Question about Superex Electronics - Others
I have a Superex 100W power inverter. I want to see if I can plug into cig lighter then a standard extension cord and lamp into it
  • Terry Weaver
    Terry Weaver Apr 24, 2017
    Yes, that will work just fine in your cig lighter -- it will pull about 9-10 amps, and most lighters are fused for 20a or more. Suggest you limit the light bulb to a 75 watt. If it really performs as spec'd it should support a 100w bulb.
    Master:
  • 923 Answers
In order to produce 100 watts at 120 volts, the current will be 1.2 amps. But if you are producing that power from 12 volts input, the current will be at least 10 times the output current, and that would be at 100% efficiency, which is impossible to achieve, The efficiency could be assumed to be around 70% though, meaning that the current input required to produce 100 watts at the output would be somewhere around 13 amps. That's a lot of continuous power drawn from a cig. lighter, and the load might blow the fuse or breaker for that circuit.
Posted on Apr 24, 2017
mrmx2333
  • 56 Answers
SOURCE: where the plug/cig. lighter power
you need to replace the flux capacitor DRRRR!!!
Posted on Dec 20, 2008
  • 12 Answers
SOURCE: fuse blow as soon as it plug it in
sounds like your inverter has died :)
Posted on Jan 30, 2009
smitty8475
SOURCE: cig. lighter and 2nd power slot for cord doesn't work,
It should be the fuse. They are located under the hood in the fuse box with the relays. you probably plugged something in that was faulty or needed to much power. the fuse is only a 10. i upped mine to a 20.
Posted on Mar 27, 2009
  • 12 Answers
SOURCE: I attach my inverter with custom battery cables
please check the voltage of the battery may be the voltage of battery is low or use the multi meter and check DC volts before conneceting the battery and after conneceting once more check the DC volts it could slove the problem
the beeping sound is due to battery low voltage
what is the DC input of the Inverter check the battery hook up if the inverter is of example DC 24 volts please check what is the input
Posted on Nov 17, 2009
  • 1738 Answers
SOURCE: I used my tom tom cig lighter power cord to power
I think it destroy. The tom tom might of use to much power, and toasted the nuvi.
Posted on Nov 21, 2009
How many and what colour wires are in the wires leading to the cig lighter end of this FM transmitter?
don't cut it, use something like this: http://www.carid.com/dorman/lighter-extension-cord-mpn-56479.html Check your local auto parts store
Aug 19, 2015 | Griffin Technology iTrip Auto Universal...
How do i charge it
On the back there should be a cover over a plug. Lift the cover and plug it in with a single outlet extension cord.
Jun 27, 2014 | Superex Deluxe power station with air...
How do I charge the Fatmax 450 Amp by Stanley
It should come with a DC or AC charging plug. All you have to do is plug it into either the 12v socket on your car, or your AC wall outlet, depending on which plug(s) you have.
Feb 11, 2014 | Vehicle Parts & Accessories
I DO NOT HAVE THE POWER CHARGING CORDS... ONLY THEAIN PART OF THE LIGHT/INFLATOR . WHAT POWER SUPPLY CLORD IS USED?
On the side of the unit is a small black flap that covers two prongs that you can plug a standard 110-120 volt extension cord into which will charge the unit. There are 3 read lights and 1 green lights on the top that lets you know when it is fully charged. The 12 volt charging cord is basically a cord that has 2 cigarette lighter plugs. One plugs into the unit and the other plugs into a power port/cigarette lighter plug.
Jul 16, 2010 | Vector 1 Million Power Series Spotlight &...
Trying to run a digital projector from a car battery
I looked at the power requirements of this projector, 280W, but that assumes a nice sine wave. Your inverted is supposed to put out 400W, but it's a modified sine wave. Under ideal conditions (including a good battery) this might be just enough. Connecting directly to the battery will help a little, because of the limited ability to get current to and through the cigarette lighter. Using a 100 foot extension cord will diminish the voltage a bit (less so if it's a heavy gage wire). I would try connecting the inverter directly to the battery, run the engine and skip the extension cord. If that works, turn off the engine. If that works, try the extension cord. If it won't work with the engine running, connected directly and no cord - there are two possibilities: (1) the projector just won't run on a modified sine wave, (2) you need a bigger inverter. --- regarding (1) I have seen lots of people having trouble with various devices. You might want to ask Epson support. --- Good luck!
May 26, 2010 | Black & Decker Black Decker 400 Watt...
I have a road pro rppi converter light links
It blinks because your computer is drawing too much current. Most of these give an exaggerated wattage range, and never give details about the true amperage available. the average laptop uses 3.0 to 4.X amps and is too much for these mini inverters. But they work fine on cell phone chargers.
Mar 24, 2010 | RoadPro AC/DC Power Inverter 80/100w
Overloaded my inverter -now only works when hooked to car battery
It sounds like the fuse that protects you cigarette lighter is blown.
After you have replaced the fuse, check the voltage again. 0.015vdc would not have powered anything that in manufactured to operate on 12vdc.
When powering anything over about 250W, I would suggest connecting directly to the battery to avoid overloading the lighter circuit.
Nov 07, 2009 | Vector VEC1024 400 Watt Power Inverter
Cig. lighter and 2nd power slot for cord doesn't work,
Mar 22, 2009 | 2005 Chevrolet Silverado
Fuse blow as soon as it plug it in
Jan 21, 2009 | Car Audio & Video
Electronics - Others Logo
583 people viewed this question
Top Superex Electronics - Others Experts
Are you a Superex Electronics - Other Expert? Answer questions, earn points and help others
