Question about HP PSC 1510 All-In-One InkJet Printer
New tri-color cartridge has a problem. I can't see what.
  • steve_truss Jul 23, 2009
    Hi
    It?s a new cartridge and the protective cover has been removed. I have removed the cartridges and powered off the printer and left it for 5 mins +.
    The error I get from HP is:- Print Cartridge Problem- tri-color. refer to printer documentation.
    Regards
    steve
  • Kevin Hughes May 11, 2010
    Is that what the printer/software says? If so more than likely the problem is with either the cartridge, or you didn't remove the tape from the new cart....should be an HP 93....if all i right, try removing all cartridges, powering down printer, and pulling plug, wait 5 minutes, and then reverse process. Get back to me if it doesn't work...
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Posted on May 21, 2011
Color cartridges are full but colored pictures are gross
Use the HP print utility and run through the tests. One bad cartridge will muck up the color completely.
There should be a clean print head option. Run it if the initial color test shows a clog.
Mar 20, 2014 | HP PhotoSmart Office Equipment & Supplies
Re: The printer will not recognize the installing of a new color cartridge.
after installing a new cartridge you need to open the program for your printer tray and reset your cartridges so that the printer and pc reconize the cartridge is full
Sep 19, 2007 | Dell 942 All-In-One InkJet Printer
HP Deskjet 5550 quit printing red color. Installed new color cartridge HP57. Quit printing red again after 5 pages. Is it a printer problem or cartridge problem?
Have you check your color cartridge if they are properly installed.
Make sure your are not using a refill cartridge.
Replace your tri-color cartridge with original an HP tri-color cartridge.
Aug 26, 2010 | HP DeskJet 5550 InkJet Printer
Keeps saying insert colour cartridge when we have just bought a new cartridge of correct spec. Says incorrect colour cartridge installed.Impossible to get past!!!
Hi,The most common reason for missing or incorrect colors is a print cartridge with one of the following problems:
  • One or more of the ink colors is empty. The black ink and all three colors of ink in the tri-color cartridge must be available or colors will be incorrect or missing. Under normal usage, the print cartridge will run low on one color of ink shortly before all ink colors are emptied.
  • The protective tape is not removed from a new cartridge.
  • Contacts on the cartridge are not making proper contact with the print carriage.
  • The cartridge is remanufactured or refilled.
  • The cartridge is defective.
Feb 14, 2010 | HP PSC 950 All-In-One InkJet Printer
My printer doesn't not recognize that I just put in a new color cartridge
hi,
try to remove the new color cartridge, if you have a clean cloth, try to wipe to copper strip of the new cartridge. try to wipe the copper strip of the carrier where you put the color cartridge, BUT before doing that make sure that the printer's power cable is unplugged.
place the power cable after wiping the copper strip of the color cartridge carrier. then place the color cartridge. if still same. try the old cartridge. if the old one is recognized, it's your new cartridge fault. you need to contact dell to have the cartridge replaced. if you ordered it from dell.
Sep 30, 2009 | Dell 922 All-In-One InkJet Printer
Error message says check color cartrigdge even
You did take the protective film off the new cartridge, correct?, could also be the contacts that recognize the cartridge ae dirty, also, try unplugging the power cord on the printer and plug back in to reset
Aug 22, 2009 | Office Equipment & Supplies
Dell 926 won't recognize new color cartridge
Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
Jun 17, 2009 | Dell 926 All-In-One InkJet Printer
Dell printer model# A940 50c error
Test your cartridges.
Remove the color ink cartridge then lower the cover of your printer. If the error message displays again, replace the black cartridge with a new one (or return the new one). Reinstall the color cartridge and remove the black ink cartridge then lower the cover. If the error message displays again, replace the color cartridge with a new color cartridge.
Note: My manual indicated that the printer might have detected a short circuit in a cartridge. I returned a month old black cartridge got a new one and my printer is working fine now. Good luck.
Nov 10, 2008 | Dell A940 All-In-One InkJet Printer
G%% color cartridge
You might have a bad cartridge or the contacts that marry to the cartridge to the machine needs to be cleaned.
Hope that helps...
Jun 18, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
819 people viewed this question
Seeker5211
Seeker5211
