Question about Sewing Machines
Thread winding around bobbin holder & pulling stopper past stopper spring singer 9960 new used 3 months
  • Sewing Machines Master
  • 12,273 Answers
If the machine is only 3 months old, it may still be covered under warranty. Contact the manufacturer for assistance.
Posted on Dec 31, 2016
How do I engage the boobin to the top thread?
wind thread onto the bobbin
place the bobbin into the carrier pulling the thread around the edge until it goes down the slot and under a flat spring
pull about 6" of thread out
put the holder into the machine
hold the needle thread and turn the machine by hand
in 2 or 3 full rotations the needle thread will have picked up the bobbin thread and you can pull both threads out ready to sew
if it is not happening , take it in for a service as the needle /hook timing may be out
Jun 12, 2016 | Sewing Machines
How do i thread the bobbin on a singer electronic anniversary edition
wind bobbin, drop into position ensuring that when thread is pulled bobbin rotates counter clockwise, pull thread towards you into slot, pull it to left under tension spring, then follow thread groove in bed to thread lock back left corner. close cover and start to sew ifr you need Singer 160 instruction email
Feb 04, 2014 | Sewing Machines
How to fill a bobbin on singer sewing machine model 6268
Raise the presser foot and turn the hand wheel to put the needle at the highest position. Next open the slide plate by sliding it towards you. Make sure the bobbin is empty (remove any remaining thread or use a new bobbin). Slide the plate forward (partially closed) so that the arrow on the plate lines up with the arrow on the machine bed. Bring the thread from the needle under the presser foot and wind it around the presser foot screw (on the left of the assembly) once. Make sure that the thread is in the spring groove. Press the One-step Button hole A button (has a bobbin symbol by it). Then begin running the machine. Watch the winding process carefully and stop when you have enough thread on the bobbin. Do not let the thread continue to wind past the outermost line on the bobbin (black). Slide the plate fully closed and raise the needle. Pull the thread to the back of the machine to a length of 4" and cut the thread in the middle of the loop you just pulled through.
Now position your fabric under the presser foot, lower the presser foot and select your stitch. Begin sewing.
The manual is available for sale or download here: http://www.singerco.com/accessories/instruction-manuals/search . Just enter the model number. The direct link is: http://www.singerco.com/uploads/download/1272_6268-_-6268_6267-wholeas-of-6_23_05-special.pdf . Pictures for winding the bobbin are on page 16 (page 18 of the PDF).
I hope this helps.
(make sure that the machine is correctly threaded before starting to wind a bobbin)
May 25, 2011 | Singer Sewing Machines
The tension on the bobbin is giving big loops and then breaking
This could be one of the following:
  • wrong bobbin for the machine
  • bobbin loaded the wrong way - must rotate anticlockwise when you pull the thread
  • thread not into the tension spring/device on the bobbin holder correctly
  • bobbin wound badly, uneven tension, loose or uneven across the bobbin
  • poor quality or old dry brittle thread could cause the breaking (but the loops is definitely tension issues).
This is a top loading bobbin machine machine and you can download a manual from
http://www.singerco.com/accessories/manuals.html
Here is the threading diagram from the manual.
tally_girl_21.jpg It is important to click the thread down into the tension spring on all top loading bobbin machines and then pull gently on the thread to check that it is under tension, you should feel firm resistance when you pull the thread. If not, then take it out, and try again.
Other thing to look at is how the bobbin is wound. It is necessary to wind a bobbin smoothly and with some tension on the spool as the thread comes off it. Best analogy is the garden hose reel. If you wind it up and don't control where the hose goes onto the reel it will all lump up in the middle, and you won't get all the hose onto it. And then when you go to pull the hose out, it will jam and be difficult to pull. Same with bobbin thread. You want a nice neat even fill across the whole width of the bobbin, not just the middle. To achieve this make sure you use the bobbin winder tension disc when winding. Also use the spool cap on top of the thread spool to stop it from bouncing around as it unwinds - the thread will then wind off around the spool cap and this keeps it running smoothly and not twisting and jerking. If you don't have a spool cap then put the curved handle of a pair of scissors on top of the thread spool to tension it while you wind the bobbin. Also watch the bobbin as it winds, give the thread a nudge with your finger to control the fill onto the bobbin so it winds top, bottom and middle of the bobbin evenly.
I would suggest the following:
clean out the race following the manual directions to remove the bobbin holder, clean in this area, replace it. Wind a fresh bobbin and then load it into the machine, following the manual instructions carefully. Also thread the top of the machine following the manual, put in a new sharp needle from the pack, turn the top tension dial to a medium number (often 5 if dial goes from zero to 10).
Now test sew again. Look at the seam, if you have loops on the bottom of the fabric, underside, then the top thread tension is too loose or not in the top tension discs fully. Generally you should not need to adjust the tension on the bobbin thread for these machines.
Apr 13, 2011 | Singer 5050 Mechanical Sewing Machine
Bottom thread too loose; tried rethreading top thread, cleaning bobbin case, refilling bobbin, changing needle, adjusting top tension
Check for correct bottom thread tension.
It's provided by a flat spring on the bobbin holder.
When the bobbin is correctly installed, pulling on the thread
should meet with slight resistance, and the bobbin should spin without
trying to jump out of the bobbin holder.
Dec 18, 2010 | SINGER 7470 Sewing Machine
Using Singer 7470 for the first time, and my bobbin thread is bunching terribly. There is a loud sound from the bobbin chamber, as if the mechanism is bouncing around??? How can I fix this bobbin issue?...
1. Take bobbin out and re-insert and thread.
If that dosen't work, try:
2. Take bobbin out and bobbin case, clean area and re-insert bobbin case and bobbin.
3. Re-thread the top thread that goes to the needle. (Sometimes the thread dosen't hook to the "Thread take-up"(page 6 on manual). It pulls the bobbin thread and the bobbing becomes loose inside the bobbin case.
4. Wind a new bobbin (Sometimes a bobbin might wind thread to lose) Do not wind thread to the edge of bobbin.
If that dosen't work, you should take it in to be serviced...Somenthing might become loose that only a technitian can correct.
Also check manual for troubleshooting.
Good luck.....
Chickiefl
Apr 15, 2009 | Singer 7436 - INGENUITY
Thread catching and bunching up in bobbin latch while sewing
I had the same problem where the thread was getting all bunched up on the underside. I took everything out and followed the manual concerning threading, then manually moved my right wheel to see if it would get bunched up. It took awhile, but I finally got it sew correctly again. I;m still not sure what was wrong with it. I have a singer 7470.
Mar 23, 2009 | Singer 132QRFB Mechanical Sewing Machine
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
I need to thread an elna air electronic su sewing machine
that's a nice machine, one of the last mechanical Elnas with the discs for extra stitches. Firstly, you need to wind a bobbin, always use Elna swiss metal bobbins, with holes on one side only, slightly dished. Put on top of the bobbin spindle and take the thread from your spool on the spool holders at the back of the machine across to the tension disc on top left, its white bump, thread through the tension then back to the bobbin and pull the tail through a hole in the top of the bobbin. Flick bobbin across to the right against the stop, disengage the clutch by holding the outer flywheel and turning the inner towards you. Now press the foot pedal to start winding a bobbin, holding the thread tail so it starts off. Wind one full coverage of the bobbin so that the starting point is covered, then stop and cut the tail off with scissors. Now continue winding at 3/4 speed until bobbin is full, watch as it winds and give the thread a nudge with your finger so it fills top and bottom as well as in the middle of the bobbin. When it is full, the bobbin spindle will stop winding. Move it to the left, cut the thread and reennage the clutch by holding flywheel and turning the inner the other way. Now install the bobbin and click the thread into the tension device, see image.
Now thread up the top thread by taking the top thread from the spool, through the tension discs, across to the eyelet on top, down to the check spring, back up to the take up lever, then down to the needle catching the thread into the two thread guides enroute.
See this image.
Now thread through the needle front to back, hold the top thread, close the bobbin cover leaving the tail sticking out the top, lower the needle down by turning the flywheel towards you through one cycle and pull the top thread, drawing the bobbin thread up to the top of the needle plate with it. Pull both threads under the pressure foot to the back and your ready to go. Remember, top tension should be on 5 and bottom tension should be on the red 1, don't change it. Brush out the bobbin holder assembly each time you use this machine and add one drop of oil into the middle of the bobbin holder, there may be a red dot or just the indenation. Run the machine for 30 seconds after oiling without thread, slowly to spread the oil through the bobbin mechanism. Standard 130/704H needles, change regularly (6 hours of sewing) and pick right sized needle and type point for the work you are sewing. Good luck with your SU. If you wanted to join, there is a Yahoo group called "Elna Heirlooms" for fellow Swiss Elna owners.
Aug 24, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
