Door locked and stays on 1 minute to go sounds like water still coming into machine
here2helpBSH
  • 27 Answers
SOURCE: Bsoch dishwasher runs long and displays 1 minute left on timer
sounds like a bad solder connection on the heater relay of your control unit. more than likely you will need a new control unit. part number 266746
Posted on Mar 19, 2009
SOURCE: Water will not drain. On the timer the door
bad pump impeller
Posted on Nov 02, 2009
  • 246 Answers
SOURCE: when i lock the doors the central locking will
depending on what year make and model your vehicle is there are a few general possible causes. if the dome light stays on the whole time between you locking the doors and it auto unlocking, this usually indicates a faulty door pin switch, where even though the door is closed, the system thinks it's still open. or if it's a newer car there's a possibility the vehicle thinks the key is still in the ignition which could indicate any fault from a bad wire somewhere, to a bad body control module. and it's always possible that your security system module is faulty.
Posted on Feb 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: f21 error on kenmore he2plus washmachine
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
taran_2005
  • 10515 Answers
SOURCE: I have a whirpool sixth
The most common cause of this fault is an open circuit motor.
Unplug the appliance and take the rear cover off.
Check the motor plug for broken wires, give the wires a good tug as they can break internally.
If ok, take the belt off and take out the bolts holding the motor to the tub.
Take the motor out of the appliance and check the carbon brushes.
If they are worn or broken you'll need to change them.
Refit the motor, re assemble the appliance and try the machine again
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 15, 2011
My belling washing machine doorv wont open
from the factory info,,,
door lock is activated because of the water level in the machine.
Drain the water by running the Pump or Spin programme.
• Machine is heating up the water or it is at the spinning cycle.
Wait until the programme completes.
• Child lock is engaged. Door lock will be deactivated a couple of minutes after the programme has come to an end.
Wait for a couple of minutes.
when in doubt unplug for 5 minutes and plug back in and see if that resets the unit.
Hope this helps a little.
Jan 09, 2018 | Belling Washing Machines
Load got off balance, I believe, and now it will not come on.
It sounds like bad electronics or bad sensor, did you try to adjust front door while turning machine on, like push them in. Do water runs in, if not it can be water switch.
Apr 04, 2016 | Washing Machines
The machine shows E07 error upon entering the service menu.
Door latching or lock error
·Door not detected closed
·Check door is closed
·Check door catch and latch
·Check door lock wiring
Check door lock
Dec 11, 2015 | Blomberg Washing Machines
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
After washing a load there remained 1 min and the door would not unlock. I manually unlock the door, load was spun out, but could not get another load started.
you couldnt wait 1 minute??,now you need to check alignment of the door lock and switch,make sure that the lock works and all the door switches are aligned
May 18, 2015 | Kenmore HE2 Plus Front Load Washer
I need help with my Duet washer
it sounds like an electronic problem with the board.
Nov 07, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Hitachi programme 1300 washer comes up with error F3. The machine is full. Can I reset or how do I get the door open to empty it??
Hi!
The door lock use electric power to stay closed. So, if you want to open the door, the power supply must be disconected from the mains plug. After a couple of minutes the door will be unlocked.
But please be carefull not to flood the room if the water level is visible trough the glass door.
Regards,
Bogdan
Aug 26, 2011 | Washing Machines
Washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
