Question about Ovens
My Oven FI31K.BIX GB is not heating up - Ovens
Heat shield fixing
you could also find a bigger self tapping screw, but if you have corrosive metal I would replace the piece, as it can spread over time.
Dec 03, 2013 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Smeg gb-ie
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 12, 2013 | Smeg Ovens
I have a Bosch HBN7053GB /05 oven which worked fine apart from the bottom oven does not heat up, the light and fan are both working just no heat. I have replaced the element but still no heat, so now im...
You changed the element does everything else work fine, stovetop elements,broiler etc.if so check your wiring going to the new element and to the switch if they are fine it may just be the temp/control switch
Mar 12, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
I can hear the fan but there is no heat!
If the fan is working o/k, the n you need to fit a new o ven element, located at the rear of the oven compartment behind a removeable cover.
Oct 11, 2010 | Bosch HBN 7052 GB Stainless Steel Electric...
I purchased a microwave/convect oven combo last week. Installed today, everything works fine except that the lower oven won't heat. I tried turning the breakers off waiting a few minutes and back on. ...
Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
Sep 04, 2010 | Bosch HBN 9722 GB Electric Double Oven
Main Oven Overheating
Try putting thermoter in oven take off main dial you well see a small screw ajust slowly and check every 30min.tell temp is correct.and put dial back on
Jul 26, 2010 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Main oven doesn't heat up. is there a fuse i can change some where?
If it is a electric fan assisted oven, and the fan is working o/k, then you will probably find that the oven element is faulty.
This is located at the rear of the the oven compartment, behind a removeable cover.
Hope this helps.
Dec 31, 2009 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Fan working but oven not heating,if it is element how do i replace it. Model number BoschHBN9153GB double oven.
It will be the element that needs to be replaced, remove panel at rear inside of oven, you will see the element located there.
Please rate my solution.
Sep 17, 2009 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Bosch hbn s gb
oven element would need model and ENR No. to supply
Sep 16, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Ovens Logo
22 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
