Question about Cell Phones
I set up wifi on printer but not it does print via lan how do I delete the wifi settings?
Model 6120 MFC
  • Ali Asghar Khambati
    Ali Asghar Khambati Dec 29, 2016
    Hi John Richardson, I want to help you with your question, but I need more information from you. Can you please add details about printer and how are u trying to print in the comment box?
Mix-it-up
  • 832 Answers
SOURCE: MFC 845CW Not Printing Via Wifi
have a look around here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=mfc845cw_us&Cat=8
Posted on Dec 28, 2007
serra_baby
  • 144 Answers
SOURCE: wifi connection
hello
1. what is the model number of your adapter?
2. what is the operating system of your computer?
3. did you install the wireless adapter on your pc or is it a built in wireless adapter?
-- if you install another wireless adapter on your pc, possible that its the one causing the conflict between the two utility. I suggest to disable the other adapter before installing the other wireless adapter
-- if the wireless adapter is a built in wireless adapter and you are using a windows xp computer, chances are that the built in utility and the xp wzc are the one causing the problem. you have to disable one of this utility to make your connection working
-- the utility is sometimes located at your system. if you wish to use the utility you have to disable the wzx or the other way around.
Posted on May 02, 2008
  • 32 Answers
SOURCE: Netgear FWG114P Print Sever not functioning on upper level of LAN
if you set your dynalink's dhcp list up to a certain number (example: .1-.99). connect cat5 cable from dynalink lan port, into print server lan port. make sure print server can be setup as access point. if so, turn access point setting to on. make print server static ip address the next number outside of dhcp range (example: .100).
.100 ip address is the port number you should then be printing to, using a tcp/ip port.
if print server can be set up this way, then it now becomes wireless access point for all wireless devices. i am assuming, since you didn't mention it, that the dynalink is NOT wireless. if it is, the the print server just becomes another device on your existig network, taking the place of the network adapter the printer doesn't have. just set it up the same way you would set up another workstation on the network. except, make it static.
Posted on Apr 02, 2009
  • 10 Answers
SOURCE: canon mp620 not connecting to my wifi laptop
This could happen if the port that you are using is not the right one.
When you are using a printer wireless, you need to use the Standard TCP/IP port, to setup a printer port, do the following
Right click on printer icon, select properties
Click on Add port, select new port
Enter the IP address of the printer, this can be obtained by printing the settings page from the printer.
Note: please setup a static IP for your printer, else everytime you restart you may endup with a new IP
Let me know if this works,
Posted on Jul 29, 2009
  • 1684 Answers
SOURCE: HP 3055 how do i pdf a document to email? set up
This unit will not scan to PDF and email without sending it to the PC and then emailing it out. You will have to scan to the PC and then email it out.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 16, 2009
Linux driver
Printing via USB:
  1. Get the samsungmfp- repository.
  2. Install samsungmfp-driver (samsungmfp-data will be installed automatically as a dependency).
  3. Go to Administration > Printing and delete previously created printer device(s).
  4. Connect printer via USB.
  5. Once new device has been created, go to Properties and change the Make and Model to Samsung SCX 4521F All-In-One.
For wireless printing:
  1. Connect to your printer. To get the IP address of your printer:
    1. Hold down on the printer power button for about 5 seconds; light will start to flash and when it begins to flash even faster let it go. This will print out the Configuration and Network Report.
    2. Locate the IP address on the Network Report and type it into your web browser.
  2. Once you are in the SyncThru Web Service, go to Network Settings and than to Wireless.
  3. Configure your Wireless Setting through the Wizard and follow the setup process (note that if your SSID contains space your network will not be displayed).
  4. Once the printer is connected to your LAN go to printer setting (Administration > Printing; Properties).
  5. Click the Change button for the Device URI.
  6. Go to Network Printer > Find Network Printer and type in the IP address of your printer.
  7. Apply the settings when it find the PASSTHRU. Device URI should looks something like this: lpd://[IP Address]/PASSTHRU.
Nov 04, 2013 | Samsung SCX 4521F All-In-One Laser Printer
How can i share my brother MFC-7420 printer via windows 7? is it possible?
Any printer can be set up as a shared printer over a LAN network. please click in this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Feb 27, 2011 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-9440CN Laser Printer how do i set
The only real way to make this printer wireless, is to connect its ethernet port to a wireless router and via the router, send jobs to the printer wirelessly. hope this helps. Cost is about $60-$70 for the router.
Apr 03, 2010 | Brother MFC-9440CN Laser Printer
We have 2 Brother printers (mfc-9880 and MFC-8860dn both on a LAN)and have just added a hl-3070cw also on the same LAN. The 2 MFC have always appeared on ''My Network Place'' but the new HL does not and...
You have to setup that printer from all clients as a network printer again... from each client, and print a test page from each too. Sharing must be enabled also, it must be installed with latest drivers, for whichever system.. Just set it up correctly and all will be good.
Mar 02, 2010 | Office Equipment & Supplies
Can't print to a Epson STYLUS SX510W from MacBook Pro OS 10.5 via wifi
First make sure the Wifi light on the printer is lit which will show if the printer is connected wirelessly to the router or not. If not then enter the Network settings on the printer and carry out a Wireless Lan set up using the wizard.If there is now a light Go to Apple Menu > system Preferences > print and fax, Delete the printer that is in the list and then select Add. Select Bonjour and wait for the printer to appear, highlight it and then add it.
Jan 13, 2010 | Epson Office Equipment & Supplies
Dell 5100cn as a netwok printer via my LAN
Connect it to the router. It should hopefully be set to get an ip address from the router. On each computer that you want to print from you need to select Add Printer in the Printers section of Control Panel and select a "Network Printer". You should be able to either browse for it or put the ip address in (depends on the router, printer settings etc). It should then ask you for the drivers etc.
If stuck there is a comprehensive how to on the Dell website.
Nov 20, 2009 | Dell 5100cn Laser Printer
How to install LAN Brother MFC-5840CN on Windows 7 when original CD only has XP driver. Windows Update list specifies MFC-5840CN USB, but machine has option for LAN - is the driver the right one?
You cannot use the full driver and software package now. BUT:
Printing is possible, scanning and FAX is not possible at the moment. You download the Vista driver (x32 or x64) from the official Brother site and install it with the Printer Wizard in Windows 7.
Oct 28, 2009 | Brother MFC-5840CN All-In-One InkJet...
Wifi laptop will not print to printer - not a wifi printer
Check if the printer has a wireless option. Actually this issue is complex. First thing first, you can print wirelessly from your laptop within the WIFI range in a case that your printer do have wireless on in. It is impossible to print wirelessly from the wired printer through LAN.
One thing, I guess you don't have a wireless router. You need to have a wireless router like LINKSYS that is easy to setup then try to connect wirelessly to the wired printer. There I am not too sure if your can do a printing option from your laptop wirelessly.
Lastly, check if you have a ROUTER and need to set it up on your laptop and on the network LAN. You may now have a NETWORK printer in this regards. Thank you.
Oct 06, 2009 | HP Compaq Presario V6000T Notebook
How to connect brother MFC-5440CN to Bt voyager 2091
Connect machine to lan. Run the network drivers. PC should find the mfc.
In case you have to do some settings have a look into the network manual which is a pdf document on installcd.
When questions left go to brother homepage of your country and search your mfc and then the faq for networking answers.
Dec 30, 2007 | Brother MFC-5440CN All-In-One InkJet...
Dec 28, 2007 | Brother MFC-845CW multi-function...
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
