Question about Pocket Watch Watches
How to replace battery in my pocket watch - Pocket Watch Watches
2 Suggested Answers
SOURCE: to replace battery of pocket watch
My son has a Timex pocket watch-I just got the back off with a very tiny flat-head screwdriver- the niche or indent you're looking for is almost indiscernible; look very closely, the edge of the back barely deviates from where it meets the edge of the front piece. Looks more like a flaw than an intentional point of entry
Posted on Nov 20, 2008
What size battery is in a phillip crow pocket watch
Pop the back off the watch with a pocket knife and look, they use so many types of small button batteries it is hard to say, better to look at it and record the battery number.
Nov 23, 2016 | Pocket Watch Watches
Do new James Michael pocket watches come with a battery?
Yes, if it is of the battery type
Movement Type
The movement, or inner workings, of a watch are what make up the main timekeeping mechanism. This mechanism measures the passage of time and displays the current time and other information including date, day and month. These movements can be entirely mechanical, entirely electronic or a combination of the two.
Mechanical movements, such as hand wound or automatic watches require winding in order to run. An automatic watch uses the force of gravity to constantly wind itself. Automatic watches have a greater consistency of power and therefore can be more accurate.
An electronic watch employs the use of a tiny quartz crystal that vibrates in the presence of electricity. This type of watch is powered by a battery and their time is regulated by the tiny quartz crystal. This is why most electronic watches are also called quartz watches. Solar powered watches convert energy from light into electricity which is then stored in a rechargeable battery. These watches do not need to have the battery replaced as long as they are regularly exposed to a fairly strong light source.
Kinetic powered watches use a combination of mechanical and electronic elements. Usually a weight rotates with the motion of the wearer?s arm which turns a generator to supply power. It is similar to an automatic watch except that electrical power is generated by the mechanical motion.
Men James Michael Pocket Watch
Jun 19, 2016 | Pocket Watches Watches
On my diesel DZ-4108 I changed all of the batteries and the hour and minuet hands are working, but the digital display is not working the batteries are brand new but on digital display what can I do?
I just figured this out. When you replace the batteries, there's the white plastic cover secured with two screws. Remove them and you'll see an area with two exposed 'pads' that says 'reset'. Simply touch them together with a paperclip, screwdriver or whatever and the watch starts right up. :)
Jun 15, 2012 | Diesel DZ4108 Pocket Watch
Hi, My mom left me a Coleman Pocket watch 40-344 and I would like to know where i should take it to, and replace the battery, and value to insure it..Thank you Sandra Lopez
Hi....Sandra any jelery store that sells watches should be able to replace the battery for you as for value this is a quartz movement watch and does not hold a great deal of value sorry if this is a dissapointment but coleman has not been produceing pocket watches long enough to be a collectors item yet
Jan 30, 2011 | Watches
Need to replace battery of lorus mickey mouse pocket watch
Try to find a watch repair shop (sometimes called clock & watch shops). Also, many jewelers replace batteries and do watch repair.
Jan 13, 2011 | Lorus Watches
I have a pocket watch i bought in paris but the battery ranout and i cant get the back off to get the battery out. what should i do?
Hi Josh, I do apologize for the inconvenience.Please try the below steps which should be helpful for you to remove the back of the watch and also replace the battery.
  1. Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
    (OR)
    Find the small groove on the back of the watch right above the hinge,place the tip of the screwdriver (the small kind used for the screws in glasses) into the groove and gently pry off the back of the watch.
  2. Remove the circular watch battery out of the back of the watch.
  3. Take the battery to any department store or watch store and purchase a new replacement battery.
  4. Insert the new battery into the back of the watch.
  5. Screw on or push on the back of the watch. Set the watch to the correct time.
The above should be of help for you to have the battery on the pocket watch replaced and have the watch working once again.Best wishes for your effort and thank you for your time and patience.
Nov 12, 2010 | Fossil VT2654 Pocketwatch
Need to replace battery in my Colibri pendant watch. Can't figure out how to open case to change it.
Thank you for contacting FixYa.
  • Place the tip of your pocket knife in the slot on the back of the watch. Pry the back off.
  • Take your tweezers and grasp the metal piece that is hiding the battery.
  • Once that metal piece is out the battery should come out too.
  • Put the new battery in and cover it with the metal piece.
  • Put the back of the watch back on and snap it into place.
  • Best wishes. Jewel
    Oct 04, 2010 | Colibri PWS-95877-N Pocket Watch
    I have a Majestron quartz pocket watch. How do I replace the battery?
  • Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
  • Remove the circular watch battery out of the back of the watch.
  • Take the battery to any department store or watch store and purchase a new replacement battery.
  • Insert the new battery into the back of the watch.
  • Screw on or push on the back of the watch. Set the watch to the correct time.
  • Aug 23, 2010 | Watches
    Replaceing battery for colibri pocket watch
    Hi, replacing battery can be found on amazon, take a look here: Rayovac Batteries Lasts as Long Costs Less. Wish you best of luck.
    Aug 26, 2008 | Colibri PWS-95877-N Pocket Watch
    To replace battery of pocket watch
    May 29, 2007 | Fossil VT2654 Pocketwatch
    Watches Logo
    13 people viewed this question
    Top Pocket Watch Watches Experts
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Rabbit Brains
    Rabbit Brains
    Are you a Pocket Watch Watch Expert? Answer questions, earn points and help others
