Stuck on 1 minute to go sounds like water still coming into the machine
Hoshizaki water dont stop runing
float switch is stuck in the "down" position. The unit goes thru a fill cycle and after 1 minute, the board "Looks" at the float swith to "see" if the sump is full. If float is stuck down, it tells the board that the unit does not have enough water and stays in the fill cycle. The compressor will not come on as long as the machine "thinks" there is not enough water. let me know if I can help further
Aug 02, 2012 | Hoshizaki Freezer Commercial Ice Machines...
I have the CFW-8000 washing machine. When the
It sounds like the timer showing 1:09 is the time in minutes (109 minutes = 1 hour 49minutes) which is approximately the same as your own timer shows.
The soap dispenser often gets blocked and you will have to remove it and clean away all the residual, built up soap.
It sounds like the drain plug in the base of the unit has become blocked and that is why the soap dispenser is filling with water. All the water SHOULD DRAIN THROUGH the dispenser when it washes the soap down into the washing machine.
Also sounds like your water or fabric softener is blocked too!
Take the plastic parts out and clean away all soap residues.
Nov 18, 2009 | Crosley Washing Machines
The machine Steams ok, But no coffee or hot water comes out! I turn on the coffee switch, the maker busses, but nothing comes out!
I had this same problem with mine and was able to get it fixed. Here's what I did: There is a water pump that can get stuck from not being used for a while, especially if you have hard water.
Unplung from power & allow the machine to cool completely. I carefully took the machine apart and follow the tubing to locate the pump (mine was about 2-1/2" to 3" long X 1/2" diameter. Remove the pump, disassemble it and carefully clean all the parts. You will probably find 2 parts that are stuck together (I found a plunger & check ball that were stuck from water drying out in it).
Sep 10, 2009 | Coffee Makers & Espresso Machines
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
Cup stuck and will not come out
put a little water around the base of the cup and give it a few minutes. Almost funny. LOL
Jun 30, 2009 | Cuisinart Cup-O-Matic SS-1 Coffee Maker
Final Spin Cycle gets stuck at 1 minute
back tub bearing,,and spin surport,,defective,,,under warranty,,,call for service..onthejob
Dec 10, 2008 | Frigidaire Affinity ATF7000E Front Load...
LG Model WD-80130F - Water not draining out
The pump is usually located under the unit, attached to the motor or belt driven. If not sure, it should have two 1 1/2 inch hoses attached to it. Something may be stuck in it or the bearings maybe wore out & it needs replaced. Pumps are not that expensive. Powder detergent will wear them out faster also!
Apr 15, 2008 | Washing Machines
you have probably flooded the base of the machine and it now is in flood mode take side panel off and have a look and drain water away common fault
Sep 25, 2007 | Hoover 24 in. HD98E Built-in Dishwasher
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
