Question about Alcatel Cell Phones
Alcatel one touch SIM card hot plug alert & phone has been deactivated error messages. How do I fix it?
Received a message on the phone "SIM card hot plug alert" then the next message was "phone has been deactivated," now what do I do to fix these errors? Can't call, send or receive!
  • 6 Answers
SOURCE: Insert SIM card error
screw loose or sim card sockit loose when u press it its work after loose it gave same problem. one of the free sagason is take a paper turn it and adjust this middel of sim and battery
Posted on May 03, 2008
Yazz226
  • 497 Answers
SOURCE: text msgs go to sim card memory instead of phone memory
go to message main menu scroll to 'message inbox' press menu key again , scroll down to 'message setup',press select. scroll to 'text message set up ' press select . in the new menu it will show u 'store to phone , sim' in that option select phone
do update me if u require more assistance
Have a nice day!
Thanks for using Fixya!
Posted on Nov 25, 2008
SOURCE: Error sending messages
i had the same problem and i could not find any source to solve it. At the end I found a way to solve this naked problem. I put the the simcard to another mobile and send a message to any number and it was sent. And then ı had delete the mobile center number and retype again and save. And then take sim card out and put it in the Iphone... The happyy End.. :)))) its start to sending the messages... HURRAYYYYYYYYY :)))))))))
Posted on Dec 29, 2008
SOURCE: Sidekick 3 wont receive text messages but can send them.
ok i have a sk 2008 and the samething happend to me, what i did was just turned of my phone took out my batter and sim crd and let it chilled there for a min...then i put it all back together and my phone started flooding with texts...i think a sidekick can get clogged up with texts..i also think that the battery can over heat and thats what causes some problems..so when ever i have a prob with my kick i just take out the battery and let it cool down :] ok hope i helped
Posted on May 24, 2009
  • 25 Answers
SOURCE: my htc will not send
It may be an error with your carrier's high speed data network. Try the following:
Go to MENU>SETTINGS>WIRELESS&NETWORKS>MOBILE NETWORKS>NETWORK MODE
Then change the settings from GSM / WCDMA auto to GSM only. Note that these two options may be different because different carriers helpfully call their various features different things. Basically take the phone off the "auto" mode and set it to use the slowest network setting possible (in my case GSM). You should notice your signal bars increasing immediately. This should also allow you to send texts etc normally. If the problem persists then as ever, take it back to the shop and tell then about your problem again.
Posted on Mar 06, 2011
Testimonial: "thanks"
Tip
Nokia Tips
`Your Nokia cell phone can be programmed to pick up radar speed traps, when programmed your cell phone picks up the radar and alerts you on the message alert tone. 1. Enter your menu 2. Select settings 3. Select security settings 4. Select closed user group 5. Select on 6. Enter 00000 7. Press ok 8. Clear back to normal, within a few seconds your phone will display a radar sign with five zero's next to it. It is now activated. Unfortunately only Nokia phones have this function. Cell info display needs to be de-activated. Settings -> Phone Settings -> Cell Info display Each time you turn off your phone, or even each time you loose contact with your carrier, you´ll have to activate it again... It is done by steps 1 through 5, but the number (00000) will be already on the field as default. If you put the number 500 in the closed user group, and you go out of a store with detection ports thy will go off. Firmware version: *#0000# *#51x0# or *#9999# View Serial No., Date Made, Programming Date, Repaired: *#92772689# Thanks to Ben-Dov for this code IMEI (International Mobile Equipment Identity) Code: *#06# Enhanced Full Rate (EFR): *3370# to activate EFR. Makes calls sound better, but decreases battery life by about 5%. #3370# to deactivate EFR Half Rate Mode (HFR): *4720# to activate HFR. Decreases call quality but increases battery life by about 30%. #4270# to deactivate HFR. Default Security Code: 12345 Warranty Code: *#92702689# [*#war0anty#] asks warranty code. You can then type a number of codes (Thanks to Mike Pfaff for these codes): 6232 - Display date of manufacture 7332 - Display date of last repair 7832 - Display purchasing date 9268 - Display serial number 37832 - Set purchasing date to MMYY 87267 - Confirm Transfer, Related to firmware upgrades #746025625# says SIM CLOCK STOP ALLOWED or similar, depending on your SIM card. Newer SIMs have a feature called 'clock stopping' that allows the phone to save energy -- it is a kind of sleep mode for SIM cards. Not all versions of software support this. You cannot turn the SIM clock on and off, the phone will do it automatically if the SIM supports clock stopping.
on May 20, 2010 | Cell Phones
Tip
Nokia
1. Enter your menu
2. Select settings
5. Select on
6. Enter 00000
7. Press ok
Firmware version:
*#0000#
*#51x0# or
*#9999#
*#92772689#
*#06#
12345
Warranty Code:
on Dec 09, 2009 | Cell Phones
Nokia c5 wont deactivate offline then says insert sim
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Oct 24, 2012 | Nokia C5 Cell Phone
Nokia E5-00 deactivate emergency only
HiFirst remove your battery from your phone and reboot it by inserting battery as well as sim card.before Menu appear a message will prompt like " Continue Using without Sim Card" ? just press no .Or when the phone is in normal mode (standby) Go to Profile >> and Activate the General.Good luck
Feb 08, 2012 | Nokia E5 Cell Phone
Icon identification on text messages inbox
it means the message saved to your SIM card, not your phone.
May 06, 2009 | Samsung Gravity SGH-T459 Cell Phone
Phone locked
WARNING: ALL CONTACTS AND OTHER SETTINGS MAY BE LOST DURING THIS PROCESS!!!
Method:
Before you start, make sure the battery is charged and all security codes or PIN codes or watever are disabled so we dont have any code prompts interfering with this method.
1. Turn off the mobile phone.
2. Insert a "Non-accepted" SIM card (sim card that wont work) half way in so that when you turn on the phone, it still says "Insert SIM".
3. Turn on the phone.
4. Enter the following code and wait patiently for phone to reset:
*2767*2878#
5. Once reset has completed, the phone will still say "Insert SIM". This is where you need to push the sim card all the way in. You can use a paperclip or a tiny object to push it in if you have difficulty. IT IS IMPORTANT THAT THE PHONE REMAINS ON AT THIS STAGE (TRY NOT TO LET BATTERY FALL OUT) IF BATTERY FALLS OUT, DO NOT PANIC, JUST START FROM STEP 2 AGAIN.
6. Enter the following code and wait patiently for phone to reset:
*2767*3855#
7. After reset is completed, SIM should work and also the reception. Don't get excited, its not unlocked yet.
8. Now we want to make it permanent. First check what locks need to be deactivated with the following code:
*#7465625#
a)
If Network Lock is "Active", put in the following code:
*7465625*638*00000000*00000000#
Message should be "Network Lock has been personalised" or similar.
Then:
#7465625*638*00000000#
Message should be "Network Lock deactivated" or similar.
b)
If Subset Lock is "Active", put in the following code:
*7465625*782*00000000*00000000#
Message should be "Subset Lock has been personalised" or similar.
Then:
#7465625*782*00000000#
Message should be "Subset Lock deactivated" or similar.
c)
If SP Lock is "Active", put in the following code:
*7465625*77*00000000*00000000#
Message should be "SP Lock has been personalised" or similar.
Then:
#7465625*77*00000000#
Message should be "SP Lock deactivated" or similar.
d)
If CP Lock is "Active", put in the following code:
*7465625*27*00000000*00000000#
Message should be "CP Lock has been personalised" or similar.
Then:
#7465625*27*00000000#
Message should be "CP Lock deactivated" or similar.
e)
If SIM Lock is "Active", put in the following code:
*7465625*746*00000000*00000000#
Message should be "SIM Lock has been personalised" or similar.
Then:
#7465625*746*00000000#
Message should be "SIM Lock deactivated" or similar.
Apr 29, 2009 | Samsung J700 Cellular Phone
SMS read receipts
You can deactivate it by erasing unsend messages from your outbox and that's all. You will not prompted again for that.
Jan 08, 2008 | Nokia N95 Cellular Phone
Nokia N73.Incoming message alert gone..No tone,vibration,message envelope
Follow this steps in the given order -
1) Switch off your phone
2) Remove memory card
3) Switch on your phone
4) Ask a friend to send you a message. Now you will hear the tone
5) Switch off, insert the memory card & switch on again
6) Ask someone to send a message again. It will work
Nov 07, 2007 | Nokia N73 Cellular Phone
Cell Phones Logo
1,469 people viewed this question
Top Alcatel Cell Phones Experts
Gene
D. E. Hev
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
