SOURCE: Humax 8000T not used for a while, now says
sig strength 29 is too low to lock onto. Humax needs 50+ to lock ideally 65+
is the aerial ok? try the set on someone elses aerial. If no joy then its possible the tuner is duff...but thats virtually unheard of.
its down to the arial i had same problem
SOURCE: no input 2 signal
The connections bad.... try rewiring the one for signal 2 or if its making a good connection... look for a weak spot in wire... that helped me when i couldn't figure out wiring
Testimonial: "Big help. Many thanks"
you need to get a digital aerial first .then you can sort out any other problems from there
