Can't update my gypsy so that I can have access to my cartridges with my new air 2
My gypsy power comes on but the screen remains blank.
I'm sorry, I do not understand what you mean by 'gypsy'. Please respond with a model number, type of device, and I will try to help you.
Feb 24, 2016 | Computers & Internet
When fax comes through paper is blank. I've tried 2 different cartridges
Replace the print cartridge
When you notice that the print becomes light or ink low or when install new ink
cartridge appears in the display, replace the print cartridge. The part number for
replacement cartridges is HP 701.
1. Take out a cartridge from its packaging and carefully remove the tape covering the
printhead.
Hold the cartridge by the colored top or black areas only. Do not touch the copper
area.
2. Press the Access Cartridge button on the control panel.
The cartridge carrier moves to the install position.
1 Access Cartridge
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
Care and maintenance 45
3. Open the control panel and cartridge compartment cover (it will click and remain
open).
4. Push the cartridge down and remove it.
5. To load the cartridge insert the cartridge as shown below. When the cartridge is
pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks
into place.
If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this
step.
1 Control panel
2 Cartridge compartment
cover
46 Care and maintenance
Clear jammed documents and paper
6. Close the cartridge compartment cover and control panel.
7. Press Start/Enter.
8. Press 1 for new cartridge, or 2 for the old one.
• When you put in a new cartridge, you must choose 1:New
• When you put in a used cartridge, choose 2:Used. This helps you to check the
correct amount of ink you have left.
TIP: If you mix up several used cartridges, it is not possible to check the correct amount
of remaining ink. Once you have put in a new cartridge, use it until it is completely
exhausted.
Nov 11, 2011 | HP 640 Inkjet Fax Machine
How do I update my cricut imagine to accept the gypsy update?
jut go to this site and watch the video www.aboverubiesstudio.com/.../cricut-imagine/cricut-imagine.../2354/ try this one hope this will help you.
Oct 23, 2010 | Computers & Internet
Problem with the back door in my Gypsy. I have a hardtop MG413 Gypsy King. Because of the weight of the tyre and hardtop door the door is sagging and it is creating noice while driving. is there a better...
get mahindra jeep hinges..but u might have to cut it at the corners,, also additinal original gypsy hinges would do. i have isolated the wheel of my gypsy and modified a tempo trax rear wheel bracket..also a one on sumo could help
Jan 31, 2010 | 1994 Suzuki Samurai
Error message "remove and check cartridge on right" Did that and shook up the cartridge still feels like it has ink but when I replace it the message does not go away. If it is truly out of ink why doesn't...
Step 1 - Remove and reseat the cartridge
NOTE: The "problem" cartridge is the cartridge indicated by the error message.
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge. Figure 1: Removing the cartridgec00143341.gif
  3. Pull the problem cartridge out of the print carriage.
  4. Inspect the cartridge. If the cartridge is new, make sure to remove the protective tape covering the nozzles.
  5. Reinsert the cartridge into the carriage at a slight angle, as shown in the illustration below. When the cartridge is fully inserted into the carriage, rock it upright. Figure 2: Reseating the cartridgec00143342.gif
  6. Hold the hinged flap of the latch out while lowering the latch.
  7. When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration below. Figure 3: Closing the cartridge latchc00143343.gif
  8. Close the cartridge access door.
  9. The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Step 2 - Clean the contacts
NOTE: Try to clean the contacts quickly enough that the cartridges are not outside of the unit for more than 30 minutes. The ink can dry and clog the nozzles if the cartridges are outside of the unit for too long.
  1. Gather the following items to clean the cartridges and print carriage:
    • Clean distilled water. Use bottled or filtered water if distilled water is not available.
    • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
  2. Remove the problem cartridge.
  3. Place the cartridge on a piece of paper with the nozzle plate facing up.
  4. Unplug the unit power cord.
  5. Lightly moisten the lint-free cleaning material with clean water.
  6. Clean the cartridge contacts. Avoid touching the nozzles. Replace the cleaning material if it gets dirty. Figure 4: Cleaning contacts (avoid nozzles)c00143349.gif
  7. Clean the carriage contacts. Use new cleaning material if the material used on the cartridge contacts is no longer clean.
  8. Let the parts dry for five minutes before reinserting the cartridges. Figure 5: Cleaning carriage contacts c00143350.gif
Step 3 - Remove cartridges and shut down the printer If the steps above have not helped and the error message is "Remove and check the right cartridge ," the following steps may help:
  1. Remove both cartridges, lower the latches, and close the printer access door.
  2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
  3. Turn the printer back on by pressing the On button.
  4. When the message display reads Insert right cartridge , open the access door and replace the cartridges.
Step 4 - Download a firmware updateIf the error is still displayed, follow the steps below to see if downloading a firmware update from HP might help:
  1. With the power on, open the printer and remove the cartridges.
  2. Relatch the empty carriages and close the printer.
  3. Open the printer and reinsert and relatch the cartridges.
  4. Close the printer and look at the LCD display.
    • If the LCD now shows no error, the original error was caused by a problem that is fixed by HP's firmware update. Though the error has cleared, it may come back in the future, or other problems such as slow printing may occur. To fix these problems, download the latest firmware update from HP. Click here to see how. Make sure to download the firmware update, rather than a driver or other software.
    • If the error message is still displayed on the LCD, the firmware update probably will not fix the problem. The update does fix other problems however, and it should be installed when it is convenient.
Step 5 - Replace the cartridge or service the printerIf the steps above have not helped, replace the cartridges or service the printer. Replacing the cartridges can help determine whether a problem is caused by the cartridges or the unit. However, cartridge replacement will not solve problems that are caused by the unit.
  • If you have not previously tried replacing the cartridges to solve the problem, or if replacing the cartridges solved a similar problem in the past, replace the cartridges now.
  • If you have already tried cartridge replacement without fixing the problem, the unit may need to be serviced. Contact HP to see how to proceed. Click the link at the top of this page for contact information.
Nov 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
How do i get to my ink cartridge on a lexmark 125
Here is your link kindly download your manual which will tell you everything with photographs about cartridge access door and other troubleshooting
www.lexmark.com/publications/pdfs/x125/eng/enhcbook.pdf
Aug 15, 2009 | Office Equipment & Supplies
I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
If you turned the machine off and replaced the cartridge, you can get this error.
Could you try the following procedure below please to clear the error, thanks.
  1. Turn on the unit.
  2. Open the top cover to access the print cartridges.
  3. Remove the new cartridge that is causing the message.
  4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
  5. Press the 1 on the numeric keypad of the HP product.
If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
follow the steps below:
  2. Open the top cover to access the ink cartridges.
  3. After the cartridges stop moving, unplug the power cord.
  4. Remove both cartridges and close the top cover.
  5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
  6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
  7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
Hope this helps
Regards.
Apr 18, 2009 | HP Photosmart 3310 Printer
Hi there
Replacing Ink Cartridges 1. Turn on your printer. 2. Lift the printer unit. 3. The ink cartridge carrier moves and stops at the loading position unless the printer is busy. 4. Press down on the ink cartridge lever to raise each ink cartridge lid. 5. Remove the old ink cartridges. 6. Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them. 7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge. 8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier. 9. Snap each lid closed. 10. Close the printer unit. 11. An alignment page automatically prints.
Mar 01, 2009 | Dell 926 All-In-One InkJet Printer
HP DESKJET 1180C
HP Deskjet 1180c and1220c Professional Series Printer and HP Deskjet 9300 and 1280 Printer - Troubleshooting a Blinking Print Cartridge Light Introduction The Print Cartridge light continues to blink with both cartridges properly installed and the Access Cover (also known as the top cover or lid) closed. Instructions The blinking Print Cartridge light may be caused by a faulty cartridge, the plastic case of the printer being dislodged or slightly out of position (which prevents the Access Cover from seating properly), the Access Cover sensor (also known as the top cover sensor or lid sensor), or by the actuator on the Access Cover. Follow the steps below to resolve the issue.
  1. With the printer turned on, open the Access Cover. The carriage will move out of the capping station and stop at one of the cartridge status icons located inside the printer under the Access Cover. The yellow arrow on top of the carriage will point to one of the cartridge status icons to indicate a good, empty, or faulty cartridge. See Figure 1 below.
    1. If the carriage stops in the cartridge’s OK position, indicated by the happy face in Figure 1, continue with Step 2.
    2. If a problem is indicated with one of the cartridges, remove the cartridge and verify that the cartridge part number is correct. The black cartridge part number is 51645A and the color cartridge part number is C6578A or C6578D.
    3. If the cartridge part number is correct, clean the electrical contacts on the cartridge with a soft, lint-free cloth. Do not touch or wipe the nozzle plate.
    4. If a faulty cartridge is still indicated after verifying the cartridge part number and cleaning the contacts on the cartridge, replace the cartridge.
    5. After replacing the cartridge, turn off and then turn on the printer to clear the cartridge error from the printer's memory. If the cartridge error cannot be cleared, the printer will require repair. If the carriage stops in the cartridge’s OK position, indicated by the happy-face in Figure 1, continue with Step 2. NOTE: The printer checks the status of both print cartridges before printing. Both the black and color cartridge must be functional and installed in the printer in order to print.
    Figure 1: Cartridge status icons c00001225.jpg Icon/Drawing Problem identified by the symbol Solution c00001226.jpg The color cartridge is missing, improperly installed, defective, or the wrong print cartridge is installed. 1. If there is no color cartridge in the cartridge cradle, insert a color cartridge.
    2. If there is a color cartridge in the cradle, remove the color cartridge and firmly reinsert it.
    3. Check to make sure the color cartridge is appropriate for the printer.
    4. If the problem persists, replace the color cartridge. c00001227.jpg The black cartridge is missing, improperly installed, the wrong print cartridge, or is defective. 1. If there is no black cartridge in the cartridge cradle, insert a black cartridge.
    2. If there is a black cartridge in the cradle, remove the black cartridge and firmly reinsert it.
    3. Check to make sure the black cartridge is appropriate for the printer.
    4. If the problem persists, replace the black cartridge. c00001228.jpg The color print cartridge is running low on ink. Replace the color print cartridge with a new color print cartridge. c00001229.jpg The black print cartridge is running low on ink. Replace the black print cartridge with a new black print cartridge. c00001230.jpg None. The print cartridges are working correctly. None. The print cartridges are working correctly.
  2. Close the Access Cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, remove the Access Cover by following the steps below:
    1. Open the Access Cover and hold it open.
    2. Dislodge the Access Cover from the hinges with a sharp blow to the hinge area of the Access Cover and then remove the Access Cover.
  3. Install the Access Cover by following the steps below:
    1. Align the hinges on the Access Cover with the hinge pins on the printer.
    2. Push down firmly on the Access Cover until the hinges snap into position.
  4. Close the top cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, the printer case may be dislodged or slightly out of position. To restore the printer case to the proper position, squeeze the printer by applying pressure to the front and back pressure points shown in Figure 2. Figure 2: Pressure points c00006497.jpg Firmly squeeze the pressure points on the printer case as shown in Figure 3. If the Print Cartridge light continues to blink, continue with step 5. Figure 3: Squeezing the pressure points c00006498.jpg
  5. If the Print Cartridge light is still blinking, push down firmly on the center of the Access Cover (the extra pressure may engage the sensor). If the Print Cartridge light quits blinking, remove the pressure from the Access Cover to see if the Print Cartridge light starts blinking again. Re-apply the pressure to the center of the Access Cover to see if the Print Cartridge light stops blinking again.
    1. If the Print Cartridge light quits blinking with pressure applied, the Access Cover is faulty and should be replaced.
    2. If the Print Cartridge light continues to blink even with pressure applied, the Access Cover sensor may be faulty and the printer will require repair.
Oct 18, 2007 | Office Equipment & Supplies
26 people viewed this question
jasbo
jasbo
