Question about Asko Dryers
Where can I get instructions for an Asko dryer model T720
  • 3 Answers
Posted on Dec 30, 2016
  • 135 Answers
SOURCE: Our Asko dryer (T720) has
Usually the drum rollers wear on that model making a thumping noise. The asko is a tough machine to work on. You may need a technician to service it.
Posted on Aug 02, 2008
abhishek33
  • 1239 Answers
SOURCE: Asko T720 clothes dryer -
hi
The drum of the dryer is usually turned by a motor-and-belt assembly. There are two very clear signs that the belt is malfunctioning: You can easily spin the drum by hand when the dryer is off, or you hear a heavy thumping sound coming from the drum when the dryer is running. Here's how to test and replace the drum belt:
Step 1: Locate the belt by removing the back or front service panel. Depending on the type of dryer you own, you may have to prop up the drum to keep it from sagging. Don't let the drum hang; the bolts that hold it in the cabinet could be damaged. Don't remove any more parts than necessary.
Step 2: Identify the belt. The old belt may be threaded around the idler pulley and motor drive shaft. Draw a diagram showing how the pulley is installed so you'll be able to replace it properly. If the old belt is worn or frayed, but not broken, leave it around the drum as a pattern for positioning the new belt; cut the old belt and remove it when the new belt is in position.
Step 3: Remove the old belt from the pulleys and stretch the replacement belt into place. The new belt must extend around the dryer drum and the pulleys. The trick is to align the belt on the drum with the pulleys -- the ribs on the new belt go against the drum.
Step 4: Once the belt is aligned, turn the drum by hand, if possible, to make sure the belt is tracking. You may have to reassemble part of the cabinet to do this.
Posted on Sep 13, 2008
  • 28 Answers
SOURCE: Asko T720 Dryer with a wobbly, thumping drum.
you probaly have problems with rollers in front of the drum.
Posted on Jul 27, 2009
  • 28 Answers
SOURCE: start button does not work on our Asko t720 dryer
if you get a light on the main power switch, then it might be overheat cut-off switch wich has been activated. This is located outside on the back of the machine. a rubber button aprox in the middle, you must push this, and hear a 'click'. it might be a solution.
ginko
  • 19396 Answers
SOURCE: Unable to obtain Service Mabual
Hi.
Here a T700 series service manual for $6.99.
Here generic Asko dryer service manual for free.
Regards.
Ginko.
Posted on Jan 12, 2011
Where can I get operating instructions for an Asko dryer model T720
https://www.manualslib.com/manual/210614/Asko-T720.html
Dec 29, 2016 | Asko Dryers
Asko dryer T720 doesn't stay running when start button pushed
Bad contact on the unit's relay would be my guess, but I don't have a schematic handy to confirm.
How to change the belt on dryer
CHANGING THE DRIVE BELT
1. Remove the top cover and the rear panel.
2. T720/780: Remove the external fan housing.
3. Remove the special tool.
4. Remove the belt from the belt pulley and take off the belt.
5. Feed the belt over the drum onto the motor shaft and over the belt pulley.
6. Install the special tool.
7. T720/780: Replace the external fan housing.
8. Replace the rear panel and top cover.
_____________________________________________________
REMOVING THE TOP COVER
1. Remove the three T20 screws at the rear of the top cover. (Keep the two star washers.)
2. Tilt the cover and pull it backwards.
25758001-gtkp3url2ghtdqenstp5bokb-1-0.jpg REMOVING THE REAR PANEL
1. Remove the top cover.
2. Unscrew the centering nut until the face of the nut is level with the end of the thread and knock out the bearing.
3. Fit the special tool (part no. 88 011 54) by fitting the tube end into one of the stamped out keyholes in the front rail. Lift the rear edge of the drum and press the drum edge onto the roller.
4. Remove the ground connection (yellow/green wire) from the input terminal block (see pages 8 and 9).
5. Take the cable bundle out of the cable clamp and pull the header block off its terminal pins.
6. Remove the wiring:
T700/T720: R1 a, R1 b, R1 13, R1 14, R1 34 on the contactor.
T760/T780: Ra, Rb, R13, R14, R34 on the contactor and F3 and F4 on the radio interference filter.
7. T720/T780: Remove the hoses to the water tank housing.
8. Remove the centering nut and the eight screws.
NOTE: Do not remove or loosen the screws around the heater housing or drum bearing.
9. T720/T780: Remove the three plastic screws at the lower part of the rear panel.
10. Lift off the rear panel.
25758001-gtkp3url2ghtdqenstp5bokb-1-5.jpg 25758001-gtkp3url2ghtdqenstp5bokb-1-20.jpg
25758001-gtkp3url2ghtdqenstp5bokb-1-27.jpg REMOVING THE EXTERNAL REAR FAN HOUSING
1. Remove the top cover and rear panel.
2. Unclip the external rear fan housing suction side.
3. Unscrew the 10 mm nut on the external rear fan wheel and remove it.
4. Lift the external rear fan housing motor side and pull it toward you.
Dado
Jun 23, 2015 | Asko T701 Electric Dryer
How to replace belt on asko t701 drier
1. Remove the top cover and the rear panel (see page 26).
2. T720/780: Remove the external fan housing (see page 32).
8. Remove the centering nut and the eight screws._____________________________________________________
Dado
Sep 22, 2014 | Asko T701 Electric Dryer
The dryer will not stay on the hot setting for very long, it will shut itself off after about 5 mins. it will stay on for the other 2 heat setting but not the hot setting. please help
You need to check your high limit switch with it located on the vent pipe on the back of the system. The limit switch is saying that your Dryer is getting to hot when it may be or may not be. Most of the time it is not getting to hot. Just when it notices heat it will shut itself off. The other thing that i recommend is that you clean your lint trap and vent pipe all the way to outside.
Jan 02, 2010 | Asko T720 Electric Commercial Dryer
Start button does not work on our Asko t720 dryer
Jul 07, 2009 | Asko Dryers
Our Asko dryer (T720) has begun to make a heavy thumping noise, even if empty. (Sounds like a single wet & heavy object is in dryer)
Aug 01, 2008 | Asko Dryers
Dryers Logo
27 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
