Question about Video Game Consoles & Games
810 ah 3006 bolt disassemble - Video Game Consoles & Games
I have problem with Aficio 220 Ricoh Japan machine and fault is like this SC541 (Fusing thermistor open A level) please help me. my email is auk270@gmail.com
Verify your fusing lamp or thermofuse and replace it if necessary
If your circuit is correct, replace the power supply unit
Don't forget reset code :
Enter SP 5-810 (SC code
reset) and select "1". Then hold
down the Photo mode key and
the 7 key at the same time for
at least 3 seconds (this does
not require the main switch to
be turned off and on).
Jul 07, 2011 | Ricoh Aficio Colour 3006 Color Copier
How does one replace charmglow burner tubes on my
most of it yes to get too, the parts you wish to replace
Jun 14, 2010 | Brinkmann Charmglow 810-7400-S Propane...
How to change the battery in a 2000 venture
1. Remove the rubber hood gasket at the base of the windshield along the car-right side by pulling up on it
2. Pull up and remove the triangular plastic shield in the car-right rear corner of the engine compartment
3. Remove the rear bolt on the large diagonal bar holding the fuse box
4. remove the two front bolts on that diagonal bar, and the other nearby car-right bolt holding the front of the plastic shield to the front rail
5. Pull up and right on the large bar and fuse box to position it out of the way to expose the battery
6. remove the bolt and spacer at the rear lower base of the battery
7. first remove the negative battery cable (8mm), then the positive cable
8. pull the battery out
9. swap the thermal cover onto the new battery, remove protective terminal caps (if there), and reverse the procedure to reinstall the new battery. Always install the positive cable before the negative to avoid welding your wrench to the car.
Nov 06, 2009 | 2001 Chevrolet Venture
Psp 3006
i bought a psp 3006 from singapore but its software and games are not avalable in india....from which site i should get the games??????
Apr 20, 2009 | Sony PlayStation Portable (PSP) Console
EEpsonstylus photo 810
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. If you want to have a go at doing this yourself, the 810 service manual can be downloaded from here:
http://www.mediafire.com/?m6ouftizois
Aug 15, 2008 | Epson Stylus Photo 810 InkJet Printer
Ricoh 3006
go to service program 5-810 ( sc reset) press on, turn off the machine an the turn on again. The service code should be gone, if it come back again check for a paper jammeed or wrapping the upper
fusing roller if this is not the case replace the thermistor;
Good luck
Vittorio
Dec 21, 2007 | Ricoh Aficio Colour 3006 Color Copier
Video Game Consoles & Games Logo
20 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
