Question about Home
After flushing the tank files and water shuts off, then about a minute or 2 later it re-files, shuts off, then continues this cycle every few minutes?? what's my solution
  • 62 Answers
SOURCE: Water is running every 5 to 10 minutes
You might have a thermal expansion problem or the the valve is bad.
Make sure your pressure in the water system doesn't exceed 80 psi.
Open a faucet just a little bit and let it run. Wait to see if the toilet continues to do the same thing. If it does, replace the Gmax valve. You can use a Fluidmaster 400A. No need to get an expensive Gmax valve.
Posted on Jul 16, 2009
parrotheadpc
  • 2600 Answers
SOURCE: toilet keeps filling tank every 10 minutes
If there is no water on the floor then the water is leaking down the main tank drain. Take off the tank lid, turn off the water supply to the toilet. Fllush as much water out as you can. Look at the main drain, sometimes if the flapper valve is connected with a chain, the chain can get caught between the flapper valve and the drain hole, the flapper valve is pliable so it tries to seal around the obstruction but can't always do it. Make sure there is obstruction, that the flapper valve is not out of shape or old and non-pliable and that it lines up with the drain hole and doesn't get "hung up" on anything.
Posted on Sep 11, 2009
smokenic
  • 49 Answers
SOURCE: Continous water running
just lower your float a little further. otherwise i'd adsume air is leaking out of your float. but if your float is up in the shut off position and water is still coming out. then you need a new assembly.
Posted on Sep 20, 2009
  • 17 Answers
SOURCE: toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Posted on Jan 23, 2010
  • 119 Answers
SOURCE: The toilet continues to run after flushing, i.e.e
The fill valve is stuck on and needs replacement, checking this part every year is a good idea.
Posted on Mar 28, 2010
97 Lumina.Two weeks ago had oil change.At that time, mechanic stated that coolant was low and discolored. He flushed the system at that time. This past week,my low coolant light came on. Checked tank and...
take the spark plugs out and fill the water up. turn over the engine. see what comes out of the spark plug holes. should just be fuel. smell. you will need some one to turn the engine over and have good charge in the battery. fill the water to the top so it is level. if you see the water go down when the engine is turning. then it could be air or a leak in the head gasket.
Oct 13, 2013 | Cars & Trucks
How to change water filter on msd2352kew
Instructions on how to change the water filter are found on page 20 of the user manual Here=> MSD2352KEW User Manual
I will be here should you have questions, Thanks Sea Breeze
The water filter is located in the upper right-hand
corner of the fresh food compartment.
1. Remove blue bypass cap and
retain for later use.
2. Remove sealing label from
end of filter and insert into
filter head.
3. Rotate gently clockwise until
filter stops. Snap filter cover
closed.
4. Reduce water spurts by
flushing air from system.
Run water continuously for
two minutes through
dispenser until water runs
steady. During initial use,
allow about a one- to two-minute delay in water
dispersal to allow internal water tank to fill.
• Additional flushing may be required in some
households where water is of poor quality
Mar 22, 2013 | Maytag Refrigerators
Keurig b70 water tank leaks out all over the counter
Shut-off valve failed, retry a second time and it will reset accordingly.
Dec 31, 2012 | Keurig Platinum B70 Coffee Maker
On my eljer toilet, I get continuous running of the water. If I shut valve off and pump the tank, the running stops (but only for a week or so). Suggestions? model 150-403 power flush pf/2
I don't know what you mean by "pumping" the tank. If the toilet runs, then either the fill valve is defective or the seal on the flush valve is defective. First, check to see that when you move the float, the toilet stops running. If it does not, then replace the fill valve. If it does, then inspect/replace the seal on the flush mechanism at the bottom of the tank. If this seal is bad, you can usually see water continuously flowing (slowly) into the bowl. You will see ripples on the surface of the water in the bowl.
Jun 01, 2010 | Eljer Home
Have a vitra dual flush toilet we have no water pressure when you flush the toilet
check to make sure the water level in your tank is sufficient, if not you'll need to ajust your float. otherwise your flapper is shutting too soon, you'll need to shut the water valve off and flush untill the water in the tank is gone, letting air back under the flapper slowing it's desent when submerged. then turn the water back on. if the problem continues repace the flapper.
Sep 19, 2009 | Home
Where is the water filter located on the Samsung SRS2028CSS
upper right-hand corner of the fresh
food compartment.
2. Remove sealing label from end
of filter and insert into filter head.
closed.
two minutes through
dispenser until water runs steady. During initial
use, allow about a one- to two-minute delay in
water dispersal to allow internal water tank to fill.
Sep 10, 2009 | Jenn-Air JFC2089HT Bottom Freezer French...
Atwood water heater lights and burns for a few minutes then shuts off and comes back on a minute or two later and burns for a while then off again. This continues until the tank has reached temp.
Check to see if the thermal bulb is aligened in the flame if ti is then you have a regulator going bad. Call a repairman to fix this issue he will need to check the vet the flame and the temp sensor, this is not something you would wantto do on your own and would require a hands on touch to see what is wrong.
Aug 19, 2009 | Water Heaters
Pump spinning but not getting up to speed then shuts off
You have a pressurized system using a pressure tank.This is a case of an air logged pressure tank. Meaning there is more air than water in the pressure tank. The pressure tank must hold 2/3 water and 1/3 air of its total volume. Installed at the tank is the air volume control to take care of this proportion. Should the air volume control malfunction or becomes defective, the air-water ratio is affected. And then,
the pressure tank becomes either air logged or water
logged.
SOLUTION:
1. Shut the power off, and open the discharge line
gate valve to flush the water in the pipe lines.
2. Open the drain plug of the pressure tank to empty
all the water at the pressure tank.
3. Close the drain plug, and put the power on.
4. Start the pump, and set the flow control valve 1/4
open.
5. The pump will normally run.
Send your e-mail for us to know the results, and for
further assistance.
Jul 04, 2009 | Plumbing
Home Logo
48 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
