Question about Samsung Microwave Ovens
Samsung microwave model smh1713s is stuck on demo mode
pgh_pa_guy
  • 2992 Answers
SOURCE: microwave wont heat
The manual says "while in standby mode, press and hold the '3' key on the keypad for 3 seconds until 2 tones sound and the 'DEMO' icon appears. Repeat to turn demo mode off."
You can download a copy of the manual here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208206572.pdf
Posted on Jan 26, 2009
SOURCE: Microwave oven (nn-sd997s) stuck in
Pressing "timer/clock" button 4 times turns on and off demo mode.
Posted on May 18, 2009
  • 864 Answers
SOURCE: Dimension 4 microwave stuck on demo mode
Here are is the manual:
http://service.us.panasonic.com/OPERMANPDF/NNT888S.PDF
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Posted on Aug 12, 2009
Testimonial: "Thanks very much, it was driving me crazy!!"
  • 41 Answers
SOURCE: microwave stuck in demo mode
press 'function' '0' '2'
Posted on Sep 14, 2009
SOURCE: we had a power blackout now my panasonic genius
DEMO MODE ON/OFF
Demo mode is designed for retail store display. In this mode, the oven can be demonstrated with no power in the oven.
On the "Timer/Clock: button:
4 taps ON The oven is in Demo mode.
4 more taps OFF The oven is not in Demo mode.
Posted on Oct 08, 2009
How do i turn demo mode off on model mw6573g samsung microwave
Press " My Settings" and the number 6 and then the number 1 or 2 to turn off the demo mode
Nov 18, 2016 | Samsung MW6572W/MW6573G Microwave Oven
I need help microwave Samsung model smh1713s it set, how can I fix
Unless there is grease, moisture, or some other foreign material deposits on your control circuit board, "SE" means you have a shorted membrane keypad.
For the official repair information as per the Samsung bulletin, see http://www.microwavecontrol.com/samsung_se_error.htm
See my profile picture if you need more help.
Jul 26, 2015 | Samsung Microwave Ovens
Panasonic inverter nn-cf778s
Demonstration Mode
This is to enable you to experiment setting various
programs. (The letter D will always appear in the display
window. This is to confirm that there is no microwave
power produced and it is safe to use the oven without
any food). To set Demonstration Mode: press micro
power once, then press Stop/Cancel 4 times. To cancel
Demonstration Mode press Micro power once, then
Feb 03, 2012 | Panasonic Microwave Ovens
It keeps on showing demo and we dont know how to get it started again
Depends on the model but here is a video for one model: http://www2.panasonic.com/webapp/wcs/stores/servlet/vSupportHowToGuideDetail?storeId=15001&idval=UCM_STG_CNT_037074&catname=Microwave+Ovens&title=How%20to%20deactivate%20the%20Demo%20Mode
In most Panasonic models, the DEMO mode is turned on or off with "Fn + 5" key combination. So if you are stuck in Demo mode, press Fn followed by 5 it will bring you out of it. Other times, it could be Fn + 0 and then Press 1 to turn on the demo mode and 2 to turn it off.
If there is no Fn key on the touch pad then it could be something like tapping the ON or OFF key four times
Jul 17, 2011 | Panasonic Microwave Ovens
Stuck on demo and cild lock
My Samsung did this as well. Unplug for at least two minutes and plug back in. Press the clock button twice. Set the time and press clock button once more. Doesn't have to be correct time, any time will do as you can go back and set correct time later. After pressing clock it should be out of demo mode. Try 1 second on high cooking. This should take care of the problem.
Aug 23, 2010 | Samsung MW4699S Microwave Oven
Stuck in demo mode after power outage - any ideas on how to get it out? model is JVM2070
Talked to GE Help Line (1-800-626-2005) and found out the magic key combination for this microwave. Plug in after being unplugged for at least 30 sec. and then press Help plus Boost at same time for 3-4 seconds (until it beeps). The microwave will now be in normal mode (I assume you do this to put it in demo mode as well).
Sep 13, 2009 | GE Profile Spacemaker Over-the-Range...
Aug 12, 2009 | Panasonic NN-T888S Convection/Microwave...
Stuck in Demo Mode
I will need a model and serial no to further assist you
Jun 19, 2008 | GE CVM2072SMSS Microwave Oven
GE Microwave DEMO MODE
I just bought a condo with a GE Spacemaker Mod# JVM1860SD
that was stuck in demo mode. (This mod# has been replaced by the JVM1870*** series)
I called GE twice in two days, and finally got someone who had the solution (and it worked):
  1. Unplug the unit for at least 30 seconds
  2. Plug the unit back in DO NOT SET THE CLOCK
  3. While the unit is still "booting up" and the display screen is lit with gibberish, HOLD THE POWER LEVEL AND THE ZERO BUTTON for at least 5 seconds.
  4. After 5 seconds, the screen will display "demo mode off"
It messed me up at first because the power level and zero pads don't beep when the unit is booting up... but it worked.
- Again, this is for the GE Spacemaker 1860-1870 series models only - The women who gave me instructions said she had different demo mode unlock methods for the 1400, 3670, 2070 etc... so call GE if you have a different model.
P.S. my model looks like this - the keypad setup is key http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=JVM1870SK&SITEID=GEA
Mar 01, 2007 | GE Advantium SCA2000B Microwave Oven
Microwave Ovens Logo
69 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
