Question about Plumbing
Well water pump seems to not be working. I can hear the switch clicking on, but not the pump.
Up down Tilt switch doesn't seem to work. can hear solenoid clicking. If I keep pressing the tilt switch, it can barely activate but struggles and is intermittent.
I would guess the system has a leak and you got water inside the unit . they will not pump water worth a darn .
Oct 05, 2015 | Boating
I have a Biasi Riva Advance HE Combi Boiler. The pilot light and fan dont seem to be working, I can hear a click when I run the hot water tap and a click after I turn tap off,
Have you bleed the air from system and run hot water and heating at the same time , bleed the pump . you could have air in the pilot after turning it off
May 01, 2017 | Water Heaters
Hi I have a Bosch WFL226 MAXX. The wash programmes seem to work OK - the motor operates the drum and the pump works fine and drains the machine. The water level vacuum switch seems ok (it stops it...
Bosch WFL226 MAXX This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 21, 2010 | Washing Machines
Hotpoint WT761 washing machine - Error code F-10 The machine is filling with water, then signalling F-10, then pumping the water out. So the fill solenoid and the pump are working OK. If I set the machine...
Thats strange, F10 means no cold fill.
Ok back to basics, you can check the pressure switch by taking off the tube and gently blowing into it and I mean gently, you should hear a click if its ok - make sure the other end is'nt blocked, blow it out with a cycle pump near the drum end
Sep 19, 2009 | Washing Machines
Washing machine clicking and flashing code F-30
The F30 code refers to a failure of the dispenser motor. The clicking you were hearing was probably the dispenser motor switch going on and off trying to activate the dispenser motor
shaun
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drain problem
Could be a pressure switch problem. If the switch doesn't know it's empty, it will keep trying to pump. Remove top and locate switch. There's a small hose going to it. Remove the switch and blow in it see if you hear a "click". Also blow through the hose and you should hear bubbles or clear air into the tub. Put switch back on and try again. If no sucess, repl. pressure switch.
Apr 09, 2009 | Kenmore 43142 Front Load Washer
Bosch Exxcel Auto option
There should be a float switch inside the dishwasher sometimes these get hung up on the full position which in turn keeps the solenoid from allowing the water to come on. remove the bottom rack and check to see if this is the case. Dislodging the float should fix the problem. If not listen to see if the solonoid Clicks when you turn the cycle to fill position if not it could be either solonoid or the timer. if you hear click and still no water check strainer in water line could be clogged or water is turned off some where.
Oct 19, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Machine wont spin or empty
Mar 21, 2008 | Washing Machines
Plumbing Logo
81 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
