Question about LG Televison & Video
47LW5700-UE.AUSYLHR LG TV shuts down when inputting or configuring the TV from the remote control also the video lags after it warms up. Please help. my email is bobgray@surewest
My TV does a couple of things but the most annoying are the picture stutters/lags and then jumps (as if a sync buffer was waiting for the picture to fill up the memory before it can play) after it warms up after 1-2 hrs of use. It is most noticeable on fast moving objects making the person or thing jump across the screen. The second thing is it randomly reboots and loses any presets since it was last turned on or rebooted. It mostly reboots when inputting information from the tv remote, changing settings or just telling it to scan for channels It almost always goes to factory out of box settings when it is powered up. It only rarely remembers its last settings after turning on and off. This problem may have been partly caused by me having the AC plugged into a remote controlled power strip so that I can turn on all devices associated with the TV at once, your comment here would be helpful as well. I thought that maybe a battery was holding the memory up on the main board when it was turned off and lost its brain once the power was turned back on to all devices, due to the lack of charging power. BOB 916 591 5292
SOURCE: 42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Posted on Oct 07, 2007
SOURCE: set top box and remote control
My remote wasn't working until I programmed it to work with itself ... (how odd it wasn't done already).
"CBL" button and ""OK/SEL" held down simulataneously for 3 seconds ... then "001" for the Scientific Atlanta. If the unit turns off, you're in business.
Posted on Apr 22, 2008
  • 463 Answers
SOURCE: The TV picture stared jumping. Then lines were
If, indeed this is a polaroid clone TV, most probably the fix is a new "control board", at the cost of $400 if TV is not under warranty.
Sorry to not be of more assistance.
Posted on Mar 02, 2009
  • 718 Answers
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
  • 585 Answers
SOURCE: Picture Stutters on HD Channels
Hi my name is Roety,
I can help you with your issue ,
 Sounds like a bad signal issue , check it on other inputs to confirm
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Posted on Oct 20, 2009
Anyone know why my LG tv has the input menu stuck on the screen. it is not the remote and the buttons are not stuck.
Disconnect the television overnight. Remove the batteries from the remote as well. Tomorrow, put new batteries in the remote and plug the television in.
Nov 04, 2017 | LG Televison & Video
LG 42CS560-UE LCD TV turns off by itself Power Supply is New
You must accidentally setup the auto sleep function within 3 seconds interval. Go to the setup page to re-configure no auto sleep interval.
Jul 22, 2014 | LG Televison & Video
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
I keep getting a pop-up screen on my 47LW5700
The TV should be set to factory defaults to clear all the system data stored. To do this, you've to enter its service mode option. If you wish to get more details about how to enter and adjust items in service mode options to LG brand TVs, check this link. Service mode entry and exit methods to several brand televisions are given in detail.
Jun 09, 2013 | LG Televison & Video
TV will not turn on; is there an easy fix?
I had the same problem with a Poliroid tv, and it was 2 capacitors that failed on one of the boards. Any internal fuses (mine had none) will require dis-assembling the tv. If it is under warranty use it!
Jan 28, 2013 | LG Televison & Video
Need codes for Go.Video remote control
Go video remote for dvd/vcr recorder combo; you program TV by 2 digit codes. press TV power down when TV is powered on; and input 11 for JVC TV, or 03 for GE TV. You can experiment any two digit codes until TV shut down, then you have just finished programing n150b remote. This also work for all LG dvd/vcr combo recorder remote such as 6711RN203A..
Mar 08, 2010 | GoVideo Go Video DVD/VCR Combo
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Oct 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv stuck on video
Try with the channel up/down on the TV or look inside the configuration menu, if your set has one.
Feb 15, 2008 | Emerson EWF2004 20" TV
LG 42PC5D Sound Lag
Turn the volume on the TV all the way down. Its becasuse you have the sound come from both sources. its kinda fun to play with.
Sep 24, 2007 | LG 42PC5D Television
Televison & Video Logo
Computer Repairing
Computer Repairing
