We have a Trane XL80. Moel TUD100R948KO. How many BTU's are there in this model?
This is a furnace/air conditioner Model.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
130000 btu
Trane xl80 blower working intermittently
hello Miss/Mrs/Mr,
I have the furnace trane xl 80, when I turned for heat everything working but only blower motor was not running, I wait for 1 minute all system suck down? I guess the capacitor blow out, that the reason why blower motor was not running
Please email me that is the
Jun 24, 2012 | Heating & Cooling
Determining the age and size of a Trane evaporator Model # TXH054A4HPAF
The serial number on that evaporator will have the date code in it, the model will tell the capacity (size). It looks like it is a 4 and a half ton or 54,000 BTU coil and has a TXV valve to meter the refrigerant.
Jun 16, 2011 | Ruud UAKA037 Air Conditioner
I have a trane xl80 furnace. the fan runs but no heat. The light on the front blinks 9 times and on the panel it says something is wrong with the ignitor. can I fix that at home or do I need to call a...
The ignitor on your furnace broke... this is a common problem and not too hard to fix if you have a place to buy the ignitor from... it also can be purchased online...
If you are not confortable with repairing it then call a repairman...
Here is a tip that wrote about how to buy heating and airconditioning parts online.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Nov 30, 2010 | Heating & Cooling
Furnace doesn't heat the burners come on for about 3 seconds then shut off. The furnace is a Trane XL80
The flame sensor is not sensing that the flame has come on....the flame sensor could be dirty or the could be ignition module problems...
I am assuming that this is not a new installation....because reveres polarity can cause that also....
I would clean/ replace the flame sensor first and then from the the control board will ned to be replaced if that don't work.....
Have had to drive a totally separate ground rod and ground the furnace separately in one extreme case...
heatman101
Nov 15, 2010 | Heating & Cooling
I currently have dual split units (Trane XL80 & XR13) heating and cooling the house. One of the XR13's is not working properly. This is what I observe. The XR13 in question is running --the fan is...
Check how many times the light is blinking... it will flash a series of blinks and then pause...and flash the series again...
Then remove the cover nad insdie it will tell you how to interpet the blinks and then you will know why it is kicked off...
heatman101
Aug 24, 2010 | Heating & Cooling
What is the efficiency rating on the Trane model BLU055E936B1 upflow furnace and what new furnaces are available to replace this old Trane furnace without having to change the venting system.
Chances are you need to replace both the condenser and furnace, then you you should get a varaible speed blower with the new furnace, get at least a 90% gas system with a 16 SEER condenser, save on energy cost as soon as it's installed. Go Get IT
Jan 28, 2010 | Ruud Central System Air Conditioner
Need a schematic diagram on a trane furnace model blu080k0942b0
Have you checked on the inside of both front panels?
Mar 05, 2009 | Heating & Cooling
Model number for Carrier furnace with issue for blower 5 minute off delay
I believe that this model number is for an air conditioner evaporator coil. This unit is probably directly attached to your furnace. The Model number for the furnace will be located in the compartment where the flames can be seen. It will be on a sticker or plate that contains lots of other information too like BTU/h, Volts etc...
The number you gave me gives me this info:
Cased air conditioning evaporator coil.
3 Tons
Horizontal application
Jun 27, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
