Question about Hotpoint Washing Machines
How to open front loading hotpoint machine when timer stuck
VtToolMan
  • 704 Answers
SOURCE: timer gets stuck on frigidaire front load washer
It appears that your timer is failing. The process to remove and replace the faulty timer is relatively easy to do with just some simple hand tools.
You should unplug the washer from the wall outlet before taking the top backsplash (control panel) apart. There are screws on the backside of the control panel, that you need to remove the back panel. Doing this will let you get to the wiring plug connector on the timer motor.
You'll also need to remove the timer/cycle knob on the front of the panel so you can use a socket (or a adjustable wrench) to remove the mounting nut and lock washer that holds the timer to the metal panel.
Once you have everything loose and accessible, all you need to do is unplug the connectors on the old timer and out them on the new timer and reinstall the lock nut and washer and button up the panel.
That shoud be all that's needed to get things working again.
Here's link showing a drawing of your washer along wtih the parts list (and prices) for parts.
The timer is part #134378400 and costs about $89.00
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FTF530ES1&productCategoryId=0153200&brandId=1428&modelName=WASHER&diagramPageId=00001&componentDescription=CONTROL%20PANEL&documentId=R0509003&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Posted on Aug 22, 2009
Testimonial: "Thank-you for the help I'll lt you know if it works after replacing timer. scott"
  • 278 Answers
SOURCE: rinse cycle gets stuck
Most models have a timer relay that times out when a cycle is over. It may be located behaind the front panel - It's worth a shot
Posted on Oct 15, 2009
  • 149 Answers
SOURCE: Front loading washing machine door is stuck, won't
press hard on door to free handle do code means door sw. not made or bad
Posted on Jan 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: Duet GHW9150P Front Load Washer: how do we open a whirlpool front loading machine w...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
  • 6277 Answers
SOURCE: I have a hotpoint ultima Problem
Hi Kim again from retired Englishman in SW France,
Athough I do not know your exact model I suspect that it is the filter cover- it's in the right position. It's a bit unusual to have it red, though. Maybe it's a warning that water can come streaming out!
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 09, 2011
Good Morning, my name is Ian. My Hotpoint Washing machine has been strong and reliable since I moved into a rented property 1 year ago. I placed a load in on a long wash, and within an hour all the lights...
It sounds like it could be the timer, but I'm not sure. I would go to a Hotpoint site and you might be able to talk to a tech or tech-support there.
Mar 05, 2015 | Hotpoint Washing Machines
Rinse cycle gets stuck
Oct 15, 2009 | Washing Machines
Washing machine isn't moving beyond first setting
your machine is waiting at the thermostop position on the timer till its hot enough as per thermostat/timer temp setting,its probably faulty element or faulty stat ,id check the element first,it should have approx 20 to 35 ohms depending on wattage of machine,check element connections and heavy connection wires at timer for any burnt connections-hope this helps
May 14, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Keeps filling during wash cycle
If the machine des not stop filling and cycle hang in position, then it is a faulty water level switch.
If the machine does not stop filling , and the cycle goes on, then test that the inlet valve is not stuck in open position, if the inlet valve is OK, replace the timer control assembly.
Mar 07, 2009 | Hotpoint Ultima WD72 Front Load...
Timer delay displayed permanantly and beeping
the button is not stuck in is it? sometimes they get a bit sticky in kitchens.
Nov 11, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint bwm129 gets stuck mid cycle and dial does not move round
YOU NEED TO ESTABLISH IF YOU ARE USING A HOT CYCLE IF THAT IS SO YOU MIGHT HAVE E PROBLEM WHERE THE ELEMENT IS NOT COMING ON THEREFORE THE THERMOSTAT WILL NOT FUNCTION RESULTING IN THE TIMER REMAINING STILL.YOU NEED TO CHECK THE ELEMENT IF THATS THE CASE.IF YOU ARE USING THE COLD CYCLE AND IT IS STUCK ON THE SAME POSITION FOR A LONG TIME YOU MIGHT HAVE A FAULTY TIMER BEST YOU HAVE IT REPLACED IF THAT IS THE CAUSE.LET ME NO IF YOU NEED ANY MORE ASSISTANCE.GOODLUCK.MOHAMED
Sep 15, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint bwm12 intergrated washer drier
BEST YOU GET A TECHNICIAN ITS E VERY HARD JOB TO OPEN A STUCK DOOR CATCH.GOODLUCK.MOHAMED.AND ITS NOT CAUSED BY COIN DAMAGE ITS JUST WEAR AND TEAR ITS A ELECTRICAL COMPONENT THAT CAN MALFUNCTION AT ANY TIME
May 31, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint WF340 - wont complete programme
hi without looking at it i would think that the control board behind the timer knob has broken down these can quite pricey so shop around before you buy one,hope this helps.
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint first edition
UNPLUG THE APPLIANCE - Hi sorry about the delay - the door needs to lock before anything will work - So - Either the door lock is faulty or the circuitry to the door is faulty.
The door lock is not too difficult to replace. Engineers reach it by going through the front ( where the door seal connects onto the front panel)
The lock connects directly to the Timer/circuit board so if it is not the lock it will be the timer board.
Hope this helps
Mar 16, 2008 | Hotpoint First Edition WMA20 Front Load...
Hotpoint WF865 Drum getting stuck?
I THINK IT MUST BE A LOOSE COIN,STUCK IN MOTOR
Feb 08, 2007 | Hotpoint Ultima WF865 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
