Question about Watches
How to adjust time dial - Watches
Setting Time on Police Hammerhead Watch PL 13088 JS/02
the three dials are for three different time zones, there is no minutes or seconds.
to adjust the middle dial just push the small bottom which is located on the back side of the watch
Jan 04, 2013 | Police hammerhead pl13088js-04
I cant change the day on my mimco sportivo watch
The big nob comes out two clicks. The 1st click is the date and time. Press the top button above the big nob to adjust the month. Then turn the big dial anti clockwise to adjust the day of the month.
The second click on big nob
Is to adjust the time it's self. Hope this helps.
Dec 26, 2012 | Watches
I have a Cerruti watch 61191, can any body tell me how to set the date dial on it???
You pull the knob for time-adjustment but only pull it half-way. Pulling it all the way lets you set the time, and half-way through lets you set the date.
Apr 17, 2010 | Cerruti Men's Blue Dial Automatic Watch
Date dial is not moving when adjusting. No problem when you turn the dial in full turn to adjust the date.
The date dial is turn by two mechanisms. By turning the crown one set of wheels are engaged to change the date but when the watch is running or the time is being set another set of wheels is used to change the date.
Because it will not change on it's own when the watch is keeping time the wheel that is supposed to turn the date needs to be replaced.
A qualified watchmaker can do this for you.
Hope this helps.
Ken Kotoski
Yellowstone Watch Inc.
www.yellowstonewatch.com
Feb 15, 2010 | Tag Heuer Link CJF2114
I have a seiko chonograph couturo alarm. 100m
Many of the Seiko Chronographs have the same setting options (mine is the lightweight "Titanium Sports").
First off, the alarm dial must show the same time as the actual main dial. If not you must adjust this first.
Pull the knob at number 4 position on the watch face out, until you feel two distinct notches/clicks (around 0.5mm travel) and the alarm will make a shrill buzzing for about 1 second.
Now turn the #4 knob to move the small alarm dial at the #6, to be the same as the actual time displayed on the main face, and press the #4 knob fully back in. This sets the alarm and the main time to the same ....er....time. You do not need to do this again, unless you adjust for daylight saving times during summer/winter.
Now you can set the alarm chime point.
Pull the #4 knob out again, but just one click. You should hear one ping from the alarm. Now press the button at #8 position. It will move the small alarm hands by 1 minute intervals, and if you keep it held in, the dial spins around quickly. This allows you to adjust the time the alarm will chime.
When you've got the alarm time and it's chime point set, leave the #4 knob at one click out.
If you wish to switch the alarm off simply press the #4 knob back in, and the alarm dial will spin around to the same time as the main dial.To re-enable the alarm pull the #4 out one click again. It's quite simple once you get the hang of it.
Jan 01, 2010 | Seiko Coutura Chronograph Watch
I have a chronograph watch with a white and a red
The trick is to pull out the stem 2 times and use the plugers to adjust each of the dials. Some watches have 3 dials and you have to pull out the crown 1 time or click and use the plungers or buttons to adjust the other dials.
Nov 18, 2009 | Watches
Hi i have just recieved a pocket watch but cant work out how to adjust the time.
There should be a button on the top that opens the watch, under this is a dial, you lift the dial not the button, there should be a click and the watch will stop, then swivel the dial to set the time.
Dec 24, 2008 | Colibri Colibori Swiss Made Elite Quartz...
Adjusting Date and day on a Festina 3 dial watch
Alhamdulillah, the problem solved (at last) tks to IRONMAN (http://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this :
1. Pull the crown full, and turn it clockwise until you find the right day.
2. and then push it one click (dont push it to hard so it back to normal position) and turn the crown counter clockwise to adjust date.
3. Push the small button near the crown to adjust month.
and voila... the problem solved
Sep 05, 2008 | Festina 161625 Wrist Watch
SECTOR 450 TIME ABJUST
when looking at the face of the watch, the "dial" to the bottom-right is actually a screw-in, screw-out dial, it is not a push dial. Unscrew it until it is freed from the screw AND THEN pull it out two clicks, adjust time as needed...
Apr 21, 2008 | Sector 450 2653450035 Wrist Watch
Watches Logo
15 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
