Question about Sony Televison & Video
Sony c635 will not play continues Schaffer all disk will play single disc only what is the problem
    Master:
  • Sony Master
  • 469 Answers
One of the lovable boyfriend present ideas that we like is usually to consider a snapshot of you in a fairly racy pose and following that have it made into a mouse pad. Mouse Pads Choosing The Best Pad For Your Computing Needs AmanStino
Posted on Jan 06, 2017
Dvd not spinning properly
I had the exact same problem.
There was a bad batch of spindle motors (why they didn't use brushless is any body's guess). I replaced mine and it is quite easy. I even soldered in the single-DVD player's (same basic model number, just not multi-disk) motor because I couldn't find the right part for the multi-disk model (or the single was cheaper, I forget). That was years ago and it still works great today (I didn't like the lack of features on a cheap replacement player).
Apr 08, 2008 | Sony DVP-NC675P Multi-disc DVD Player
Sony dav-hdx265- disc is stuck- door will not open
According to the Sony manual, a C-31 error code indicates that the disc is not inserted correctly. Their recommended fix is to restart the system and re-insert the disc correctly. That just leaves the problem of getting the disc out, right? If eject doesn't work, you may have to open the disk drawer manually. With single-disc systems this is fairly simple: there is always a small pinhole near the disc drawer, usually just below the right side of the drawer. Straighten a paper clip and stick it into the hole until the latch releases, then remove the disc and close the drawer. All should be fine from there on. I do not know if multi-disc systems have the same sort of release but that is where I would start.
Nov 24, 2013 | Sony BRAVIA DAV-HDX267W Theater System...
Denon DN-C635 CD Player problem.
In working with consumer electronics a lot of years, the pickup, mechanism or CD section is not always at fault but people that
are trying to work on their own equipment make assumptions that may not be correct. If you put in a new CD player then the other issues as with all wave soldered equipment can be bad solder joints and even bad solder at joints where the connectors are as these get a lot of activity in a repair. Look at the PCB well. I have fixed a lot of equipment by resoldering bad or broken joints. Check around power transistors and those larger drive transistors for these broken joints.
Mar 22, 2013 | Denon DN-C635 CD Player
L need to play mortal kombat armegeton but my format disc stop working is there any other way to play it
Your disk is corrupted due to power failure/termination when it was saving data there.
You must format to continue.
Apr 15, 2011 | Sony PlayStation 2 Slimline Console
Have a Denon DN-C635 CD player . Replaced motor spindle / laser assembly (plug and play part assembly from Denon $45 old price $151) It loads disc , voice coil moves laser lens up and down but spindle...
Dave, Holding the motor spindle / laser assembly in a position where the white ribben plug in receptacle is facing in an upward position, look down to the lower left hand corner of the print board just under the plug in. You will see a small blob of solder bridging two contact points. Remove this solder bridge. I have found two new Denon assemblys with this problem.........*****
Mar 11, 2011 | Denon DN-C635 CD Player
Sony MDS-JE440 mini disc,single play
If there is a "PROGRAM" button, then you just turn on "program", rotate the knob to what track you want and then hit ENTER. Then when you hit 'play' it will only play back that track. You'll have to repeat this for every track or manually hit the PAUSE button between tracks if you program more than one.
Nov 10, 2009 | Sony MDS-JE440 Mini Disc Player
My nexbase dvd player doesn't recognize many discs
Time to buy a new DVD player. Try using Sony or Samsung dvd player.
Aug 23, 2009 | NextBase SDV-17 Portable DVD Player
Power disconnected during finalization
There's no way you can continue the finalization of the disc, the disc has been marked as finalized already, even a single power fluctuation when you are using ac power adaptor can affect the disc finalizing process, so it is better to use battery when disc finalizing
Aug 30, 2007 | Sony DCR-DVD301 DVD Camcorder
Televison & Video Logo
32 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
