My Amanda furnace blows hot air then shuts heat off then a/c kicks on
    Master:
  • 946 Answers
Does it have one of those thermostats that switch AUTOMATICALLY from heat to cool? Might be programmed to kick on at too close a temp. don-ohio
Posted on Dec 31, 2016
Testimonial: "No, no automatic thermostat."
  • don-ohio Dec 31, 2016
    Describe the type of thermostat you have? don-ohio
Furnace will not kick on. air will not kick on
check thermostat setting. make sure unit is on! when u say "air will not kick on"? are you saying the heated air is not blowing out? if no hot air, there is no heat to blow out! fix furnace!
Oct 05, 2015 | Heating & Cooling
After furnace shuts off fan keeps running and blows cool air for while before shuting off
Check the AFC AUTOMATIC FAN CONTROL is not blocked with fluffon the back of it , you can remove this and check the back of it .
Mar 15, 2013 | Heating & Cooling
Fasdfas
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
Jun 08, 2017 | Heating & Cooling
House heater does not blow hot all the time. the furnace kicks on and then shuts of and then the blower just blows cold air. the furnace tries to kick on three times but shuts off, sometimes it works just...
When it blows cold air, there should be an error code blinking on the LED light located on the PC board. Look through a small viewing port in the front panel, then remove the front panel and on the reverse side there should be a diagnostic code chart to help you figure what is wrong.
Mar 15, 2011 | Coleman Heating & Cooling
I have a Dayton Furnace Serial# swglm033942 and need some information; My furnace is installed in the attic and sometimes it will not blow hot air. I have tried to start it and the burners start up, but...
Please have this checked out by a technician. If there is a crack in the heat exchanger it could do just as you described. The blower blows air into the combustion chamber and blows out the burners.
Jan 07, 2011 | Dayton Gas Furnace Heater
Furnace will not blow hot or shut off
The furnace has a fault check the furnace compartment for a flash code and check it with the code chart on the furnace door. Turning the power off to the furnace and turning it back on will reset the fault but it may happen again till you verify the fault and fix it.
Feb 22, 2010 | Heating & Cooling
Furnace has a mind of its own
If your thermostat no longer controls your furnace possibly could be the control board in the furnace or a shorted fan relay.
Jun 10, 2009 | Dometic Rooftop RV Air Conditioner
Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Nov 29, 2008 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
