How do you replace the STROBE INDICATOR PILOT LAMP on a music hall usb 1
Music volume low when digitizing vinyls
The software itself should come with an sound imput level control. But if you can't find it or it's on full then there are ways round it. However it depends on how the turntable is connected to your computer. Most turntables require in an amp to have a magnetic cartridge pre-amp to boost the level to that say of a tape. Rather than mess around sometimes it's better to get one of these pre-amps and have that between the turntable and the computer. Then the sound should be the same level as a tape signal. You will have to bypass that pre-amp if you are recording anything else such as tapes to your computer. Or you will get a noisy loud signal!
Just search for a "magnetic cartridge pre-amp" on the web.
Jan 31, 2014 | Music Hall USB-1 - turntable
Pilot light problem
Most power lights are line voltage, i.e. 12v power=12v lamp, 120v power=120v lamp. Get a voltmeter and see what voltage is goin' to the lamp. Once you have determined that,, 12v lamps are easily found @ auto parts stores. 120v @ Radio Shack or electronics supply stores.
Dec 29, 2013 | VOX AC30HW2X Amp Combo
We have bought a battery charger HB 1206S DC6V - 12V 6AMP, but it does not state what is the state of charge do the lightes go out when it has reached changed state or light up please help
Product Detail Model No.: HB-1206S
The item is used for charging 6V-12V lead-acid batteries
Max Charging Current: 6A
AC Power Input: 64W
Output: 6/12V DC 3. 52A
Batteries Capacities: 15AHR-80AHR
Unit Packing: Colorful box
Dimension: 18cm x 10cm x 20cm
G. W. / N. W.: 1. 85KG/1. 75KG
Certifications: GS, CE, BS, ROHS, SAA
Main functions:
(1) The HB-1206S battery charger has the features of convenient operations, reliable safety and high performance.
(2) During charging, if turn up overload, the battery charger will keep itself at normal current and normal voltage with its self-automatic protecting function.
(3) If being short circuit, the battery charger will switch off itself, and turn normal after one or two minutes.
(4) The output current of the battery charger is very stationary, so it can protect the battery charger very well. It only costs 3 or 4 hours to fully charge the batteries.
(5) Indication of charging: the battery charger has 6 pilot lamps. The more pilot lamps shining, the less electric quantity is. The charging process finishes when all the pilot lamps go out.
(6) The battery charger can be switched between 6V and 12V, so it can charge for 6V and 12V accumulators. You can select 6V or 12V according to your own needs.
(7)The operations are very convenient: Put the red clip to the positive pole of the accumulator which indicated "+", and put the black clip to the negative pole of the accumulator which indicated "-", then plug in power source, the accumulator will be charged.
Aug 02, 2011 | GPS
Pilot light not workimg
. You light the gas escaping from the tube, and it burns all the time.
Mar 11, 2011 | Ovens
I can see a smaal current going trough the bulb but it doesnt fire regularly
It is important to understand how strobes work. A capacitor is charged to around 300 volts through a high value resistor. When the bulb is triggered, the capacitor charge drives the lamp with a high burst of current as the lamp breaks down with plasma. The lamp is USUALLY triggered by a very fine wire around it or one end that recieves a several thousand volt pulse from a trigger transformer that creates a field near the electrodes within the flash lamp. This field starts the gas in the tube breaking down which causes the plasma to form.
Typically you should see the voltage across the lamp build up to around 300 volts DC. You would need special instruments to see and measure the high voltage pulse that triggers the flash.
The usal cause of failure is degradation of the flash tube due to sputtering of the electrodes at one end. If you see a blackening near one end of the flash tube, time to replace the flash tube. DO NOT handle the glass of the flash tubes as skin oils can degrade them. If the bulb shows no blackening, possibly the triggering is not working. NO current flows through the flash tube until triggered, however there would be a small current charging the capacitor that is in parallel with the tube to build it to around 300 Volts DC.
Nov 06, 2010 | Chauvet Mini Strobe
How do I get the strobe light on the Mobilite 300 to stay on continuously?
You can't get the strobe light to stay on continuously, the strobe is a very high voltage discharge lamp which can only illuminate briefly.
But the unit does have a built in modelling lamp at far lower power and intensity, used only to set up the lighting rig and to check for shadows and highlights. As long as the unit is connected to mains voltage then you just use the power switch to turn the modelling lamp on.
Oct 07, 2010 | Cameras
Faceplate LED's
Below is the list of Pilot lamp replacement parts
If you need the owners manual please send me your email
Thx
Change all Pilot lamps to the improved listed in table below. ReplacementNumber Part Name Part Number Remark 1 Pilot Lamp 1-517-181-12 Green 2 Pilot Lamp 1-517-181-22 Amber 3 Pilot Lamp 1-517-181-32
Oct 02, 2008 | Car Audio & Video
Itunes and pilot
The whole point of the Pilot is to avoid the tether to iTunes. I'm not sure you can really sync with iTunes but you can easily copy your music to the player. The path in Windows to the iTunes music library is usually under the My Music directory under iTunes\iTunes Music. I created a folder on the Pilot named iTunes Music and copied all the folders under the iTunes Music folder on my laptop to the Pilot folder. Playlists are also supported but if you create the playlist file in iTunes you may need to convert it to m3u format. You will also want to go into the settings and set the USB mode to File & Folder.
Jun 02, 2008 | Insignia Pilot MP3 Player
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
