Question about Kitchen Ranges
Is a corning ware electric smooth top, self clean available on the market? Oven element burned out & 1969 range exhausted its life!
  • 1314 Answers
SOURCE: my manual clean oven range
you really don't need to remove them if your nervous just turn the power off at the breaker but they wont hut you as long as the oven isn't on
Posted on Jan 18, 2008
Agent Matt
  • 8 Answers
SOURCE: Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
Posted on Apr 07, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
Posted on Sep 25, 2008
SOURCE: ROPER ELECTRIC RANGE SELF CLEANING
how long to leave on to self clean
Posted on Apr 18, 2009
SOURCE: JBP84TOHWW GE Electric Range Large Dual Element Not Working
similar problem after a power outage. Display would be blank until I turned ON an element (after which display would light, but no power to the respective element. No elements would heat even thought the dial shows power). Turning OFF the element would blank the display. I reseated the power cord and cycled the 50a basement breaker for 5 mins. Everything now works, but not sure for how long.
Posted on Apr 11, 2010
My oven will self clean and the top will come on when in Broil but oven will not preheat in bake mode.
self clean and broil will make same heat for self clean
if this is a gas range then change bake glow ignition
more info can be yours send us full model # of range for more exact info of your range.
electric range will be element bake or broken burned wire
Dec 06, 2014 | Hotpoint Kitchen Ranges
What may cause the oven overheating during self clean
well last time I checked the self clean went to around 600 degrees . has to to burn off the stuff burnt on inside . and YES outside gets really hot .
Aug 28, 2014 | General Electric Ge Stove / Oven / Range...
I have a Maytag Gemini Double Oven Range. The model is nowhere on the appliance but on the manual it could be a MER6555/6751/6755/6775 or 6875. The lower over heating elemant on the bottom stopped working...
turn off breaker or unplug. then wires commonly burn out near the heating element. To determine if a wire has burned out, inspect the wires leading to the element. If a wire is burned out, it will often be visibly burnt.
Jan 14, 2018 | Maytag Gemini 30" Self-Cleaning...
The bottom oven is heating up very slow.
If you are having problems with your electric oven heating up too slowly, not being able to maintain temperature set point, or wild variations in temperature, then you probably have a bad baking element in your oven.
The bake element is the bottom element in your oven. The life span of these elements can vary depending on the usage of your oven and the quality of the element. Anything electric has an unpredictable lifespan. Elements made on the same assembly line can vary greatly in how long they last. But when the element burns out it will need to be replaced to have your oven work properly.
The thing the fools many people is that many ovens will use the broil element to preheat the oven and then switch to using the baking element only. When this happens the oven will no longer heat and will cool down. The unit may sense this and activate the broil element again which will cause wild swings in temperature and also can cause food to burn on the top self or not bake properly.
If you can see the elements, watch them and see if they both get red hot when initially warming the oven. If only the top, broil element gets hot then you have a burned out element or a bad contacts where the element plugs into. Usually lifting the element and pulling out on it will release the element. If the contacts are discolored or pitted then they could be causing your problems. By using an ohm meter you can check the resistance of the element. If you get no continuity through the element it is no good.Bad elements will often have blisters, bubbles, or even burn in two.
If the element contacts are bad, make sure the you replace both the element and the receptacle that the element plugs into. Replacing only the element will only temporarily solve your problem.
Jan 23, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Whirlpool Self Cleaning Oven - Model RF360BXXW Serial # FA4005915 Turned oven on bake - bottom element is not heating however top element is. Tried to change setting to 'timed bake', 'broil' and 'clean'...
Your lower element may be burned out. Generally you can firmly grasp and pull it out. Take it to a repair shop and get a replacement unit. Then simply snap it back into the same outlet where you remove the first one. It sound as if you've tried everything else so it must be the unit that is bad.
Nov 04, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Need power cord for corningware broil,bake tray Model P-54 and for the P-35-B tray Thanks
The Corning Ware P-35B bake broil tray is for use inside your oven or broiler. It can also be used inside your microwave. It is made out of the same material as regular Corning Ware bake ware and may also be used on top of the range. This is not an electrical part and should not have a connection for a cord. Corning Ware did make hot plates. Is this what you are seeking a cord for?
Oct 12, 2010 | Kitchen Ranges
My oven is two years old and the bottom oven coil will not heat up. The top one works just fine but not the bottom.
you may have a burned out bake element even if the range is only a couple of years old. if you can see the element look for a burned area. if you can't see it you will need to unplug the range and see how to get it out yourself or call a repair service. hope this helps.
Oct 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Self cleaning hotpoint stove
Sometimes in self clean it can burn out the element.  Need to check the element with an ohm meter and see if it shows resistance.  If it shows open then the element is bad.  If it shows resistance then the element is ok.  Next see if you are getting 220 volts to the element when in bake mode.  If you are not getting 220 volts then the control is bad.
Oct 20, 2007 | Hotpoint RB757 Electric Kitchen Range
Kitchen Ranges Logo
29 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
