Question about Pool & Spa
I have a BLP155AT propane heater that will not fire. Fan starts gas clicks on(you can also smell the gas) but igniter does nothing. Have replaced igniter. Still nothing.
5 Suggested Answers
  • 9 Answers
SOURCE: HEATER WAS WORKING FINE TILL I HAD PROPANE TANK TOPPED OFF
The Pressure Regulator may be stuck, Try closing the propane valve releasing the pressure,, gently tap the regulator( on the propane inlet side) and Very Very slowly open the propane tank valve, and attempt to light
Posted on Aug 14, 2009
  • 103 Answers
SOURCE: My 40-FAC heater will not ignite and run. The igniter has been replaced. What should I check next?
These models require electrical power to run the blower fan.
When you connect the electrical cord, the fan should turn on, then you should be able to start / ignite the propane. if the fan does not turn on when you connect the power cord, you will not be able to ignite the propane.
Posted on Dec 10, 2014
  • 1631 Answers
SOURCE: New installation liquid propane fueled will not
By all indicators, it appears that you should have ignition! But you do not. First thing that comes to mind, since we are human, and are capable of making mistakes, we also have a tendency to overlook the obvious... Is the Gas Valve of the heater in the " ON " position?
And... is the main gas line gas shut off valve, open?
because you entered into the lockout mode, the heater made three attempts to fire. But since you did not, it appears that it has no fuel to ignite? Check this.
Posted on May 25, 2015
  • 41797 Answers
SOURCE: Master blp155at propane heater. Why does it smell like raw propane and burns your eyes?
Either the heater was installed incorrectly or some element has failed.
Posted on Dec 29, 2015
Reddy heater 75 125000 propane heater. Fan comes on, have spark, smell propane and still won't fire
There are couple possible reasons your unit refuses to fire; some units tjis big have to be level, this is a saftey feature bulit in if it is not level, it will not fire, ( it believes it has been tipped over), the smell of propane could also mean it has a leak on your line connection ( bad fitting, not sealed properly), finally check the temperature sensor may be bad and need replacing......
Jan 21, 2017 | Reddy Heating & Cooling
VERY GOOD "spark" HOOKED UP YOU CAN SMELL THE GAS WHEN YOU HOLD THE BUTTON IN IT WILL IGNITE THE GAS WHEN THE FAN OFF BUT DOES NOT
Possible weak gas flow to igniter may require adjustment, have a qualified gas technician check it.
press the helpful button
Jan 08, 2016 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Dec 29, 2015 | Heating & Cooling
Dec 09, 2014 | All-Pro Propane Garage Shop Heaters - All...
My Hayward H400 will not turn on
Does the heater sound like it is trying to fire? (Fan on, clicking sound). Check your filter pressure. If it is high, it may be causing the heater not to fire because the heater doesn't know the pump is running.
Apr 12, 2014 | Hayward H Series Pool & Spa Heater 400k...
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
Gas is on can hear ignition. Doesn't light. May not have gas to heater. Air in line?
Check also to see if the valve on the gas valve itself is in the "ON" position. Is it on or off?
If it is on, then you may in fact have air in the gas line that needs to be purged.
BE CAREFUL WHEN PERFORMING THESE STEPS!! ESPECIALLY IF PROPANE GAS - LPG!!!!!!
Have a large piece of cardboard or the front cover/door of your heater will suffice.
If solid pipe to heater, then there is a union, if you have flexible gas line to heater then you have a flare nut.
With NO flames or sparks even close - NO SMOKING !!!Carefully & slowly loosen either the union or the flare nut with gas valve open. You will hear hissing sound. Leave open for about 30 seconds, until you smell the gas. Carefully & slowly tighten either the union or the flare. Take the cardboard or door, and fan towards the heater to push away and fan away any gas fumes. Do this for about a minute or so. Very Important you do this, again especially if Propane. Propane is a very heavy gas & it will linger in a "Puddle", unseen puddle near the heater. If you did not fan away these fumes, when the heater starts to ignite - .... not so pretty.
Anyway, if you had air in line, heater should fire. If it didn't try above steps one more time. If it still does not fire, possible bad gas valve.
Dec 16, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
New installation liquid propane fueled will not fire. 120 volts is wired correctly. Checked for lp pressure to valve - is ok.turn switch on and see led blink once then hear igniter "clicking' for several...
You can try swaping the leads (hot and common) If this is a lo nox heater be sure your pipe size is correct. The new lo nox rely's on gas volume as well as pressure. Also be sure your heater is wired for 110v or your spark won't be hot enough with just a 110v feed, but if your getting 24v at the valve that is probally OK.
Jun 25, 2010 | Pentair MiniMax 100 Aboveground 100,000...
Jul 30, 2009 | Hayward H Series
Dyna Glo forced air propane heater
...found out that this is a continuous ignition heater so the igniter is always on.
Sep 22, 2008 | Reddy Heater-30,000 BTU Propane Forced-Air...
Pool & Spa Logo
59 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
