
Apr 21, 2012 | Samsung Np-r530 Np-r530-ja05us R530 Laptop...
My Samsung N145 Battery does not power the notebook
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 27, 2012 | Samsung NP-N145-JP02US NETBOOK
I have Samsung NP-R505H laptop. My laptop won't
You say it isn't charging, but will it run off of AC power? If it isn't getting *ANY* AC power, then it might be the female end of the power jack on the laptop. If it will run on AC, the culprit is likely to be a battery that needs replaced.
May 13, 2011 | Samsung Computers & Internet
Can Samsung Champ connect with Laptop using pc Suite?
i have purchase samsung champ gt-c3303 before 1 monthe. but now this phich automatically goes swiched off and not taking charing, when i chared the battry hardly than it swiched off but on the screen it only showing 'connecting to pc'
please give me the solution as soon as possible
Aug 16, 2010 | Cell Phones
Computers & Internet Logo
921 people viewed this question
David Payne
David Payne
