Question about InFocus Office Equipment & Supplies
Hi, my infocus IN122 projector is not projecting anything. the power lights up solid blue. then the temp/lamp blinks pink. A new lamp replaced it but the problem is still there. what could be wrong?
tvtechnician
  • 105 Answers
SOURCE: Both the LAMP/COVER and FAN/TEMP indicator lights come on, not blinking
with both lights solid. according to the manual all it says is (there is an electrical failure inside the unit, please take to an authorized servicer). if you are able to do this yourself you will need the schematics and a voltmeter to start testing your voltages. your lamp is fine so dont waste your money replacing that anymore. if you would like the service manual send me an email to fixya@markservicepro.com.
Posted on Oct 30, 2007
SOURCE: Projector gives off pink tint
when you have a tint on the projector its not a lamp issue, it is a connectivity issue you have to check the cables if they are connected firmly, or swap the cables with good known cables , if this doesn't help you have to send the projector to infocus repair center, since it is a DLP projector this may require engine /major repair
Posted on Aug 14, 2008
  • 221 Answers
SOURCE: lamp replacement
if the lamp warning light is lit steadily, the lamp is at fault. if the lamp warning light is flashing, the ballast (lamp power module) is at fault
Posted on Oct 31, 2008
projdoc
  • 2237 Answers
SOURCE: Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Posted on Mar 09, 2010
Testimonial: "Of all the comments on lamps failing to power up, only this answer fits my circumstances. I eliminated other "solutions" posted on FixYa. Thanks!"
SOURCE: Lamp
lamp duration
Posted on Jun 12, 2010
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    I have an Infocus 5000 projector that we have just tried to replace our 2nd brand new lamp. Each time we attempt to replace the lamp we get no picture and the red light blinks once so often. At first when...
    be sure and reset the lamp hrs. But you really need to make sure you haven't pushed the lamp connection in the lamp housing out of its cubby hole. I've seen this alot, the connection gets pushed in and when you think you have the lamp in, it's not really connected. Really the only way to check this is to remove the top cover. Before you do this though, one other thing that can happen is the lamp door gets mishapen due to the heat from the lamp and can cause the thing that pushes against the safety switch when the door is on not to depress it fully. you can power the unit up while holding the switch in with something non conductive to see if it is in fact the lamp door. anything beyond this is likely the power supply/ballast being defective, or the blower fan in the right rear of the unit not working.
    May 21, 2010 | InFocus ScreenPlay 5000 Multimedia...
    Infocus X1 Projector started with 3 blinking red lights.
    Its due to lamp Ballast power supply is faulty,it need to repair or replace otherwise again it will damage Lamp so be careful
    Mar 09, 2010 | InFocus X1 Multimedia Projector
    InFocus ScreenPlay 4805 no projection. Unit powers on and green light blinks, but no light and no fan, eventually red light blinks continuously about 2 seconds between blinks. When the green light is...
    the high-pitched sound is the colorwheel trying to spin up to speed. that may need to be replaced. check the inside of the lamp for bulges, black spots, fogging or flaking. if it has any of those, replace the lamp. you can get parts from an infocus service center or send it to them for repair. either way, try www.avsolutionsny.com they're really good. if you want to replace it yourself, there is a detailed step-by-step on my "tips" area. it's the same as the infocus x1, x2, x3 and sp4805. click on my picture and scroll down to tips. good luck!
    Feb 01, 2010 | InFocus ScreenPlay 4805 Multimedia...
    Wont light up
    the colorwheel needs replacing. if the colorwheel won't spin, the lamp won't light. if you hear a high-pitched whir, the colorwheel works, which means there is a power supply issue. there is a fix for that, but you have to be good at soldering. if you are give it a try: http://www.infocus.com/service/asc/communications/tech_notes/2006/09/tn495g.pdf
    Oct 05, 2009 | InFocus LP70+ Multimedia Projector
    Infocus X3, no light, LED is solid green.
    the colorwheel. if it does not spin, the lamp will not light.
    Aug 26, 2009 | InFocus Proxima UltraLight X350 Multimedia...
    Projector shuts off within 30 seconds of power on
    is the led lit on the top of the projector? what colors?
    green is ok.
    red flashing in sequence:
    2 times- lamp hours exceed 200 hrs. replace lamp.
    3 times- lamp failure. replace lamp.
    4 times- fans not working. remove obstruction or replace fan.
    5 times- temp too high. clean thoroughly.
    solid red- undiagnosed error by projector. possible power supply or ballast.
    also make sure the lamp door switch is working.
    Aug 07, 2009 | InFocus LP 820 Multimedia Projector
    Projection screen is pink
    it's the resolution and input issue. make sure that the settings are correct and the resolution matches. then make sure the cable is fine.
    Jul 30, 2009 | InFocus LP1200 projector lamp Projector...
    SP-LAMP-LP3E powers off in 5-20 secs after inital power on
    if the new lamp doesn't have a problem, then it's not the ballast, it's just a bad bulb. especially if you didn't get it from infocus. the cheaper lamps don't last long. you get what you pay for.
    Dec 23, 2008 | InFocus Projector Lamp for LP340, LP340B,...
    76 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
