Question about The Watches
I have the hour hand set but the second hand is not moving
VOTIT
  • 2071 Answers
SOURCE: hour and minute hands dont move, second hand does
You better go to a watch service center to replace depected parts ,the problem of your watch is a broken center wheel,need to replace with a new one with identical size and caliber,so its works normal again.
Hope it may help you;
Regards;
VOTIT
Posted on Apr 23, 2009
SOURCE: My watch second hand does not move an hour after accidentally falling from a 2 feet high cabinet.
MY SECOND HAND WONT MOVE ON MY ESQ WATCH
Posted on Dec 17, 2009
  • 299 Answers
SOURCE: how do i set the the 24 hour hand in a rolex 16758
Yours is the original GMT Master. The GMT Master II allows the GMT hand and the regular hour hand to be set differently but not on your older model. On yours, the regular hour hand the the GMT hand are fixed so that if the triangle on the rotating bezel is at the top, the GMT hand will indicate local time. To indicate time in a 2nd timezone, rotate the bezel to orient the time to the GMT hand. There's a copy of the original instructions posted at: http://www.rolexforums.com/showthread.php?t=45269
Posted on May 01, 2010
  • 5370 Answers
SOURCE: I cannot get the sweep
Try this procedure to set date:-- • Unscrew crown counter-clockwise (toward you) to position 0. • Pull crown out to position 1. • Turn crown counter-clockwise* to set date. • Push crown in and screw-in until tight. (clockwise - away from you). * NOTE: By turning crown clockwise with crown in position 1, the alarm hand will move. --------------- Try this procedure to set time:-- • Unscrew crown counter-clockwise (toward you) to position 0. • Pull crown out to position 2. • Turn crown to set hour and minute. • Push crown in while screwing-in clockwise. (away from you). * NOTE: Do not set date between 9 p.m. to 1 a.m.. --------------- WHILE CHRONOGRAPH IS RUNNING:--- 1. Minute chrono dial records minutes. 2. Hour chrono dial records up 12 hours. 3. The sec dial displays split sec when chrono is stopped. -------------- If nothing is helping then you can try to set the watch manually:--- IF CHRONOGRAPH HANDS DO NOT RESET BY PRESSING BUTTON B while watch is in stopwatch mode, they can be reset manually. Chronograph Second Hand. • Unscrew crown. • Pull crown to Position 2. • Push Button A (upper one)until hand is reset to proper place. Chronograph 1/20 Second Hand. • Unscrew crown. • Pull crown to Position 2. • Push Button B (lower one)until hand is reset to proper place. ----------- Check out.Keep updated.This should help.Thanks.Helpmech.
Posted on Jan 18, 2011
  • 6 Answers
SOURCE: hour hand does not move
Loose cannon pinion or cannon driving wheel, depending on model of movement inside the watch.
The seconds hand represents the wheels in the back of the watch going around ok, but the power need to transfer through to the front of the watch somehow. This is done by snapping/clicking two wheels together on either side of the main plate. The one on the dial side (cannon pinion) needs to slip to be able to set the time as the minute hand is set on this pinion. From there it is one wheel to the side & then back into the centre for the hour wheel. Over time the mating surfaces wear & become loose, meaning that the two hands driven fron the front of the watch are not being carried anymore. Time to see a repair guy!
Posted on Feb 15, 2011
Second hand is stopped, hour hand moves in oposite direction, behaves like second hand.
Peet you need to take it to an expert to fix this problem. The watch is complex. save it.
Dec 08, 2013 | Casio Edifice Watches
Set date on omega seamaster quartz 1425
When you pull the crown (winder) , you will notice it has two positions (two clicks). The first click is for quick date setting, the second click is for time setting (moving hands). Second click can be use for date setting as well, but for this you need to move watch hands forward for 24 hours to pass 12 o'clock.
Feb 25, 2011 | Omega Seamaster 300M wristwatch
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Citizen AT03060-50E,i bobught online kind cheap than showroom so still am confused that it is original or not.. my chronograph second and minute hand stops after 1 hour,the small chronograph second hand...
The chronograph will only run for 59 minutes 59.95 seconds.
If you do not have a set on instructions for your watch, you can find one on their web site (citizen.com)
When there, click on "technical support" and the on "setting instructions" and fill in the number off the back of your watch.
Feb 01, 2010 | Citizen Eco-Drive BL5184-56L Wrist Watch
I have a Aerospace model watch and am having difficulty in adjusting the digital time to be equal to the minute and hour hand time.
Its best to change on the hour.Stop your watch so that the second hand is pointing to 12.
Move the hands to the time i.e 10am then advance the minute hand 5 mins past the hour, then turn it back to 10am, when the time comes push set and your hands are set.
I think you might have not moved the minute hand forward 5 mins and back.
You can now set your digital time from your hands setting.
Oct 22, 2009 | Breitling Aerospace Avantage E7936210/G606...
Changing the hand time only w/o changing the digital time
For Casio Waveceptor:
--- A
( ) Button Reference
--- B
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
Good luck,
Techjoel
May 10, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
Instructions for casio wave ceptor 4303
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 06, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
18 people viewed this question
Top The Watches Experts
John mullen
D. E. Hev
 Larry
Larry
Are you a The Watch Expert? Answer questions, earn points and help others
