Question about Dryers
Why does some automotive toggle switches have just two prong for power and some have three for power and ground. Is the ground necessary when what you're wiring is already grounded?
    Master:
  • Dryers Master
  • 469 Answers
The switch with two prongs is a single-pole, single-throw switch; it is either on or off. AmanStino Lightning Cable Apple MFi Certified 1M Nylon Braided Charging...
Posted on Jan 05, 2017
    Problem Solver:
  • 7 Answers
The switch with two prongs is a single-pole, single-throw switch; it is either on or off. The switch with three prongs is likely a single-pole, double-throw switch. That is, it controls two circuits but only one can be on at a time. For instance, it could control a two-speed fan with one position being low and the other being high. The "ground" you speak of is the common terminal and may or may not be connected to ground. You can find more information by searching for SPDT and SPST switches on Google.
4-prong to 3-prong Power Cord Conversion.
On a 4-prong power cord you have 2 hot wires, one neutral wire, and one ground wire. On a three prong cord, you have 2 hot wires and one neutral/ground wire. The difference is the on four prong the neutral wire goes to electrical neutral bus in the breaker panel and the ground wire goes to the ground bus in the breaker panel. Since the neutral and ground buses, although separate, both go to physical ground, on a three-wire setup, you are just putting the neutral and ground wire together, Most dryers actually have a place at the pigtail connection to do just that.
Sep 09, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I just had my pioneer AVH-P6300BT installed in my car and when i went to put a dvd in, the sound worked, but i couldnt see the movie. also i filled a USB with pictures i thought i could upload?
Just ground the parking brake wire (turquoise), get a TWO prong toggle switch. Splice it and connect each end to the toggle prongs. Every time you watch a video just toggle the switch on/off once and you will be able to see video.
Jun 15, 2011 | Pioneer AVHP7490DVD Car DVD Player
Don't know how to switch from 4-prong to 3-prong power supply
Your new 3 prong power cord needs to be wired up just like the 4 prong you just dont have the seperate ground . in the use of a three wire cord ground runs thru neutral .Hook black to black on the terminal block on unit. hook red to red on the other side of block and white to white or green in the middle reinstall the cover ....Plug in and your ready to dry
Aug 14, 2010 | LG DLE2532W Electric Dryer
How can I bypass the parking brake wire?
You have to connect the ground wire and the parking brake to get pictures
Apr 16, 2010 | Pioneer Car DVD AVH-P6600DVD Car Video...
Want to switch electrical cord on a whirl pool dryer. from a four pronge to a three pronge
In most all cases, the 4 prong plug has to lines of power, one line neutral, and finally a ground. The only thing you can do is eliminate the ground. You still need to run a ground wire from the unit to some sort of positive ground for safety reasons. Do not leave the unit ungrounded. You can really get hurt or worse.
Apr 01, 2010 | Whirlpool GEW9200L Electric Dryer
Wiring on a 3 speed rotary switch for a fan (cord type),the switch just broken and i want make a connection on wires for just to run at only one speed.
put the 2 white wires together then try one of the other wires from the fan to the black power wire,if to slow try the other wire if that speed works tape off the other wire . it should be white to white and red to black green is ground
Sep 03, 2009 | Patton U2-1487 Floor / Box Fan
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
Four prong plug to three prong plug
Kalola,
You can if you want to, but it's not generally necessary. Here's a picture of a 3 prong configuration with a ground strap...
That green wire with the yellow stripe is a ground and it is most definitely connected to the cabinet somewhere. So it will serve as the ground strap (in the above picture).
Here's the thing... say you were going from a 3 prong to a 4 prong. That is, the dryer was originally "designed" for a 3 prong. This means you'd have to "retrofit" it a bit. Take a look at this pic... ( I made this for someone else, so please disregard my somewhat hostile remarks, OK?)
The ground strap has been removed and has been replaced by the ground to the frame. Yours probably does NOT have a ground strap, though... yours uses that Green/Yellow wire for frame ground.
All of that to say this. Don't lose sleep over it. Ya done good.
SG
May 01, 2009 | Maytag Neptune MDE6800A Electric Dryer
Switching electrical plugs
it sounds as if your plug configuration is for 220 volts. that means that all wires are needed to operate the unit. white is the common and red and black are both power leads. in other words...the red lead provides 110 volts and the black provides 110 volts, and the white is the common for both circuits. and of course the ground is for curcuit safety
to change to a three prong plug the ground must be sacrificed but with shock risk. i suggest a seperate ground wire run to an adequate ground.
a typical three prong plug will mean that the two prongs closest to the edges are the two power leads and will use the red wire on one and black wire on the other.(doesn't matter which one goes on which prong)
the white will go to the center or usually odd shaped prong. be sure and be safe!
hope this helps.......................jay
Mar 20, 2009 | Bosch Nexxt 800 Dryer
Headlight willnot come on in 1994 isuzu P/U, however brights work
one of those three prongs sould be ground, one should only come on with the high beams, and the other only with the head lights. if all three have 12v power you have a short somewhere.
Mar 20, 2009 | 1991 Isuzu Pickup
Dryers Logo
43 people viewed this question
Top Dryers Experts
