Question about Ovens
The oven element burned out in the 1969 model manufactured by corning. Does corning currently have new models for sale?
SOURCE: MAJIC CHEF DOUBLE OVEN NOT WORKING
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Posted on Dec 18, 2008
dgjtex
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
SOURCE: whirlpool oven heating element
what are the meanings of gas marks,what is suitable for making pizza
Posted on Jan 22, 2009
  • 14 Answers
SOURCE: element ''melting''
paul,as the saying goes the dont make them like they used to,im sorry to tell you your elemant is on its way out dont be surpised if by the time this answer gets to you it is burnt out .sorry i could not give you better news.adrian ps.the elemant is melting please get it replaced.
Posted on Feb 14, 2009
  • 30 Answers
SOURCE: I need to purchase a new heating element for
you will need to call the parts store directly and ask them to order the part or if they know where to get it. My guess is that with the unit being that old, your part is obsolete.
Posted on May 03, 2009
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
How do I turn off demo mode for KitchenAid Model KEBS179BSS00
The following is from your Users Manual:
Demo Mode IMPORTANT: This feature is intended for use on the sales floor with 120 V power connection and permits the control features to be demonstrated without heating elements or burners turning on. If this feature is activated, the oven will not work.
1. Press OPTIONS until "DEMO MODE" is displayed.
2. The current setting will be displayed.
3. Press the "1" keypad to adjust the setting.
4. Press START to save the setting.
5. Press OFF to exit and display the time of day http://www.kitchenaid.com/digitalassets/KERS306BSS/Use%20and%20Care_EN.pdf
Feb 19, 2015 | KitchenAid Ovens
Whirlpool gold double oven model #gbd307pdb. upper oven lower heating element burned out. replace lower element. it does not get hot. upper element heats up. control board works. is this the thermos
You will have to see if there is power to the element. It is possible that the relay contacts burned when the element burned out. There is a fusable link but this would shut down both the top and bottom elements. If the relay is burned out the control board will need replacing or rebuilding.
Oct 28, 2014 | Ovens
Ge model jbp21gv2wh oven bottom element doesn't
Element is burn,t out, It will have to be replaced.
Nov 07, 2012 | Ovens
It's a Model JJW8530CAB. The baking element
Are you having any issues at all with the display at all? Did this start out of the blue or did you have a power outage or anything else?
Jan 20, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Switched bottom oven on, then noticed it had tripped fuse for cooker in main fuse box. Swithed it back on and it wouldn't heat up. The fan and light were ok! Top ove? grill works ok still.
sounds like you have a heating element burned out. Look real close at the heating elements and you may see a hole burned in the metal tube. This is a sure sign of a bad element. Some elements are easy to unplug. Others a real pain. Always unplug and or turnoff breaker prior to unscrewing anything. If you fine the bad element just unplug and other element may work OK. Best to get your model number and search net for new element.
May 30, 2011 | Ovens
HAve an older model dacor oven model w305. bottom heating element went out. REpair man said that type of element is no longer manufactured. It has a ceramic plug, just plugs in new ones are wired. Do I...
I just found 3 on Ebay. put in search dacor element. You will need the part number or you can email them if it will fit yours. goodluck
Oct 16, 2009 | Ovens
Element in top oven not heating up all the way.
Yes needs a new element.they burn out. easily.you know this because they sell them seperately.its there way to make money off of you.anytime they sell you something and the parts are readily available especially sold seperately you know its going to need to be replaced eventually..If you replace 1 replace them all to avoid furthur issues.
May 29, 2009 | Frigidaire 30 in. Electric Gallery Series...
I need to purchase a new heating element for this double eoven range (right Side)I believe the model is from 1969 but is still in great working order. I think the model # is RCDG-71P but the parts website...
Apr 19, 2009 | Frigidaire FEB27S5A Electric Single Oven
Baumatic b180 oven
The oven cabinet is likely built for several different models, which means that the case could have been built with an extra hole or two that aren't used on your model. This a normal manufacturing technique for mass-product factories. I see from the Baumatic website that several of their models do use a meat thermometer probe, but even if you bought a probe you couldn't use it your oven. Your model doesn't have the correct circuit board and control panel that the oven needs to use the probe. In any case, if you need to order parts from the manufacturer or would like a downloadable Owners Manual for your model, they are available at this website link: http://www.baumatic.co.uk/products/discontinued-models/builtinovens/B185SS-B Hope that helps! ;)
Aug 05, 2007 | Baumatic B180SS And B60SS (Bundle)...
Ovens Logo
19 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
