Question about Refrigerators
My LOGIK freezer seems not to freezing in the middle draw
2 Suggested Answers
  • 43501 Answers
SOURCE: I have a Hoover D42UF fridge freezer that isnt
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Posted on Apr 21, 2010
DEFY C305 combi top fridge bottom freezer FAULT:freezer operates ok, but fridge is running hot.
do you mean that your fridge is not cooling and freezer just freezes up ?
Nov 06, 2017 | Refrigerators
My logik freezer wont freeze
Hi, the motor (compressor) is not working, or the gas is not circulating properly due to a blocked choke ( A much thicker short section of the piping housed at the back of the body) or the gas is leaking out, probably by now there is no more gas in the pipes. But first check to see and hear if the motor is working when switched on.If the motor does run, then it is definitely a gas circulation problem due to the two mentioned above facts. Only the repair man can help in any one of these circumstances
If there is a gas leak, then you will have to buy a new present day modern freezers are too labor intensive to strip down to access the piping in order to repair an internal leak. If the leak is external then it is easily repairable.
Hope i have been of help
Good luck
Sep 10, 2014 | Logik LFC55W13 White 200 l Fridge Freezer...
Fridge partly freezing at top and bottom , middle staying neutral, why?
Check your evaporator fan motor also make sure there is no obstructions such as plastic bags blocking air flow.
Aug 02, 2017 | LG Refrigerators
Ice collects on the bottom of my frost free woods freezer
im not sure if i answered this one before. but this sounds like a blocked drain, the drain is located midway behind the shelves, you can take away the catch tray and poke a coat hanger down this hole hole to dislodge the blockage.
Nov 10, 2009 | Woods 201 cu. ft. Upright Freezer V2003RW3
I have a hoover frost free fridge freezer,the freezer seems ok but the bottom of the fridge is freezing all the goods,can you help
you could have set the temperature too low.
adjust the tempearature in the middle section and if it would still freezes the bottom part, use the minimum setting and see if it will make a difference.
tnx 4 using fixya,
Oct 24, 2008 | Refrigerators
Fan is a big issue. New problem though.
good day!first and foremost, in most freezers, the highest freezing point is regards with the water dripping from the air vent hole, you have to minimize your your freezing setting to the middle.turn it to 3 or 4 freezing point.
Aug 22, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
Kenmore refrigidaire, bottom freezer
It depends somewhat on the quality of ice cream. Some brands freeze easier than others. One reason is cheaper brands have more sweetener/sugar in them.
I think if your freezer is freezing water into ice cubes, it should freeze ice cream of good quality.
Try putting the ice cream where the ice cube tray is and verify ;this.
Mar 31, 2008 | Refrigerators
Candy fridge freezer
check that the correct thermostat is installed and that the element wire is connected.check door rubber and door hinges.check if it has independant defrost timmers and if it is working.oh and see if the element is drawing current if fitted with one.
Nov 05, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
