Pro scan TV plcd5092a-b will not turn on - Televison & Video
Problem with Proscan PLCD5092A-B I replaced the main board with no luck :
Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Dec 30, 2016 | Proscan PLCD5092A 50 in. LCD HDTV
My proscan tv model plcd5092a won't turn on the green light comes on for about 5 seconds then goes red
probably a bad capacitor. if it cant hold the charge it will not power up the screen. it could have a blown fuse too. a local computer shop should be able to check them and even replace them. and they should be cheaper than best buy too.
Apr 02, 2015 | Proscan Televison & Video
EEPROM for proscan main bd c12090002 mod plcd5092 a- b
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 20, 2015 | Proscan PLCD5092A 50" LCD TV 1920x1080, 60...
My PLCD5092A-B tv power button comes on but no picture no sound
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 21, 2014 | Proscan PLCD5092A 50 in. LCD HDTV
How to turn off closed caption
Unplug your tv from the wall (AC Plug) for 10 minutes. The set should revert back to default settings. This can also be done to your cable box/ direct tv box/ dish box.
Jul 29, 2014 | Proscan 50" LCD HDTV PLCD5092A - CURTIS...
My tv have problem power supply
If you cant turn the TV ( power indicator ) off after it comes on, then thats a good indicator that the Main Digital Board is bad. Thats usually the board with the HDMI connectors on it.
Jun 26, 2014 | Proscan PLCD5092A 50 in. LCD HDTV
Tv shut off while in use,and will turn back on
Try unplugging it and leaving it unplugged for about a minute. The plug it back in and try turning it on.
Nov 04, 2013 | Proscan 50" LCD HDTV PLCD5092A - CURTIS...
How to unlcock proscan tv model # plcd5092a
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help.
Apr 07, 2013 | Proscan 50" LCD HDTV PLCD5092A - CURTIS...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
