Question about Health & Beauty
My Casada back massaging cushion has started making a loud knocking sound when I lean on it... It is on the left side of the cushion when my back is against it. How to fix or do I just ignore...
SOURCE: My washer machine is making a knocking sound
Therer is a ribber gromet at the bottom of the drum , this gromet wears out , we had ours replaced with anewer version and is fine now
Posted on Jan 21, 2007
  • 88 Answers
SOURCE: New 14 seer split ruud heat pump makes very loud knocking noise
Well you may want to have a tech come out and check the freon level, but mostly when going into defrost, some units make alot of noise, the freon is reversed in the unit by way of the reversing valve, it makes a whooshing sound like freon is draining off, as far as the knocking noise, could be as I said in the beginning, might be low on freon, but it could be that, this particular unit does this, I have had units make some really strange noises in the past but functioned perfectly, hope this helped, please let us know, thanks again,
Posted on Jan 24, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile Knocking
Unplug and closely examine the area for a loose fan blade or anything that may be causing the noise. Better now than to get damage that could be prevented. Let me know what you find, Thanks, Sea Breeze
Posted on Mar 23, 2009
  • 1136 Answers
SOURCE: makes loud knocking noise under refrigerater side
Hi, Does this noise accure when the compressor is shuting off?
Posted on May 12, 2009
  • 1627 Answers
SOURCE: 2001 dodge durango 4 wheel drive not working loud knocking
You need to check the cv joints in the front end or the u joints in the front drive shaft.If none of the above then the problem is internal in the front diff.
Posted on Jan 28, 2010
What makes my truck knocks when i cranked it up a loud pop sound and then it started knocking
comment on petrol or diesel
in any case have a compression test done to check for mechanical failure
Sep 25, 2015 | 2008 Ford F-150
Hi yesterday i was using my homedics cushion . I had it set on shiatsu and i was controlling whereit went. I accidently pushed roller full...well it startd to go upwards and then started making clunki
mine did that and I tried turning it on and let it run through the cycles with no pressure on it. then it found its own track again and started working ok, but I am very careful with the controller now. Hope it helps.
Oct 13, 2017 | Homedics Quad Roller Massaging Cushion...
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
My loyale starts and runs ok, but makes a terrible noise, coming from the engine area. It sounds like a very loud knocking, clicking, sort of sound. It doesn't seem to affect the running of the...
hi a loud noise like the one you described can really only be a few things, either the main engine bearing is getting worn and is on its way out or you have a damaged or dirty lifter. The main difference between the two is the bearing will sound like a knock or grinding noise and the lifter will be more like a loud tick from either the left or right head on the motor you may just have to listen carefully to tell but it is possible and they will both speed up with the engine rpm. A bearing will usually cause problems running/starting/idling etc so maybe lean towards a lifter if it is damaged it will need an expensive replacement but try an oil change first as this can also free up dirt etc and solve the prob
Jun 02, 2011 | 1991 Subaru Loyale
Knocking sound from wheel well
it sounds like you have a bad cv axle on the drivers side.
May 14, 2009 | 2006 Chevrolet Impala
The power led light keeps flashing
Give it a good 'knock' on the back (hard surface). You might hear a clink sound. I think it's when a cog gets out of line. My chair is fine now. You'll notice that the rollers start moving back to the off setting. So if it goes off and they are in the middle or top then it's stuck and needs a thwack!
Dec 01, 2008 | Homedics SBM 300H Therapist Select Shiatsu...
Faulty Homedics SBM 300H Therapist Select Shiatsu.
My mom had the same problem so i unzipped it from the back, and once i started to take out the padding i saw that there was a wire unplugged so i plugged it back in and it worked!
Nov 27, 2008 | Homedics SBM 300H Therapist Select Shiatsu...
Electrical issues
If you are not fimiliar with electronics repair then I would have to say take it to a repair shop. You can check the cord and make sure it was not frayed, Also make sure it was plugged in completely to the wall when you give it a try. If the cord is frayed you can take it to any electronics store and buy a new one or order a new one online.
Dec 19, 2017 | Panasonic Health & Beauty
Health & Beauty Logo
49 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
