Cant get the time from changing to I hr behind. there is a simble on the top left itcomes on after I set the clock atles 1 hour later
adib
  • 450 Answers
SOURCE: Calendar times advance 1 hour when sync
Check daylight savings time on the laptop
Posted on Sep 14, 2005
SOURCE: Centrios Atomic Desk Clock/Temperature
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
Posted on Jan 28, 2008
  • 6 Answers
SOURCE: setting time after power been uplugged for 1 hr
I had the same problem with my Sony Dream machine of not being able to set the time after a power outage and finally figured out the sequence. Unplug power chord, plug in, then press the set time button holding until the 12 flashed, then up and down to the hour is set, then press the set time once, then the minutes flash , then set minutes, then press set time once. You seem to only get one chance for this, then if you make a mistake , you must unplug the chord and repeat the sequence. Why you cannot reset the time after setting it once, I have no idea. But I finally found at least a solution for my problem.
Posted on Jul 23, 2008
SOURCE: time not correct
press mode button once.
Then press set until the time zone is on the correct setting
then press mode again
Posted on Jan 05, 2009
SOURCE: Change watch setting from 24 to 12 hr clock
my 40/6703 has 4buttonstop left-light topright-st-stp bottom left mode bottom right reset can u help
Posted on Jan 31, 2009
I want to change the time from military to regular, but my bose does not have clock set just and arrow to the right and left for time
The manual is available at Bose.com and page 17-18 shows the detail.
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
May 02, 2011 | Bose Wave Radio
How to set the clock on a 2004 saturn vue
1. Turn on car
2. Push "clock" button
3. Wait until HR (hour) flashes
4. Look at the "tunes" button at the top right
5. Turn the "tunes" knob (yes, it turns!) left to lower the time or right to raise the time.
Repeat for the minutes
Good Luck!
Mar 15, 2011 | 2004 Saturn VUE
I have a bell f20 bicycle program...i have been trying to set the time...can someone tell me how to set the time without erasing everything on the program...
Click on the right side of the red button until you reach the clock (after SCAN). Hold down the left side of the red button until you see "12 HR" click--choose "12 HR" or "24 HR" (24 HR is military time). Click on the right side of the button to select the hour and change with the left side to change the hour. Click the right side of the button to change the minutes. Finally, click the left side of the button to move away from the clock. Other settings are intact.
Nov 15, 2010 | Cycling
Need to change the clock in my jimmy and dont know how,,theres no manuel
I found this solution already was answered by: chavezemail
Rank: Wiz gmc.gif Expert
Rating: 87%, 24 votes
Owners manual: 3-10:
Setting the Clock for Systems with HR and
MN Buttons
Press and hold HR until the correct hour appears on the
display. Press and hold MN until the correct minute
appears on the display. To display the clock with the
ignition off, press RECALL or HR/MN and the time
will be displayed for a few seconds. There is an initial
two-second delay before the clock goes into the
time-set mode.
SET Button
Press SET. Within five seconds, press and hold the
SEEK right arrow until the correct minute appears on
the display. Press and hold the SEEK left arrow until the
correct hour appears on the display.
Jul 12, 2010 | 2000 GMC Jimmy
The digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
Jan 14, 2009 | Maytag MER5552BAW / MER5552BAQ /...
Change Clock - Logitech Pure-Fi Elite
hold the src button left of power along with button to the right power.a model number will appear once it does let it disappear and the unit will go into reset. set the language, 12/hr, 24hr etc and the time. :)
Dec 13, 2008 | Logitech Pure-Fi Elite High Performance...
Setting the clock
Setting the Clock for Systems with the
Set Button
Press SET. Within five seconds, press and hold the right
SEEK arrow until the correct minute appears on the
display. Press and hold the left SEEK arrow until the
and MN Buttons
time-set mode
Nov 13, 2008 | 2002 Chevrolet Silverado 2500HD
Setting the time on car stereo/cd player
Changing the general settings
(PSM)
You can change the items listed on the next page
by using the PSM (Preferred Setting Mode) control.
• The PSM items are grouped into five
categories—“Disp (display),” “Clock,” “Tuner,”
“Color,” and “Audio.”
Basic Procedure
1 Press and hold SEL (select) for more
than 2 seconds so that one of the PSM
items appears on the display.
(See page 23.)
The currently selected
category is shown on the
left side of the display.
2 Press 5 (up) or ∞ (down) repeatedly
until your desired PSM category
appears on the left side of the
display.
3 Select the PSM item you want to
adjust.
4 Adjust the PSM item selected.
5 Repeat steps 2 to 4 to adjust the other
PSM items if necessary.
6 Finish the setting.
To set clock—Clock Hr, Clock Min
You can set the clock using the PSM control.
1 Press and hold SEL (select) for more than 2
seconds so that one of the PSM items appears
on the display.
2 Press 5 or ∞ repeatedly until “Clock” is selected
as the PSM category (it is shown on the left side
of the display).
3 Press ¢ or 4 to select “Clock Hr
(hour).”
4 Turn the control dial to adjust the hour.
5 Press ¢ or 4 to select “Clock Min
(minute).”
6 Turn the control dial to adjust the minute.
Nov 04, 2008 | JVC KD-G720 CD Player
Setting the clock on my pioneer deh 2000mp
1. If the device is on, press and hold the SRC/OFF button until it turns off.
2. Now, press and hold the same button until the hours on the clock blink.
3. Set the hours with the up and down buttons.
4. Switch to minutes with the right button (you can return to hours with the left button).
5. Set the minutes with the up and down buttons.
6. Press the SRC/OFF button.
Jul 02, 2008 | Car Audio & Video
Acqua Indiglo Digital Watch
My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers.
-AP
Dec 04, 2007 | Watches
27 people viewed this question
 Grubhead
Grubhead
