Question about Ovens
COULD YOU PLEASE PROVIDE THE REQUIRED POWER RATING FOR ELECTROLUX UNDER WORKTOP DOUBLE OVEN AMPS? EOU 43002X
barkencoa
  • 3463 Answers
SOURCE: Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Posted on Jan 11, 2009
jumptrout51
  • 3361 Answers
SOURCE: Bottom oven on Electrolux EOU 6330
Probably a broken bake element.
Posted on Jul 05, 2009
jumptrout51
  • 3361 Answers
SOURCE: I have an electrolux double oven eou 6330 the
Yes. You can do it. Part should be $40 or less.
Turn off the power to the oven. Remove the oven racks.Unscrew the element screws from the back wall of the oven. Carefully pull the element out. The wires may be short. Remove the wires from the element. Do not let the wires pull back into the oven cavity. Take the element to the appliance parts store and have them match it to the existing element. Attach the wires to the new element,insert the terminals into the opening,replace the mounting screws. Turn on the oven and bake away.
P.S. Your model number is not correct.
Posted on Nov 05, 2009
Testimonial: "Thankyou for your help I will have a go asap."
barkencoa
  • 3463 Answers
SOURCE: I have an electrolux EOU 6330 double oven, how do
Assuming you live in the u/k, and it is an electric fan assisted oven, and that it is the fan oven you are referring to, then the element is usually to be found at the rear of the oven compartment, behind a removeable cover.
Hope this helps.
Posted on Dec 10, 2009
  • 13 Answers
SOURCE: electrolux 30" electric double oven
Some oven elements are "plug-in" style, held in place with spring clips, It is possible that they have dislodged during cleaning. Good luck, Rob
Posted on Jan 01, 2011
NEFF B4562 Oven LED display just stopped working during use yesterday. Oven still works but have to guess what programme I am using. any ideas on fixing it without the Neff 100pounds call out fee and...
Preparing the units - Fig. 1
? The safe operation of this appliance can only be guaranteed if
it has been installed to a professional standard in accordance
with these installation instructions. The installer is liable for
damage incurred as a result of incorrect installation.
? Fitted units must be heat-resistant up to 90 °C, and
neighbouring unit fronts up to 70 °C.
? Cut-out work on the units and worktop should be performed
before fitting the appliances. Remove any shavings or the
function of the electrical components may be impaired.
? Caution during installation. Parts that are accessible during
installation may have sharp edges. Wear protective gloves to
prevent cuts
? The power socket for the appliance must either be located in
the hatched area B or else away from the installation space.
? A gap of 5 mm is required between the appliance and
surrounding unit fronts.
? Secure freestanding units to the wall using a standard bracket
C.
Appliance under the worktop - Fig. 1
There must be a ventilation cut-out made in the intermediate
floor of the surround unit.
Secure the worktop to the fitted units.
If a fitted oven is to be built in under a hob, pay attention to the
hob installation instructions.
Appliance in a tall unit - Fig. 2
The appliance may also be installed in a tall unit.
There must be a gap between the intermediate floors and the
mounting wall of approx. 20 mm in order to provide ventilation
to the oven.
Only fit the appliance at a height where removing baking trays
does not present a problem.
Corner installation ­ Fig. 3
To ensure that the appliance door can be opened in the case of
corner installation, take account of dimension D. Dimension E is
dependent on the thickness of the unit front under the handle.
Connecting the appliance to the power supply
Only allow a licenced professional to connect the appliance.
National regulations apply as well as those of the local electricity
supplier.
The appliance must be disconnected from the power supply for
all installation work.
The appliance corresponds to protection class I and may only
be operated with a protective earth connection.
Power cord: Type H05 VV­F or higher rated. The yellow/green
wire for the PE connection must be 10 mm longer than the other
wires on the appliance side.
During installation, an all-pole isolating switch with a contact gap
of at least 3 mm must be present, or the appliance must be
connected via a three-pin earthed plug. This must be accessible
after installation.
Contact protection must be ensured by the installation.
Identify the phase and neutral conductors in the socket.
Incorrect connection may cause damage to the appliance.
Only connect as per the connection diagram. See the rating
plate for the voltage.
Position the appliance in front of the units in readiness for
connection. The connecting cable must be sufficiently long.
Securing the appliance ­ Fig. 4
? Fully insert the appliance and centre it.
? Screw the appliance into place.
? The gap between the worktop and the appliance must not be
closed by additional battens.
Removal
Disconnect the appliance from the power supply. Undo the
securing screws. Raise the appliance slightly and pull it out
completely
the only contact info that I found is the info below:
http://www.neff.co.uk/contact-us.html
Dec 08, 2014 | Neff Ovens
Electrolux oven racks how do they go in oven?
Hi Friend, that's a great question!
I see that your post is listed under Electrolux Wall-Oven. May I have your model number please? You can normally find the serial tag (which lists your model number) on the front of the oven, on the left side, as you open the door. With this material I can provide you the correct instructions on how to place the racks in your Electrolux wall-oven. Thank you! - Z
Jul 20, 2014 | Electrolux 30" Built-In Double Electric...
Hi, I have an Electrolux EOU 6330 electric grill/oven. In have only used it twice as i have just moved in to the house and after the second use during the cool down period it started rapidly clicking and...
Try turning the power off to the oven at the meter box and leaving it off for an hour or so. This will allow it to fully reset. When you power up again, reset the clock time and set to manual cooking , hopefully , all will work again.
Jun 27, 2014 | Ovens
We have an Electrolux E30EW85ESS double oven. We took the doors off to clean the class and now we can get them back on. Is there a trick to putting them back on? Thanks, Tired and Frustrated
Hello & Welcome to FixYa
This video gives you step by step instructions for replacement:
Please get back to me if you have any other questions.
Kevin
Aug 16, 2011 | Electrolux E30EW85ESS Electric Double Oven
I have an electrolux EOU 6330 double oven, how do I gain access to change a faulty element?
Hope this helps.
Dec 10, 2009 | Electrolux EOU6330 Electric Double Oven
I have an electrolux double oven eou 6330 the bottom oven element has broken.Can I buy and fit it myself as single female with very little spare cash?
Nov 05, 2009 | Electrolux EOU6330 Electric Double Oven
What connection do you require for eye level electric double oven
You need a 45amp circuit for this double oven, under no circumstances , try to run it off a 13 amp circuit.
Thankyou.
Jan 25, 2009 | Neff U1421 Double circotherm Electric Oven
Thanks.
Jan 11, 2009 | Electrolux EOU6330 Electric Double Oven
Ovens Logo
24 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
