Question about HP Pavilion dv6-1122us Notebook
On puttin on my web cam it said ''hp mediasmart webcam does not support a screen resolution smaller than 1024x768, and i am not able to start web cam.
  • 3,600 Answers
Click on your desktop and set your screen resolution to that size 1024x768, but I don't believe that’s the case cause most web cameras only put out 300 bit pictures but try it maybe it will work and afterwards you should be able to open the properties of the camera to change resolution
Posted on Jul 21, 2009
Where can I find the drivers for the HP truevision Web cam in my HP Pavilion dv7-4117ez
To use the webcam you need the HP MediaSmart Webcam Software installed.
If it is not functioning well anymore, re-install it. In most cases the installed HP
software packages are saved in the C:\SWSETUP folder on your harddisk.
Check the version of the installed HP MediaSmart Webcam Software, and if you
need it you can find v3.0 here:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&tmp_geoLoc=true&softwareitem=ob-77452-1
Jun 30, 2011 | Computers & Internet
Tip
Solution to the HP Purple Web Cam Issue
This document is located on HP's web site concerning purple tint on certain web-cams.
This document pertains to certain HP Notebook PCs with Windows 7.
When using an HP ENVY 15 notebook PC webcam in low light conditions, images on the webcam may have a purple tint.The ENVY 15 Series webcams include night vision technology that is designed to operate in normal lighting conditions and optimized to operate in low and zero light conditions.The webcam night vision feature includes two Infrared (IR) lights located on each side of the webcam and behind the display panel bezel.
Low to zero light conditions will cause the webcam IR lights to activate. The IR lights provide illumination for low and zero light conditions and help prevent fuzzy images that are typically associated with operating standard webcams in low and zero light conditions.
Turn off the webcam IR lights. While some degree of purple tint may be present under low light conditions, turning off the webcam IR lights will reduce and in certain cases eliminate the purple tint.
  1. Select Start > All Programs > HP > HP MediaSmart > HP MediaSmart Webcam .
  2. In HP MediaSmart Webcam, select Settings > Display > Advanced Settings , and then click the Camera Control tab.
  3. Select the Low Light Compensation check box, and then click Apply .
  4. Click OK .
NOTE:Disabling the webcam IR lights will cause display images to appear darker in low and zero light conditions.
The webcam IR lights are also available on other webcam programs.
Refer to the software Help for additional information.
This document will be updated if additional information becomes available.
on Jul 28, 2010 | Computers & Internet
Hp mediasmart webcam does not support a screen reslution smaller than 1024x768
Often webcams produce fixed resolution images, and cannot be changed. I would double check to see if you have the correct drivers installed for both your webcam and your graphics card. You can download these by entering your Part number (from the bottom of your laptop) here: http://welcome.hp.com/country/us/en/support_task.html
Mar 01, 2011 | HP HDX 16t Premium-Intel Core2 Duo...
How to get back my web cam drivers for hp dv9000au windows 7.... i used quickplay till i had windows vista... but nw since i have installed windows 7... i cannot access my web camera.... so pls help me...
Hi, Quick play would not work in Windows 7. When upgrading from Vista to Windows 7, some media programs are no longer compatible and will not be found in your Start menu. HP provides replacement programs for QuickPlay and other media programs with Windows 7 MediaSmart software. Plz go to below link and you will get all appropriate software?s of HP Mediasmart. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01929858&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN In this link you need to download the drivers used in HP mediasmart webcam and all other stuffs. If you find this helpful then Plz vote for me..Dreamkam
May 23, 2010 | HP Pavilion dv9000z Notebook
The MediaSmart webcam was working until I hooked up my HDMI cord to the T.V. I disconnected and unpluged the cord and my mediasmart webcam want work. There is a pop up that says " HP MediaSmart Webcam does...
u need to change the resolution of the computer more than 1024x768> u do that by right clickin on the desktop> properties> settings tab> increase the resolution > click apply> then ok
Oct 09, 2009 | HP w2558hc 25.5" Widescreen LCD Monitor
MEDIASMART WEBCAM HOW TO TURN IT ON
first check device manager to see if theres a mismatch ( the yellow exclaimation mark) next to the description of the component, if it fine then check add hardware app in windows to see if the system is recognizing it and if its functional. then check drivers for web cam , then the program in windows that starts the webcam, some progs place an icon on the screen to active the program.
Jul 12, 2009 | HP Pavilion ze2000 Notebook
HP Webcam not working.
If it an external web cam you need to plug in to your computer , then install its drivers through CD.
Jun 18, 2009 | HP Pavilion dv2000t Notebook
I cannot turn the web cam on
There is a software to turn on the webcam
Try this
Start > Start Search > type in YouCam/Cyberlink/MediaSmart.
Click on any one which you see in the start up menu above and your webcam will start.
Jun 03, 2009 | HP Computers & Internet
YouCam not working on my HP Pavilion dv6707us laptop...
every time i click on my you cam icon, it says you cam cannot support a screen resuloutin smaller than 1024x768
Nov 26, 2008 | HP P1978A Webcam
PC web cam not funcitoning properly
Well, that could be because of the cam itself. It is a cheap cam. If you want better quality you will have to buy a little more expensive cam with atleast 1 MegaPixels resolution. The one you currently have has about 600 000 Pixels. Simply put, you will have to buy a cam with higher resolution for better quality.
Mar 24, 2007 | Philips SPC 200NC Webcam
HP Pavilion dv6-1122us Notebook Logo
295 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
