Question about The Audio Players & Recorders
My 400 disc changer lights comes on but it does not select a disc. what is causing this?
There is a sound coming from the unit as if it is trying to select the disc, but no disc is selected.
welcomejee
  • 10594 Answers
SOURCE: Rotary table on Sony CDP-CX225 200 disc changer will not rotate
I think CD Mechanism needs service and might required belts replacement.
You need to get service manual of your CDX-C225 model to do this job as manual contains all technical info about mechanism etc.
Posted on Nov 07, 2008
SOURCE: worcester bosch highflow 400
Sounds like a control panel.Detatch the block connector that serves the gas valve,see if you have power on the bare pins.both left and right pins should measure mains voltage.If you have no power at the pins its the pcb control board.Replace the board.
Posted on Nov 24, 2008
SOURCE: M&S Systems MC602 Master Unit and M&S MCD6 6-disc CD Player
mc 602 system---volume stuck on 32 and not playing main speaker
Posted on Dec 22, 2008
SOURCE: 2004 GRAND CHEROKEE 10 DISC C/D CHANGER MALFUNCTION.
It fixed it's self,the next day the changer was working normal.the battery is weak and going to be replaced.so maybe the problem was low system voltage." IT'S A JEEP THING " ???
Posted on Feb 06, 2009
  • 3 Answers
SOURCE: 5 disk cd changer is flashing and cannot select
I also had this problem, but found the solution here... http://www.fixya.com/support/t358730-blaupunkt_idc_a09_5_disc_cd_problem
Give it a good whack...
I did it, and then hit the eject button and the CD came right out. After that, it worked just as it should.
Posted on Nov 27, 2009
Bmw x5 cd changer no disc
absolutely no idea ,do you have anything else plugged in that could cause the sound cut off although you say the radio works?or has a plug come loose in the back of the radio ,you could try one of them radio fitting centres as you never know some young lad comes out presses a button and it all works as you had the mute on or something but the radio works ,is it a built in cd player or a remote unit ? in my time a 8 track was the in thing these modern things are welll beyond your ancient dinasaur here .
Jan 30, 2014 | Cars & Trucks
I have a sony 400 cd player and the lights come on, but the carousel won't move. When I press any button the button will light up but nothing happens. The blue light flashes all the time. Also, the door...
sounds like your loading mechanism is jammed up. I would take the cover off, and look in the back where the cd's load to play and see if you can see anything out of place.
Dec 04, 2013 | Sony CDP-CX400 400-Disc CD Changer
CPU freezes on boot up
try reset CMOS.or re-wiring the electrical wires,make sure they are seated tight.
Jul 24, 2013 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Hey guys, I've just installed a CD changer in my car - having some difficulties getting it to work. After some Googling I came across this forum so I figured I'd see if any of you guys know where I'm...
there should be a small connector on the changer itself for the power ground and remote wire for power to the changer unit. the cord coming from the unit to the changer doesn't supply this power and this is why it wont eject and also your head unit wont recognize it until it gets powered up and able to communicate with the head unit and then it will show up as a selectable source when switching between sources of music. check the back of the changer for a small connector containing 3 or 4 pins and you should have a connector with the corresponding wires coming from it to plug into this spot after connecting the wires properly. if you bought it on ebay it is possible you didn't get this piece which is critical when connecting this changer.
Apr 03, 2011 | JVC CH-X1500 12-Disc CD Changer
My cd changer wont play, it sits there for a minute then rotates the slots and then says "no disc"?
from your description it could be the laser unit
try to clean with a clean disc
if it will not help it might be the laser unit
Nov 04, 2010 | Sony CDP-CX450 400-Disc CD Changer
I have got a rca 5 disc changer rp 8055c it want play my cd
RCA 5 DISK CD PLAYER AND RADIO CANT HERE MUSIC LIGHTS COME ON CD PLAYS BUT NO SOUND.
HELP
Aug 16, 2009 | RCA RP8078 5-Disc CD Changer
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 14, 2009 | iLO CA3000V CD Player
Wurlitzer one more time vinyl
How iwll it not play? Does the carousel rotate? Is there no sound? Does the red light flash? etc.
Jun 24, 2008 | Wurlitzer Jukebox 1015 One More Time...
No sound
Hi Margie,
I suggest checking the connection between the head unit and the cd changer for starters.
Cheers,
Matt Coyote
Feb 19, 2008 | Xtreme Sound WMS6100RW 10-Disc CD Changer
Sound only coming from one side
you should have 3 leads going into you multi changer, two rca's and one bus lead. power up the unit and remove the first rca cable if the music goes off unplug the second rca and plug the first rca where the second was plugged in, if the music comes back on then the multiloader is working fine and you need to check the radio controller and its connections
Nov 06, 2007 | Sony CDX-646 10-Disc CD Changer
42 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
